Thread Number: 55171
Speed Queen Spin - is it BELT driven - does anyone know? |
Post# 775657 , Reply# 1   8/5/2014 at 17:55 (3,551 days old) by mtn1584 (USA)   |   | |
Sounds like you need a new belt...no biggie, part of the maintenance just like on a car. Mike |
Post# 775692 , Reply# 2   8/5/2014 at 19:48 (3,551 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
I am assuming it is a Top Loading SQ, if so it may need a belt or other repairs, but be sure that you are using a cycle with a high speed spin, and you could have a poor spin due an excessive detergent caused suds lock, lift the lid in the final spin and see if there is any suds peeking through the basket holes when the tub stops, if so cut down on the detergent, go to an HE detergent or try using fabric softener in the rinse.
Post# 775701 , Reply# 3   8/5/2014 at 20:35 (3,551 days old) by ryanm (New York)   |   | |
Thanks for the response! Yes it is a top load and it is running on regular spin speed which should be 710 rpm. No excess detergent, no suds, so now that I know it has a belt, perhaps that is all it will need. |
Post# 775739 , Reply# 4   8/6/2014 at 00:30 (3,551 days old) by washman (o)   |   | |
spring. As mtn184 said, easily and worthwhile to replace. |
Post# 775789 , Reply# 5   8/6/2014 at 09:15 (3,550 days old) by mrb627 (Buford, GA)   |   | |
Post# 775874 , Reply# 6   8/6/2014 at 18:50 (3,550 days old) by nmassman44 (Brooksville Florida)   |   | |
I had the same issue with my SQ washer and changing the belt did the trick. I did it myself, so of your handy it can be done. Fair warning though this is not a simple change like a Maytag helical drive machine. It took me a good 20 mins to get the bolts undone and then got the pump off ...it's held by clips and then threaded the belt onto the pulleys , then I found out I didn't need to take the motor assy out...undo the top and tilt the wash system to tilt it upward to get to the clips on the pump, pull down and get the belt on that way. But anyways a belt change will take care of your extraction issue.
