Thread Number: 55807
Late breaking news from Ogden... It lives! |
Post# 781972   9/6/2014 at 18:32 (3,520 days old) by turquoisedude (.)   |   | |
Well, I figured I had nothing to lose, so I plugged the J-47 Bendix automatic in...
No sparks, flames, etc - always a good sign. Better still - it ran!! The motor kicked right in and the tub started spinning. Unfortunately, I think the machine is a victim of 'timer motor death' - the timer did not advance during 'wash'... I advanced it manually and heard what I believe was the drain solenoid kick in and when I brought it to the 'dry' portion of the cycle, the machine kicked into the dizzying 330 rpm final spin. Not even going to try to compare it to the Unimatic... LOL
So the Bendix is in better shape than I thought!! Maybe tomorrow I'll peek at the timer and see what kind of drive motor it needs...
Post# 781979 , Reply# 1   9/6/2014 at 19:06 (3,520 days old) by rberryiii3 (Palm Springs, California)   |   | |
In the 20 years we had this washer as a kid we replaced the timer twice....I can't imagine where u will find one Best of luck This is on my list of must haves for my collection |
Post# 782053 , Reply# 2   9/7/2014 at 02:46 (3,519 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 782079 , Reply# 3   9/7/2014 at 07:17 (3,519 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
These older timer motor are easy to replace with the timer motors that came after the dreaded black motors. The new style motors look different, they are in a Steel plated silver case and have the timer motor leads attached. These newer timer motors were used from roughly the mid 50s through most of the 1960s and seem to be much more reliable that the earlier DBMs.
Post# 782822 , Reply# 4   9/10/2014 at 13:03 (3,516 days old) by Tomturbomatic (Beltsville, MD)   |   | |
The timer probably did not advance in the wash because the water level switch was not satisfied if you were running it dry. |
Post# 783465 , Reply# 5   9/13/2014 at 11:50 (3,513 days old) by turquoisedude (.)   |   | |
Post# 783660 , Reply# 6   9/14/2014 at 11:49 (3,512 days old) by bendixmark (Winchester Mass)   |   | |
Try blasting the motor with wd40 and then electronic contact cleaner it worked on my bendix which is the same one you have.Rotten shame the drive motor doesnt run after smoke poured out of it that day. |
Post# 788331 , Reply# 7   10/10/2014 at 13:36 (3,486 days old) by maytagman (Half Moon)   |   | |
Hi Paul, Any luck on that timer motor? Thanks, Don |
Post# 788333 , Reply# 8   10/10/2014 at 13:52 (3,486 days old) by turquoisedude (.)   |   | |
Alas, no.... I did try to cheat the water level switch to see if that might make the timer kick in, but it didn't. The motor has indeed succumbed to 'black timer motor death'. I have been seriously wondering if the motor from the aluminum Christmas tree colour wheel might be a replacement... Ya never know!! |
