Thread Number: 55934
Whirlpool Dryer Temp Control Switch, PN 688712 ?
Post# 783107   9/11/2014 at 20:26 (3,514 days old) by dogstarb52 (Athens, GA 30601 usa)
I am looking for the Temp Control Switch for an old Whirlpool Dryer--PN 688712, I believe. WP Model LE5780XKW0 Serial#M21828288
www.appliancepartspros.com/whirlp...
NLA ?
Or how to determine where it is set, since the stem is broken flush with switch face ?
Thanks!
Post# 783283 , Reply# 1   9/12/2014 at 17:22 (3,514 days old) by dnastrau (Lords Valley, PA)
Switch on Ebay
Greetings:
Here is a used one on Ebay.  I also replied to your original thread with the link to Ebay.
Andrew S.
CLICK HERE TO GO TO dnastrau's LINK on eBay
Post# 783398 , Reply# 2   9/13/2014 at 04:00 (3,513 days old) by dogstarb52 (Athens, GA 30601 usa)
Thanks!
I saw that already, but thanks!
I have to test the dryer before I buckle under to buying an over-priced, used part--
Ouch?! He knows what he has, but I can wait...I am not that desperate, hah?!
Post# 783417 , Reply# 3   9/13/2014 at 07:13 (3,513 days old) by thefixer ()
You can tell what it is set to by either checking the dryer exhaust temperature or checking continuity between the temp switch AH terminal to the line side of each of the three thermostats to determine which one has been selected. If the wiring diagram tells you which thermostat is which (probably doesn't), you could just check continuity on the back of the temp switch.
Post# 783418 , Reply# 4   9/13/2014 at 07:15 (3,513 days old) by akronman (Akron/Cleveland Ohio)
Waiting
akronman's profile picture
Yes, way overpriced. Patience. Also, ask around this website for crossover PN's, Whirlpool/Kenmore may have 2 or 3 or more switch PN's that can all be used. Post a picture of the dryer and console, it may jog some memories.
Post# 783435 , Reply# 5   9/13/2014 at 08:47 (3,513 days old) by thefixer ()
Owners manual might give some insight.
shared.whirlpoolcorp.com/assets/p...
Post# 783455 , Reply# 6   9/13/2014 at 10:40 (3,513 days old) by DADoES (TX, U.S. of A.)
dadoes's profile picture
It has a separate thermostat for each of the three heating temps (high, med, low) per the parts diagram.  The LE5790XP I have has two heat choices instead of three, and has only one thermostat with a bias heater on it to trick it into reading the lower temp.
That was an engineering redesign which came into play at some point after the K series ... using one thermostat with the bias heater instead of multiples.  My 1991 KitchenAid dryer has three heats but also just one thermostat.
