Thread Number: 55958
Speed Queen Front Load Washers and Dryers |
Post# 783320   9/12/2014 at 19:17 (3,513 days old) by richardlxixxx (Old Westbury, New York)   |   | |
Good Evening,
I currently work as a House Manager for a very large Estate in New York. We have 2 laundry rooms and 4 washers and dryers. The equipment is heavily utilized and after 7 years is starting to fail. In the past I have purchased Whirlpool Duet washers and dryers. I am considering switching to Speed Queen front load washers as they are commercially built units for home use. Does anyone have any experience or history with Speed Queen front load washers? How about the matching dryers? My only concern is that they do not have a sensor in the drum and I worry about over drying. Feedback and information will be greatly appreciated. The washers do have a smaller capacity than my current units, but the cycles are much shorter on the Speed Queen. Which means the staff can probably manage to do the same amount of laundry on a daily basis.
A great evening to all,
Richard Old Westbury, New York |
Post# 783409 , Reply# 2   9/13/2014 at 05:48 (3,512 days old) by DADoES (TX, U.S. of A.)   |   | |
Washers and dryers don't necessarily have to be a matched set. Choose some other brand/model of dryer if moisture-sensing autodry is preferred over thermostatic sensing. They also don't necessarily wear-out at the same rate, so keep the current Duet dryers if they're still OK or can be brought up-to-speed with a bit of servicing. |
Post# 783430 , Reply# 3   9/13/2014 at 08:27 (3,512 days old) by mrb627 (Buford, GA)   |   | |
Post# 783518 , Reply# 5   9/13/2014 at 16:34 (3,512 days old) by richardlxixxx (Old Westbury, New York)   |   | |
Thank you for the input.
I do have to have a matched set as they will be stacked. No other option is available.
Malcom, as you do have a matched set, please give me your opinions of the dryer. As our laundry at the Estate is not heavily soiled, are the cycle times as short as indicated by Speed Queen? How do you soak in the machine? Just turn it off?
Do you have any videos of the washer and dryer in operation?
Thank you,
Richard |
Post# 783520 , Reply# 6   9/13/2014 at 16:38 (3,512 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 783525 , Reply# 7   9/13/2014 at 17:10 (3,512 days old) by mrb627 (Buford, GA)   |   | |
If I need to soak something, I will just turn the cycle switch to off. Then return to it after whatever time limit has passed. Then I will either set it for rinse and spin for a short agitation before pumping out and extracting or resume the regular cycle as needed.
I find the dryer a lot easier to live with than one of the electronic sensor machines. When I had a duet pair, I found that with a small load of clothes, the dryer would quit after a couple minutes and rarely dry the load to completion without needing to be reset. None of that nonsense with the Speed Queen. There are several videos on my YouTube site of the washer in operation. Malcolm |
Post# 783527 , Reply# 9   9/13/2014 at 17:33 (3,512 days old) by mrb627 (Buford, GA)   |   | |
Post# 783534 , Reply# 10   9/13/2014 at 18:26 (3,512 days old) by appnut (TX)   |   | |
What's the logic behind the pulse spins between each rinse and after the first wash? I like that it does that spray rinse before the 1st set of pulse spins after wash. I guess that's kind of a suds kill?
How long is regular's wash cycle peroid? I guess perm press has a slightly shorter wash period. Is the tumble pattern the same as on regular--and I know the final spin's sequence is slightly different than regular.
How does it handle a much larger load than these towels? I know my sister's going to be asking questions. Glad I got to see this video. |
Post# 783651 , Reply# 11   9/14/2014 at 10:25 (3,511 days old) by washerdude (Canada )   |   | |
Well this is a little......scary.... CLICK HERE TO GO TO washerdude's LINK |
Post# 783658 , Reply# 13   9/14/2014 at 11:30 (3,511 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
You can buy the non SS model for around 1500.00 and the machine will last the average user [ at 10 loads per week ] about 50 years and do the job every time in about 45 minutes. The SQ FLer will outlast a Miele by 2 1/2 times and most other US FLers by 3-4 times, this would easily make the SQ FL washer the cheapest to own automatic washer period.
Post# 783663 , Reply# 14   9/14/2014 at 12:02 (3,511 days old) by Pulsator (Saint Joseph, MI)   |   | |
I love my Speed Queen FL washer except for 3 things:
1) I REALLY wish it had a soil level selector. 24 minutes of wash it just too long for some loads and I'm not about to sacrifice the 1,000 RPM spin to shorten the wash period. 2) The spin cycles are somewhat finicky. For the pulse spins, if it can't balance on the first try, it bumps off the fastest pulse. I've had it only successfully do one pulse before which isn't enough. It'll also lower the final spin speed if it has any trouble balancing. Sometimes it goes wayyyyy off balance and the rim of the tub slams into the glass leaving a huge gash in the glass. 3) Socks and other small items will sometimes fall into the seal while it's washing and then remain there for the rest of the cycle. I usually end up rewashing that item with the next load since it never got washed fully, rinsed or spun out. If they fixed those three things, I'd be much happier with my machine. |
Post# 783679 , Reply# 15   9/14/2014 at 13:50 (3,511 days old) by DADoES (TX, U.S. of A.)   |   | |
That review is among the goofiest I've run across. They're yammering about a Heavy Duty cycle (combined with Delicate) which their own pictures of it clearly indicates Delicate/Bulky ... Heavy Duty is nowhere on the dial. And fussing about no Normal cycle? What do they think Regular means? And calling-out the plastic dispenser drawer (and then grudgingly saying that at least it won't rust). Do any machines on the market have a metal dispenser drawer? |
Post# 783747 , Reply# 16   9/14/2014 at 19:14 (3,511 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
been running for a couple years now.
I always insisted on dampness sensors using WP dryers but this dryer is every bit as functional with out. I haven't over dried anything in two years which does surprise the heck out of me.
Read the manual and the dryer does exactly what the manual states, I don't know how they achieved this without a sensor circuit but they did.
Post# 783751 , Reply# 17   9/14/2014 at 19:39 (3,511 days old) by mrb627 (Buford, GA)   |   | |
Post# 784665 , Reply# 20   9/19/2014 at 23:36 (3,506 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
When we were in training with SQ their reps are the ones that said they could last 25,000 loads, 10,000 loads sounds about right for their very good TL washers.
I currently have a 6 YO SQ FL pair that we took out of the Jefferson Hotel in Washington DC, this washer and electric dryer washed and dried almost 35,000 loads in a period of around 5 years [ they estimated about 20 loads per day] with very few problems, and they are still in great shape and we are reselling them. |
Post# 784668 , Reply# 21   9/19/2014 at 23:41 (3,506 days old) by whirlcool (Just North Of Houston, Texas)   |   | |
Do these machines only do spray rinses or will they do a deep rinse too? |
Post# 784672 , Reply# 22   9/20/2014 at 00:58 (3,506 days old) by mark_wpduet (Lexington KY)   |   | |
Post# 784720 , Reply# 23   9/20/2014 at 09:17 (3,505 days old) by mrb627 (Buford, GA)   |   | |
I never went through with selling them. They sat in the garage while I had the Miele's in use. I moved them back inside to verify operation before selling them and realized how much I preferred them to the Miele's. So the Miele's got sold instead.
A heater would be nice, but the reality is you can certainly get by without it. Malcolm Combo, would love a pic of the set you are planning to sell... |
