Thread Number: 56952
/ Tag: Modern Dishwashers
Miele Wash Rinses |
Post# 792537 , Reply# 3   11/7/2014 at 13:47 (3,458 days old) by logixx (Germany)   |   | |
Post# 792560 , Reply# 4   11/7/2014 at 16:11 (3,458 days old) by mtoronto (Toronto)   |   | |
Hi guys! Thanks for the responses, my model is the G2141 SCU |
Post# 792561 , Reply# 5   11/7/2014 at 16:13 (3,458 days old) by mtoronto (Toronto)   |   | |
There was no more info :( |
Post# 792574 , Reply# 6   11/7/2014 at 18:15 (3,457 days old) by logixx (Germany)   |   | |
The service manual for the G1000 / G2000 series does not cover the follow-up units that had an xxx2 in the model number. However, both the user manual for your dishwasher as well as the service manual describe setting the amount of rinse aid to be dispensed in the same way. See page 129 and following for possible hidden-menu adjustments such as Extra Rinse or Extra Water. Customer service might help you over the phone as well - if you're lucky.
applianceservicesecretsmembership... |
Post# 792604 , Reply# 7   11/7/2014 at 20:30 (3,457 days old) by aamassther (Hendersonville, NC )   |   | |
One rinse on the normal cycle is likely correct. The normal on my La Perla II, which if iirc, is of the same model line and has only one rinse as default. Thanks to member, nmassman, who posted the instructions to access the hidden menus several years ago. I was able to add an extra rinse and increase water levels in all programmes, as logixx suggests. Making an otherwise useless programme useful. Again, iirc, this was the entry level of the line and believe that it didn't include the sensor system used on the upper end of the range.
Post# 792607 , Reply# 8   11/7/2014 at 20:52 (3,457 days old) by mtoronto (Toronto)   |   | |
Thanks! I will follow the directions and see what happens. |
Post# 792664 , Reply# 9   11/8/2014 at 06:57 (3,457 days old) by lavamat_jon (UK)   |   | |
It does at least one interim rinse before the final rinse, so you still get at least 2 rinses overall. |
Post# 792683 , Reply# 10   11/8/2014 at 08:56 (3,457 days old) by aamassther (Hendersonville, NC )   |   | |
Post# 792688 , Reply# 11   11/8/2014 at 10:04 (3,457 days old) by logixx (Germany)   |   | |
It probably tries to carry over most of the heat from the main wash into the final rinse to save energy by not having to heat as much. Previous versions of Energy Label Normal cycle did two prewashes in order to purge as much cold water from the line so that the dishwasher didn't have to heat as much.
Post# 792705 , Reply# 12   11/8/2014 at 13:13 (3,457 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 792778 , Reply# 14   11/8/2014 at 18:49 (3,456 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
jerrod6, In canada province of quebec we de not have water bills since the town i live in do not charge for water for your info but it also depends on the dishwasher model i have a kenmore elite dishwasher but if i have the hi temp option selected it starts heating the water as soon as i press smart wash cycle chose the options hit start and voila no need to run the faucet first.
