Thread Number: 5703
LG Steam Washer, Diagram how it works
Post# 119185   3/31/2006 at 22:36 (6,600 days old) by ggibson ()
www.absolutehome.com/web/catalog/...
Select Product Specs to see a diagram of how steam generator works, also with tests indication less water used etc.
Post# 119266 , Reply# 1   4/1/2006 at 05:57 (6,599 days old) by designgeek ()
When the page opens, look for the bullet points under the picture, and click on "Product specifications."
Clever system, also seems pretty efficient. Though, I do wish they'd do away with those weird ratings such as MEF, and just stick to straight-up power consumption for one load of X lbs. on Y cycle settings (which can be translated to watt-hours per pound of laundry) and also publish data for the full range of cycle settings, i.e. "minimum is Q, maximum is R."
Post# 119349 , Reply# 2   4/1/2006 at 15:58 (6,599 days old) by acerone ()
Home Depot has the white model on sale for $1499 plus up to $200 off if you open up a account with them. The extended warranty isn't bad also. 3 years for $59.00 and 5 years for $89.00.
