Thread Number: 57091
Bauknecht WA758SC |
Post# 793932   11/14/2014 at 20:18 (3,450 days old) by statomatic (France)   |   | |
Hi, I've recently get this very nice machine picked up by a friend.
Built like a tank, heavy, steady and pretty quiet because it uses an asynchronous motor (spin speed 800rpm by using a clutch mechanism). The drain pump were completely dead and the filter gaskets leaked. We replaced it by a Copreci with some modifications. Is anyone has some infos about this kind of machine ? They seems to almost doesn't exist on the web. I'll post some other pics tomorrow. |
Post# 793975 , Reply# 2   11/15/2014 at 05:25 (3,450 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
You're welcome! ;-)
Here is the link to the thread with the whole brochure. The specifications are there too. If you can't make anything of the Dutch, just ask. www.automaticwasher.org/cgi-bin/T... |
Post# 794111 , Reply# 3   11/15/2014 at 18:51 (3,449 days old) by statomatic (France)   |   | |
Thanks for your replies guys.
This brochure is very interesting, the coppertone one looks sexy ! @ foraloysius: I don't understand Dutch so if you can translate some infos about the 758 it will be cool. As promised here is some other pics: |
Post# 794146 , Reply# 4   11/15/2014 at 23:02 (3,449 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
KEMA is the Dutch electric safety institute, this machine has a label from it.
It has a child safety system, that locks the door during the whole program. Capacity is 5kg, drum is 46 liters. Spin is 850rpm. It has a wool cycle. The button on the right is the spin button, you can use it with the non-iron/permanent press cycle and the wool cycle. The left button is the 1/2 load button, the machine will use less water if you use that. A 95*C cycle with prewash will use 106 liters, 2.8kWh and will take 110 minutes. |
Post# 794211 , Reply# 5   11/16/2014 at 07:24 (3,449 days old) by statomatic (France)   |   | |
Post# 794325 , Reply# 6   11/16/2014 at 17:41 (3,448 days old) by statomatic (France)   |   | |
Here is some internal pics:
Is anyone has the schematic diagrams of this machine or an equivalent model ? |
