Thread Number: 57402
HELP! Hotpoint dishwasher making noise... |
Post# 797553   12/5/2014 at 15:02 (3,429 days old) by maytaga806 (Howell, Michigan)   |   | |
So Ive had this 1980s Hotpoint (GE) dishwasher forever. Its always worked fine. here and there it vibrates. Just the past two times Ive ran it, the vibration gets even worse. The vibration starts as water enters the tub, and the arm starts rising and cleaning the dishes. And the vibration is worst then. Throughout the entire cycle it vibrates. The motor I think? And now yesterday, it was doing the same thing. But as it got into the last two rinse cycles, their was not only vibration, but a fast clicking sound. It was still cleaning the dishes, no issue with that. Just clicking & vibrating. Very fast & repeative clicking. Like its the impeller? So what on earth is wrong with it? Im afraid to use it because I dont want it to leak or not drain or something. Thanks, Dan!
Post# 797591 , Reply# 1   12/5/2014 at 21:11 (3,429 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 797797 , Reply# 3   12/7/2014 at 00:50 (3,428 days old) by MattL (Flushing, MI)   |   | |
Does it have an upper rack washarm? If so the coupling in the back can wear and cause a noise something like you are describing. It's a cheap part only a few $ and easy to replace, just snaps on the tube that runs up the back of the DW. |
Post# 797854 , Reply# 4   12/7/2014 at 11:25 (3,427 days old) by washran (Appleton Wisconsin)   |   | |
My GE did this and it was the fan on the motor ... take the bottom panel down and start it up and stop it if the fan is off the shaft it will vibrate and make a ticking noise. you can see it. loose. Had to replace the motor... very common with these. |
Post# 800867 , Reply# 5   12/25/2014 at 19:43 (3,409 days old) by maytaga806 (Howell, Michigan)   |   | |
Thanks. Unfortunatley, we dont use the dishwasher nearly as much to where we would fix it. My dad will probably get rid of it and use the space for something else. Since were on septic, he thinks its ''Too much''. Pshhh. I very disagree. @washdaddy thanks for the advice. Machine hasnt ran since I posted this. I dought we will even fix it. @MattL nope. Its 27 years old, has one wash arm the maine bottom one. Theirs a little thing at the top thats supposed to be a little tiny spray jet with two holes which doesnt work at all. It doesnt get water to it or something? Anyway, the noise comes from the motor. Thanks for all the responses!
Post# 800870 , Reply# 6   12/25/2014 at 20:49 (3,409 days old) by appnut (TX)   |   | |
