Thread Number: 57927
/ Tag: Vintage Dryers
Clogged filter? Anti static sheets? |
Post# 803806   1/13/2015 at 10:48 (3,391 days old) by g3bill ( San Fernando Valley, So. Cali.)   |   | |
The filter in our older Dryer gets clogged every month or two I guess with the chemical used on these anti-static sheets like "bounce" . I noticed it mostly with the Costco Brand. Takes forever to clean the filter screen as the lint sticks to the screen. Is this just something ya have to live with or any alturnatives out there? The dryer is electric.
Post# 803821 , Reply# 1   1/13/2015 at 11:31 (3,391 days old) by tennblondie78 (Bowling Green, KY)   |   | |
Post# 803824 , Reply# 3   1/13/2015 at 11:37 (3,391 days old) by Yogitunes (New Jersey)   |   | |
best thing to do is run hot water over the screen, and maybe some dawn and a toothbrush to clean it out very well....
that will take care of the filter......but think about what kind of build up you have all inside the machine, especially the sensors... always best not to use these items, but if you must, maybe cut the sheet in half, or use sparingly.... |
Post# 803825 , Reply# 4   1/13/2015 at 11:39 (3,391 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 803885 , Reply# 5   1/13/2015 at 16:32 (3,391 days old) by PhilR (Quebec Canada)   |   | |
I never use Bounce or other anti-static sheets (and I rarely use fabric softener in the washer) but I recently noticed that some dryers seem to produce more static than others. Of course, it seems to happen more when the clothes are over-dried and they are rarely overdried in my Filtrator dryers! Recently, I unloaded my 1-18 dryer which tends to dry a bit more than I like (it still has a smaller Maytag blower wheel, maybe I should re-install a Frigidaire blower in it!) and there was a lot of static in my clothes. A friend of mine, who doesn't care much (or at all!) about laundry or appliances told me that porcelain-coated or stainless steel drums are less prone to cause static in clothes than painted ones. I was quite surprised to hear a comment like that from him and I'm wondering where he got that information! Could that be true? |
Post# 803896 , Reply# 6   1/13/2015 at 17:23 (3,391 days old) by kb0nes (Burnsville, MN)   |   | |
Post# 803920 , Reply# 7   1/13/2015 at 18:55 (3,391 days old) by hippiedoll ( arizona )   |   | |
that some people have used aluminum foil balled up loosely & tossed in the dryer with the wet clothes. and that this eliminates static in the dryer. i myself have never tried this for fear that the sharp/pointy edges of the aluminum foil ball, might cause damage to clothes or the inside of the dryer drum. but that's just me.
maybe someone here who has tried this aluminum foil ball, in the dryer, can chime in and give us first-hand experience about this working for static and any damage to the clothes or dryer drum itself? |
Post# 803933 , Reply# 9   1/13/2015 at 19:37 (3,391 days old) by g3bill ( San Fernando Valley, So. Cali.)   |   | |
wELL, tHE PROBLEM WITH HALF SHEETS IS i TRIED THAT AND MY vERY OLD MOM JUST PUTs 2 IN, HARD TO TRAIN An OLD DOG new TRICKS:) Liquid softener might be a good idea in the wash if it stops the static? I heard those bounce type sheets can be put in the wash but haven't tried it. I heard of the Aluminum foil thing and forgot but good point on possible damage unless we hear otherwise? I clean the film off the filter with hot water and small brush but takes time so as not to damage the screen, doubt I could find another one easy. Great point on the sensor, never thought of that. Thing is just bought a box of bounce;( If it will work in the wash would be good or might return the junk and try liquid. Its just my mom and her light cloths that get static, I dry on economy and no problem with mens clothing.
I think the dryer has paddels that are plastic, drum is porcelain. |
Post# 803991 , Reply# 11   1/14/2015 at 03:52 (3,390 days old) by ozzie908 (Lincoln UK)   |   | |
it removes all film traces and helps cut down dryer time.
As for static its to do with synthetic clothes rubbing together that causes it the remedy has been mentioned and liquid softener just with synthetics cuts it out also I have noticed that since changing to a heat pump dryer that is so gentle and similar to the Filtrators it does not have any static either with or without fabric conditioner it seems overly hot dryers cause more static than others I believe. Austin |
Post# 803999 , Reply# 13   1/14/2015 at 06:48 (3,390 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
My favorite GE design - do you have the washer too? Beautiful!
I never use dryer sheets, in fact just tossed a box of them a few weeks ago I found on the shelf in the garage above that dryer. Maybe three or four were used, probably for other purposes like the car, etc. When we used them years ago in a GE/Hotpoint dryer, the sheets would invariably end up in the filter. They usually were deposited there near the beginning of the cycle it seemed. |
Post# 804009 , Reply# 14   1/14/2015 at 07:56 (3,390 days old) by tennblondie78 (Bowling Green, KY)   |   | |
