Thread Number: 58058
/ Tag: Vintage Dishwashers
Mint doesn't even describe this new find! |
Post# 805412   1/22/2015 at 20:37 (3,381 days old) by jetaction (Minneapolis)   |   | |
This made its way home today and I couldn't resist. The only thing is the rubber fitting over the nipple for the power shower wash arm was so brittle I broke it off. I will have to find a replacement, any suggestions? I would be interested in a copy of the owners manual as I enjoy reading these.Also, the model # is 1SP40T1 and the serial number is RT7-05311. If I dated this correctly it is August of 1960, experts can weigh in! Very quiet machine in my test, I was surprised at that and it was empty when I tested her.
Post# 805414 , Reply# 1   1/22/2015 at 20:45 (3,381 days old) by jetaction (Minneapolis)   |   | |
Post# 805416 , Reply# 2   1/22/2015 at 20:51 (3,381 days old) by pulltostart (Mobile, AL)   |   | |
Post# 805418 , Reply# 3   1/22/2015 at 21:09 (3,381 days old) by moparguy (Virginia)   |   | |
Congratulations, that is beautiful! |
Post# 805420 , Reply# 4   1/22/2015 at 21:19 (3,381 days old) by warmsecondrinse (Fort Lee, NJ)   |   | |
Very cool. |
Post# 805425 , Reply# 6   1/22/2015 at 21:51 (3,381 days old) by roto204 (Tucson, AZ)   |   | |
Post# 805430 , Reply# 7   1/22/2015 at 23:23 (3,381 days old) by rpms (ontario canada)   |   | |
Post# 805446 , Reply# 9   1/23/2015 at 05:59 (3,381 days old) by appnut (TX)   |   | |
Post# 805456 , Reply# 11   1/23/2015 at 06:57 (3,381 days old) by turquoisedude (.)   |   | |
Don this an amazing find! I have only seen one other GE impeller dishwasher with the extra cup racks and I believe it also had been a 1960 model. I think you found a low-use machine here!!
The hoses of the GE Mobile Maids are something of a weak point so check them out carefully. I still have to try this out, but I managed to unscrew the water supply hose from the Unicouple assembly of one of mine and got someone who works with hydraulic hoses to attach a new high-pressure hose to the original threaded connector. I haven't tried it out yet, alas so I am not sure that will be a good solution or not.
In a pinch, you could substitute a more recent hose assembly but you probably wouldn't be able to save the original Unicouple...
Can I guess the cycles base on the four buttons?? Fine China and Crystal, Utensils, Normal Soil, Heavy Soil (with water heated IIRC) Wash are what I'd think of first.
I know some in CT who will be chiming in about this one!! This post was last edited 01/23/2015 at 07:18 |
Post# 805458 , Reply# 12   1/23/2015 at 07:09 (3,381 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
Post# 805461 , Reply# 13   1/23/2015 at 07:27 (3,381 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 805482 , Reply# 14   1/23/2015 at 10:05 (3,381 days old) by jetaction (Minneapolis)   |   | |
Thanks for the input, I wondered what that baffle was for Tom, now I know.
Paul the buttons read: Open Cover Daily Dishes Mixed Loads Utensils Pots Pans Fine china & Crystal I will have to be careful with the hoses as they seem a little hard, I do have an extra set that I could part out but of course I would want the shiny stainless uncoupler on them.... This model has the feature that the top pops open in the dry cycle, kind of fun. As far as the top sets of tines, cups don't stay up there and even my smallest juice glass would prevent the top from closing. Maybe it's just my cups and glasses.... |
Post# 805485 , Reply# 16   1/23/2015 at 10:17 (3,381 days old) by jetaction (Minneapolis)   |   | |
I noticed that the water was being heated, this really was (from my small pool of impeller knowledge) about the most fully featured, best performing of the impeller machines I believe. I am really impressed so far and I have always kind of written them off. Tom you are correct about the cycles skipping the first rinse for china and pots/pans. Seems that pots/pans would have the longest cycle. It appears the lid opens soon into the drying cycle, is this correct?
Post# 805494 , Reply# 17   1/23/2015 at 10:50 (3,381 days old) by turquoisedude (.)   |   | |
Don, thanks for the info - of course this would have to have a 'cover open' button... LOL Pretty darn difficult to load if not, eh? I guess it was only the SU70 Undercounter that had the 4 cycles.
I was thinking about the connection sleeve for the power shower; maybe the flexible part of a faucet adapter meant to go on a tap where one could not disconnect the aerator would work. They should be in the plumbing department of the larger hardware stores and they usually have a standard 3/4 inch garden hose connection on one end.
Post# 805518 , Reply# 19   1/23/2015 at 14:17 (3,381 days old) by turquoisedude (.)   |   | |
I think the "logic" behind those first Utensil/Pots and Pans cycles was that the cycle would help soften the heavy soils for hand-scraping OR that one would scrape and pre-scrub the pots then use the dishwasher to de-grease and thoroughly rinse 'em. Either way the shortened or skipped heated dry was probably intended to not have gunk baked back onto the pots and pans.
I believe it's actually suggested in the KDS-14 dishwasher owner's manual to use the Utility and Utensil cycle to loosen the gunk on pots, scrape off whatever was left at the end of cycle, then reload and run a Full Cycle. I look forward to trying that approach out someday in the very near future... |
Post# 805524 , Reply# 20   1/23/2015 at 15:02 (3,381 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 805658 , Reply# 22   1/24/2015 at 07:59 (3,380 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
I remember our machine had a big pink grind I'd say they were an 1" to 2" square. It didn't prevent silverware from dropping thru but that was only on loading-unloading.
It was separate from the bottom rack, I remember that too. Our machine looked like one in the 1957 brochure. Flat large dial to the right, ivory grill about with the slider in the middle. One strip of chrome handle across the top which dipped down for the dial to show. Ours had the walnut wood front. |
Post# 805845 , Reply# 24   1/24/2015 at 23:57 (3,379 days old) by jetaction (Minneapolis)   |   | |
I don't bring that much home any longer but I have had so much fun listening to all your memories, expertise, advice and contributions for this little gem of a find. It makes it so personal when you all share your memories of this or other appliances that we are all passionate about. Tom, Paul, and everyone else I will make you a deal, you plan a trip to Minneapolis at the same time. I will have you over for dinner and we can put the pots and pans in the dishwasher to loosen up the cooked on debris, than we will wash them as usual to test the 1960 strategy for cleaning pots and pans. The best part Tom is that I will use big pillar candles for the dinner party and we won't blow them out at all-"we'll stay up all night and sing them all" as Judy Garland said in her Carnegie Hall concert! Bigalsf I will send you my address in response to the email you sent, thank you so very much!
Post# 805893 , Reply# 25   1/25/2015 at 07:38 (3,379 days old) by turquoisedude (.)   |   | |
Don, that sounds like a blast! I'll bring the Jersey Milk.... This post was last edited 01/25/2015 at 08:27 |
Post# 805895 , Reply# 26   1/25/2015 at 07:53 (3,379 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
and be sure some burns to the pan, then you'll see the power of the bowtie- or better yet mom always burned the peas -- always! Thats a good test !! LOL
The '57 was the perfect machine to use Dawn in !! I was once young and down at the Cape where we reinstalled that machine after upgrading Schenectady with a KA-19. I loaded the GE , had no powdered detergent so thought just a drop of Dawn would suffice.
Well the machine started and slowly the GE ROAR started to die down, then it got nice and quiet - almost soothing. Then my friend Gail screamed, I turned around and saw-- GOBS OF SUDS pouring out the white grill at the top down the walnut front and across the kitchen floor in one wide swath of pure white suds !! It kept coming! I opened the machine, the entire tub was a solid block of suds - nothing was visible, even the pink dispenser was gone! We scooped out what was "shaving cream" at this point with pots !!
The kitchen floor was really clean that day.
Post# 805905 , Reply# 27   1/25/2015 at 08:37 (3,379 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
Post# 806045 , Reply# 28   1/26/2015 at 00:00 (3,378 days old) by A440 ()   |   | |
Don what an awesome find! It is in beautiful shape! B |
Post# 806448 , Reply# 29   1/28/2015 at 10:40 (3,376 days old) by bajaespuma (Connecticut)   |   | |
I have the 1961 iteration of this exact model. Yours is definitely a 1960 model and for some reason you got cup racks (that I covet) and I didn't. Does yours have the automatic cord reel?
I love my machine and got it in almost new condition. It was stored outside so there were a lot of exterior flaws (the hoses were stiff as bones and disintegrated when I pulled them up and out of the front to connect the machine to water) but the inside was pristine. The only difference that I can spot besides the lack of cup racks (that I covet) is the new-style plastic silverware basket. These machines were fantastic and I will never stop looking for the late version SU-70V that was my first dishwasher (with cup racks AND rinse dispenser). |
Post# 806499 , Reply# 30   1/28/2015 at 16:55 (3,376 days old) by Tomturbomatic (Beltsville, MD)   |   | |
Your GE has been taken over by Maytag pods! |
Post# 806506 , Reply# 31   1/28/2015 at 18:11 (3,376 days old) by bajaespuma (Connecticut)   |   | |
I thought you'd like that picture!
I have the manual for this model and I'm in the process of sending it to the twin-cities for scanning into the Ephemera library. Please be a little patient; if there's anything you need to know urgently post the question and I'm sure five of us will answer. Be aware that the Calrod heater on the bottom of the tub gets hot enough to melt and cook any plastic that happens to be in the lower rack and is within a few inches of the coil. Our melamine dishes in the early sixties survived this assault but a lot of the plastics that I use now are not as hardy. The China/Crystal cycle pretty much eliminates that danger but heats the coil for the first 5 minutes of the dry period. If your machine does indeed have the rinse dispenser as well as the cup racks, would you be so kind as to post some pictures of these features? Thank you in advance.
Post# 806584 , Reply# 32   1/29/2015 at 09:59 (3,375 days old) by jetaction (Minneapolis)   |   | |
I do have the automatic cord reel on this machine but not the rinse aid dispenser. I was surprised as full featured as it is it did not have that on it. I recall our mobil maid (mid-60's) when I was a young child and learning that nothing plastic can go anywhere near the carload element. We had some interesting shaped tupperware, one that actually melted enough to form a pour spout. Mom thought it made a great manhattan cocktail shaker as she could pour it out through the newly melted pour spout!
Post# 809056 , Reply# 33   2/13/2015 at 10:53 (3,360 days old) by cadman (Cedar Falls, IA)   |   | |
Post# 809057 , Reply# 34   2/13/2015 at 11:05 (3,360 days old) by jetaction (Minneapolis)   |   | |
Post# 809063 , Reply# 35   2/13/2015 at 11:25 (3,360 days old) by turquoisedude (.)   |   | |
