Thread Number: 58310
/ Tag: Refrigerators
Help! a few problems with "new" '53 Hotpoint fridge :( |
Post# 808233 , Reply# 1   2/8/2015 at 14:13 (3,364 days old) by mom11 (Dundee, MI)   |   | |
The 2 pics are from the craigslist ad from the seller's garage before I had cleaned or defrosted it. Sorry I don;t know how to rotate them. |
Post# 808235 , Reply# 2   2/8/2015 at 14:22 (3,364 days old) by rp2813 (Sannazay)   |   | |
The percolating sounds are normal. My '57 GE combination makes perking -- almost popping -- sounds in the freezer when it's cycling. Doesn't your '57 do likewise? Is the sound your '53 is making different? Even if it is, I'm betting it's normal.
Are you referring to the drain pan that catches the defrost water? I'd say any sort of caulking or silicone sealer would work.
The back of your '53 is where the condenser coils are located. On your '57, these coils are tucked underneath the fridge behind the front grille, and there's a fan that draws air across them for cooling purposes and blows it out the left front of the grille over the drain pan to help that water evaporate. This is called a "forced draft" system and allows for this type of fridge to be built into a snug cabinet surround if desired.
Your '53 has a passive system for cooling the condenser coils, which is very common even on modern day refrigerators that have the coils on the back, and there is no condenser fan involved (which is why your '53 has a solid toe kick plate at the bottom up front instead of a grille). This passive system requires extra room behind (and to a certain degree, above) the refrigerator, so your '53 is going to stick out more than your '57 currently does. |
Post# 808270 , Reply# 3   2/8/2015 at 18:44 (3,364 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 808427 , Reply# 5   2/9/2015 at 11:25 (3,363 days old) by rp2813 (Sannazay)   |   | |
My '57 varies in noise level, but it's generally very quiet. It seems to run even quieter when ambient temperatures are warm, like on hot days (we have no A/C). The perking sounds it makes are only heard inside the freezer while its cycling. They aren't audible with the freezer door closed.
Regardless, your '53 might be making noise as a result of having been moved and defrosted. It will likely run quietly -- even more quiet than your '57 because there's no fan running -- after it has been operating for a while.
Keep us posted! |
Post# 808440 , Reply# 7   2/9/2015 at 12:26 (3,363 days old) by rp2813 (Sannazay)   |   | |
The compressor was likely painted black to begin with. The crust could just be deteriorated paint.
The insulation probably served a purpose, so I'd put it back. As long as the fridge is cooling and not making any strange noises, let it run and see how it does. Put a glass of water in the fridge and stick a thermometer in it. Check the temp after 24 hours. |
Post# 808447 , Reply# 8   2/9/2015 at 13:55 (3,363 days old) by jamman_98 (Columbia, SC)   |   | |
Post# 808480 , Reply# 9   2/9/2015 at 16:43 (3,363 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 808505 , Reply# 10   2/9/2015 at 18:38 (3,363 days old) by rickr (.)   |   | |
The gurgle sound is the refrigerant circulating, and is no problem. The rust on the compressor looks as if the fridge may have been used in a damp basement or something, nothing to worry about. The fins on the back will get warm, and that is normal too.
We have the same model of Hotpoint in our basement, as a second fridge. Great fridge! Our power bills went down, after we got rid of the self defrosting refrigerators, and the food stays fresh longer too! |
Post# 808537 , Reply# 11   2/9/2015 at 20:50 (3,363 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 808552 , Reply# 12   2/9/2015 at 22:06 (3,363 days old) by rickr (.)   |   | |
Post# 808645 , Reply# 14   2/10/2015 at 13:34 (3,362 days old) by g3bill ( San Fernando Valley, So. Cali.)   |   | |
Usually theres an exsisting screw on the frame pretty close to attach the ground or might need a short piece of electrical wire to reach with wirenut? I use those eyelet crimp on connectors or solder it to attach with screw if the power cord ground is bare wire at end.
Fixing cracks, not sure what this plastic looks like? pics? I usually make sure its dry then place tape about 1/8" on either side of crack then flex the plastic just enough to open the crack if possible to force slow cure epoxy in the crack. But if you do it this way you will need a thin plastic piece (maybe 1/16") to bond over crack repair to insure it wont leak. Silicone is easiest or tape like mentioned but not my way if it shows. Plasic solvent works great but havent tried it on a repair, just on new clean cut plastics like when i made my freezer tray to catch defrost. |
Post# 808663 , Reply# 15   2/10/2015 at 16:49 (3,362 days old) by Goatfarmer (South Bend, home of Champions)   |   | |
