Thread Number: 58735
/ Tag: Vintage Dishwashers
Kitchenaid KDP20 noise |
Post# 813022 , Reply# 1   3/9/2015 at 09:33 (3,335 days old) by A440 ()   |   | |
It sounds like the fan above the motor is loose. It is connected to the motor shaft. Perhaps it just needs to be tightened.
Post# 813181 , Reply# 2   3/10/2015 at 01:23 (3,335 days old) by washdaddy (Baltimore)   |   | |
You may try touching base with "Stevet" and asking him for some advice. He has quite a lot of knowledge regarding Kitchen Aids and may be able to guide you on what needs to be checked. Good luck with getting your problem solved! Have a Good One! |
Post# 813223 , Reply# 3   3/10/2015 at 08:45 (3,334 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
There are several possibles causes for a sound like this, the DW may have some foreign object in the drain pump area that makes noise when draining, or it may have a squealing main shaft seal [ most likely ] or a loose cooling fan on top the main motor [ possible, but a loose fan usually makes noise on and off when ever the motor is running ].
What To Do, nothing unless the problem is really loud and irritating, For problem #2 the squealing seal, try leaving a lot more oil on your dishes and see if the problem goes away, [ you can also add a few tablespoons of BonAmi cleanser to the detergent, this will sometimes hone the main seal and eliminate the noise ]
For problem #1 take apart the pump and look for foreign objects [ if you do this have the drain impeller and main seal replaced at the same time ]
For problem #3 a loose fan you have to completely dissemble the pump and either replace the motor or in some cases we have been able to epoxy the fan back on the motor shaft The best thing to do with the old Hobart motors is to replace them with the much better Emerson motors.
