Thread Number: 58923
/ Tag: Modern Dryers
Maytag performa washer |
Post# 814959 , Reply# 1   3/20/2015 at 20:58 (3,336 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 814965 , Reply# 3   3/20/2015 at 21:47 (3,336 days old) by Kenmore71 (Minneapolis, MN)   |   | |
I'm not sure I understand the symptoms that you are describing? Does it agitate properly? If so, the transmission is fine. If the tub is moving excessively with agitation it is likely a brake issue. Has it been making loud squealing sounds at the end of spin cycles for a while? If it doesn't spin at all but pumps water out then it's either a clutch OR brake issue.
The brakes were finicky on these "Herrin" sourced Maytags. Other than that they actually worked reasonably well for a cheaply built machine. |
Post# 814966 , Reply# 4   3/20/2015 at 22:08 (3,336 days old) by wvkenmore (Wv)   |   | |
Weak agitation and about a min or two into wash cycle goes into full spin while agitating. No noises during spin the last week or so but water was not spun out as well as normal. Washer has been great no repaires till now. |
Post# 814968 , Reply# 5   3/20/2015 at 22:33 (3,336 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 814993 , Reply# 6   3/21/2015 at 08:38 (3,336 days old) by coldspot66 (Plymouth, Mass)   |   | |
Bad transmission. Sounds like a broken gear in the tranny. |
Post# 815005 , Reply# 7   3/21/2015 at 10:53 (3,336 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 815027 , Reply# 8   3/21/2015 at 14:51 (3,335 days old) by coldspot66 (Plymouth, Mass)   |   | |
Actually I misspoke. I have seen these machines agitate in the spin cycle and not get up to proper spin speed because of agitation in spin. Whatever the agitate or spin problem is, these trannys are not servicable at all. |
Post# 815032 , Reply# 9   3/21/2015 at 15:57 (3,335 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Here is some information from the service manual:
Spin During Agitation • Check for thrust bearing misalignment (Page 7-6). • Check for defective brake package (Page 7-7). • Check for misalignment of snubber
(Page 7-8).
Spin Speed Too Slow WILL THE MOTOR RUN? YES - Check for broken or slipping belt .
Check for binding tub seal (Page 7-3) .
Check for partial engagement of brake assembly (Page 7-13).
Check for obstruction between tubs (Page 5-5).
Check for proper adjustment on thrust bearing (Page 7-4).
Complete torque test (Page 7-12) . This post was last edited 03/21/2015 at 16:13 |
Post# 815039 , Reply# 10   3/21/2015 at 17:11 (3,335 days old) by mrb627 (Buford, GA)   |   | |
Post# 815041 , Reply# 11   3/21/2015 at 17:21 (3,335 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 815051 , Reply# 13   3/21/2015 at 20:11 (3,335 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
Post# 815052 , Reply# 14   3/21/2015 at 20:18 (3,335 days old) by repair-man (Pittsburgh PA)   |   | |
Performas from those years could be Newton built. I sold hundreds of them. I ask this because the original poster said that the "belts" looked good. |
Post# 815055 , Reply# 16   3/21/2015 at 20:52 (3,335 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
Post# 815059 , Reply# 17   3/21/2015 at 21:44 (3,335 days old) by Lorainfurniture (Cleveland )   |   | |
I kind of imagined some twisted marriage of a helical drive and a herrin. That sounds interesting! |
Post# 815063 , Reply# 18   3/21/2015 at 22:31 (3,335 days old) by Kenmore71 (Minneapolis, MN)   |   | |
I have the control panel off of a Performa built in Newton. LAT2500AAE serial ends in AJ = May, 2002 |
Post# 815094 , Reply# 19   3/22/2015 at 10:04 (3,335 days old) by Lorainfurniture (Cleveland )   |   | |
You know what, I might have seen that machine a few times and never noticed the performa label. Thanks for posting the pic! |
Post# 816558 , Reply# 21   3/30/2015 at 14:18 (3,326 days old) by electronicontrl (Grand Rapids, MI)   |   | |
