Thread Number: 59031
Maytag A806 very hard on clothing |
Post# 815934 , Reply# 1   3/26/2015 at 15:12 (3,318 days old) by Yogitunes (New Jersey)   |   | |
Post# 815935 , Reply# 2   3/26/2015 at 15:14 (3,318 days old) by hippiedoll ( arizona )   |   | |
I'm no expert here but,
could it be that you aren't filling the machine with enough water?? One mistake I made when I was washing a set of delicate curtains was I filled the machine to a medium sized load (because that's where the curtains reached on the agitator) and I set the washer on "DELICATE", thinking this was how I was supposed to use the "SLOW" speed to wash. Well my curtains came out partly shredded. But come to find out, when you use the "DELICATE/GENTLE" cycle, you're supposed to use the "EXTRA LARGE" load water level to get the true "GENTLE" washing action. Is this what you're doing too?? |
Post# 815936 , Reply# 3   3/26/2015 at 15:15 (3,318 days old) by wayupnorth (On a lake between Bangor and Bar Harbor, Maine)   |   | |
Post# 815938 , Reply# 4   3/26/2015 at 15:32 (3,318 days old) by nmassman44 (Brooksville Florida)   |   | |
Here's my two cents....I would check the agitator to see if you have any rough areas on the wash vanes. That can happen when one doesn't close zippers and they get down to the base of the agitator and it roughs up the edges of the vanes. Next I would look at loading. With a Maytag washer one drops the clothes in loosely and only loads to the top row of holes for a full load. Do not pack or wrap the clothes around the agitator.
I have had Maytag washers in the past...an A510, A613 and an LAT 9356 and with all those machines, never had an issue like this happening to laundry. I also never overloaded those machines either and always got great results. |
Post# 815949 , Reply# 6   3/26/2015 at 16:33 (3,318 days old) by norgeway (mocksville n c )   |   | |
Usually is too gentle if anything,I always thought their action was slow. |
Post# 815976 , Reply# 8   3/26/2015 at 18:51 (3,318 days old) by norgeway (mocksville n c )   |   | |
The clothes at the bottom are drug back and forth while the ones on top just set there... |
Post# 815979 , Reply# 10   3/26/2015 at 19:07 (3,318 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
I heard about some agitator configurations not being good to some kind of clothes, like catching and pulling in the fins, maytag fins might do that to some thin fibers and yes like large net fibers as fins are not attached to the base but are flexible to some extent, though that is something that usually happens as you overload and or underfill it..and not so likely.
Said this I always heard about maytags as well designed in this sense... pretty gentle yet effective. The sort of damage you describe sounds more like a rough tub damage than agitator, especially if you have checked it, not much about the holes but what makes me think it's rather the ends of clothes you mention which if I have understand are chewed and "grated", these are usually the tails, collars and endings or high ground sewing that are the most rigid parts on the clothes and the ones that would swish against the tub with a greater "resistance" than the softer more flixible parts (not sure if resistance is the right word to use here). I recall I've read something on a guy who tried to descale and remove rust on the machine with some kind of acid product, the guy filled it put the acid and let it sit overnight, while the acid cleaned the tub and the outter tub very well he claimed that after that his machine has never been the same and actually started to give the same kind of damage you describe, it turns out that the kind of acid he used was hydrofluoric acid which is a common rust remover ingredient, and that kind of roughened up the porcelain that is worked and meant to be smooth and not create friction with the clothes.. Porcelain, especially the one used in washing machines will stand and resist many acids, but if there is one acid that porcelain will not tolerate it's right the hydrofluoric. So I would compare your tub to the one of another similar Maytag if you have a chance, they usually are very shiney, if it's dull then maybe that's the problem..some previous owner may have done the same thing... This post was last edited 03/26/2015 at 19:41 |
Post# 815981 , Reply# 11   3/26/2015 at 19:15 (3,318 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
It appears very gentle on the top of the drum as there are no fins on the agitator post. However the turbulence at the bottom of the drum is extremely powerful despite the slow agitation. While many may not believe it these machinse are more likely to shred clothes than a DD Whirlpool.
Combine the fact that the base fins had to do all of the work in these machines and because of this the turnover was very slow resulting in clothes spending too much time in the Robot-Coupe zone it only makes sense that things would get shredded.WK78 |
Post# 815982 , Reply# 12   3/26/2015 at 19:22 (3,318 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
They never gave me the impression of being slow, as you have to imagine what happens under not judge by what you see above, and I see a good wash action down there.
The fact is that these are machine to use with clothes put really freely and with high water level in order to gurantee proper turnover. |
Post# 815998 , Reply# 14   3/26/2015 at 21:21 (3,317 days old) by d-jones (Western Pennsylvania (Pittsburgh Area))   |   | |
Since everyone is baggin' on Maytag's I'll throw in my 2 cents(that's all I can afford). My parents have been using the A806 that I went through for them since July 2012 and they've never had even the smallest issue with it. It seems to do an excellent job and the few times I've stood there and watched it work the turnover during agitation is strong. Last year we took down a bunch of white lace curtains from the windows upstairs and down at my parents house(all told more than a dozen sets) and washed them on the gentle cycle. These curtains are decades old and half of them hang in direct sunlight, so they should be a bit on the delicate side, yet they emerged from the wash clean and undamaged. Obviously it'd be foolish of me to argue with those who claim to have had a different experience and call them liars, but I can say that I haven't seen the problems being described. (knock on wood) I'm very happy with my old Maytag. |
Post# 815999 , Reply# 15   3/26/2015 at 21:33 (3,317 days old) by washerlover (The Big Island, Hawai’i)   |   | |
Wow, I am surprised to hear that a Maytag would do something like that. Being a Norge/Wards fan and owner, given their vigorous and rapid agitation, have never had anything torn apart or shredded. And the Maytags I have owned and still own have never given me trouble in that area. As stated in the previous posts, Maytags are one of the more gentle machines I have experienced. Please keep us posted..!
Post# 816000 , Reply# 16   3/26/2015 at 21:34 (3,317 days old) by norgeway (mocksville n c )   |   | |
Something hard on clothes, get a 20 pound tub Norge!!!!It is great for nasty work clothes, but boy does it really wash! |
Post# 816037 , Reply# 17   3/27/2015 at 07:26 (3,317 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
It is well documented that MT washers can be fairly hard on clothing compared to most other brands of washers built during the same time period. That said they can be successfully used without destroying your wardrobe, as millions of owners have proved.
But the fact remains that MT Automatics always had problems with fabric damage complaints from the very first automatics built, [ I worked for A MT Home Appliance store in the early 70s and our MT rep shared a lot of letters that MT got from consumers about clothing damage, it was a constant problem for MT when consumers switched to MT washers ] the agitator was simply too big for their small diameter tubs, this coupled with the long stroke and squared off fins was not a good design. MTs orignal agitator was designed for a square wringer washer tub and it worked quite well in this application.
MT never had a decent agitator in an automatic washer [ that they designed and built ] till they came out with the Load Sensor Agitator in the last helical drive machines.
Yes even a Norge 20LB washer washing along at high speed will not do the damage that a Power-Finn MT agitator will do to a load of clothing, Consumer Reports proved this years ago. |
Post# 816051 , Reply# 18   3/27/2015 at 09:20 (3,317 days old) by Yogitunes (New Jersey)   |   | |
Post# 816074 , Reply# 20   3/27/2015 at 12:57 (3,317 days old) by hippiedoll ( arizona )   |   | |
did you know what size of load you had before filling the washer??
Here's a suggestion, to try avoid damaging clothes and if you want to use borax again; put the clothes in the washer first, to see what size of load you have. Select the correct water level. Take the clothes out of the washer, and fill the machine with water and add the borax. Let the machine agitate to dissolve the powder borax, and then add the clothes back in to the washer filled with the water. This way, you'll know you have the right amount of water for the load. Just a suggestion.... I hope this helps ;o) |
Post# 816083 , Reply# 21   3/27/2015 at 14:04 (3,317 days old) by Yogitunes (New Jersey)   |   | |
I usually pull the filter out and dump the detergent and additives down the center, then replace the filter.....
this was always the suggestions of using a Maytag at a Laundromat..... note: commercial/Laundromat machines never used a lint filter, just a trim cap on top, and hollow down through the center.....yet, did anyone complain of linty clothing?... |
Post# 816087 , Reply# 22   3/27/2015 at 14:18 (3,317 days old) by murando531 (Augusta, Georgia - US)   |   | |
I can attest to the power of that Power Fin agitator. My aunt on my dad's side had a lower end A-series I believe, can't recall any actual model number because I was very young, and she replaced it with a KitchenAid similar to the one we had growing up. I remember her complaining about certain garments getting stretched in places, but I don't remember if anything tore. Her problem however is that she and all of that family of four have absolutely no care at all if things like laundry or dishwashing are done right; as far as they're concerned, if you pack the washer with clothes and dump a scoop or cap of detergent in, and the washer has run, the clothes are "clean". She would overload it every time I ever saw the machine run, and the load would slowly, but surely, roll, but with a lot of rocking back and forth. The transmission ended up giving out on the poor thing. Not sure what ended up happening to the KitchenAid either, because she hasn't had it in years, in place of the Maytag Performa with a straight vane agitator that they have now. I myself have already replaced a belt and the pump on that specific machine, and I honestly don't give it very many more years to run.
I can also attest to the Load-Sensor agitator that my Atlantis, currently powering through loads upon loads of my father-in-law's family's many clothes, and its success. I think the low-profile fins on that machine in addition to the broad spirals on the upper-agitator are what does such a good job with rollover and gentle performance. |
Post# 816088 , Reply# 23   3/27/2015 at 14:30 (3,317 days old) by floyde (Los Angeles, CA)   |   | |
I usually do put the soap in the middle of the agitator. I bought some Tide powder and wanted to see how it sudsed up as well!LOL! Christina your A806 is as old or older does the porcelain tub still have a shine or is it dull? Thanks, Floyd |
Post# 816090 , Reply# 24   3/27/2015 at 14:42 (3,317 days old) by beekeyknee (Columbia, MO)   |   | |
Post# 816097 , Reply# 25   3/27/2015 at 15:44 (3,317 days old) by DADoES (TX, U.S. of A.)   |   | |
Ran into a family friend some years ago during a haircut appt. I don't know how washers came up as a topic (maybe something was already being discussed in that area before the friend came in). Anyway, Linda said she always wanted a Maytag so bought one and it stretched her knit sweaters all to hell so she demanded the dealer take it back for something else (I don't recall what). Previous washers I know she had were a 1960s FilterFlo followed by a 1974 Whirly. |
Post# 816198 , Reply# 27   3/28/2015 at 02:24 (3,316 days old) by hippiedoll ( arizona )   |   | |
But I am definitely still in the learning stages, Roger can be witness to that. I am just not mechanically-gifted. And sometimes me & Roger get a good laugh at the questions I come up with when we're talking!
Hm hm hm... but I'm learning ;o) floyde... My 806 tub is shiney but, to be honest, there are some dull looking spots on the bottom of the tub. At first I thought it was like a dried on residue of soapy water or something. But I couldn't wipe the spots away. So im not sure what those dull-looking spots could be from? Maybe from the previous owner soaking clothes with bleach?? :o/ |
Post# 816212 , Reply# 28   3/28/2015 at 06:00 (3,316 days old) by beekeyknee (Columbia, MO)   |   | |
Christina,
We all start somewhere. I'm glad Floyde is near by to help you. I would love to share the things I've learned with others and vice versa, but Columbia is a small place comparatively. If I knew someone near by with the same interests and a good workshop I would jump at the chance to learn more. I would like to spend more time on other brands of washers as well as stoves, refrigerators, etc. I'd love to work on old Frigidaires and Kenmores. The small place in my garage isn't very satisfactory and my utility room is small so I wouldn't get to take advantage of machines I restored. Maybe some day, if I'm lucky. :) Brian p.s. The dull spots on your tub may be hard water deposits. They may come off eventually, depending on what they are. Try laying some terry cloth towels wet with vinegar over them to soak or rubbing the spots with some light cut swirl remover. Sorry, I ment Roger, not Floyd. This post was last edited 03/28/2015 at 11:12 |
Post# 816428 , Reply# 31   3/29/2015 at 14:16 (3,315 days old) by bajaespuma (Connecticut)   |   | |
Now that I've read this thread and reflected on it, to the best of my recollection, I never saw any clothing damage when we had GE machines; the edges of the Activators in our machines were very rounded and there weren't any extra "ears", fins or other protrusions to catch clothes. Also, the Bakelite was very hard and wore down very slowly. Another possible factor is that, if you've ever watched an early FF with the spiral activator do its thing, the first, hard stroke is a very short back stroke that pulls the load downward. The majority of the force is from the "body" of the activator; not so much from the three fins on the bottom.
When I first owned a Maytag, it was an orbital model with the newer version white poly agitator with lots of ridges, four little auxiliary "ears" attached to the post and sharp corners on the bottoms of the "Power Fins". After a little while I noticed holes in sheets and shirts that seemed to increase in number over a long period of time. I changed the agitator to the earlier blue Power Fin version without any ridges or protrusion which improved turnover and seemed to decrease the incidence of damage, but I noticed that the soft polypropylene nicked very easily and left sharp small tears and edges that could catch fabric. One of the things I love about the LG front loader is how gentle it is on almost every material that goes into it. Doesn't generate a lot of lint either; I imagine that was one of the general flaws of any machine with an agitator that oscillated back and forth. |
Post# 816452 , Reply# 32   3/29/2015 at 16:27 (3,315 days old) by hippiedoll ( arizona )   |   | |
Beekeyknee/brian:
For the advice about the vinegar. And yes, I am very greatful for Roger; for being so kind & for living close by & for always being willing to come over & share in my enthusiasm & help me. And I am also very greatful for all of you members here & this OUTTA SIGHT group! Tomturbomatic: For chiming in to let me know not to soak but to just wipe with vinegar & rinse immediately. I will be sure to do that. brucelucenta: For chiming in to give your insight about other washer tubs that you have seen where others have used their own concoctions other than laundry detergent & regular clothes bleach. I'm afraid I'm guilty of washing a couple of my own concocted vinegar, baking soda, bleach, and laundry detergent loads in some of my past maytag washers. :o/ But NOW, I no better!! Thank you guys for sharing your insights & experiences. :o) |
Post# 816511 , Reply# 33   3/30/2015 at 03:13 (3,314 days old) by beekeyknee (Columbia, MO)   |   | |
Well, you guys. I've never known vinegar to harm porcelain...but if you say so. What about Lemishine? Or is that too strong? I would have told her to wash clothes in softer water to see if the dullness disappears, but most people don't have a way to change the softness of their water. She could buy a water softener but those are pretty expensive. I think they're worth it but some people don't want to spend the money. She could buy a 50lb bag of STPP and wash in that for a year and see what happens. Looks like it's around $100.00 now. Personally, I'd go for the water softener. Salt is a lot cheaper than STPP. I would imagine the water's probably pretty hard in Tucson.
And by the way, porcelain tubs will loose their shine over time from rubbing, especially from metal zippers not being zipped and metal buttons, among other things. Oh, I forgot. Remember all the posts about old Maytag washers with the bakelite agitators rubbing off the porcelain around the bottom of the tubs from the vigorous action from the fins that didn't flex on those old agitators. It was just wear and tear over the years. This post was last edited 03/30/2015 at 03:29 |
Post# 816531 , Reply# 35   3/30/2015 at 09:16 (3,314 days old) by Tomturbomatic (Beltsville, MD)   |   | |
An acid on glass will definitely have the potential to injure it. I remember the use and care manual for GE ranges used to warn users to line the broiler pan with foil before marinating or cooking anything with an acidic marinade or sauce. |
Post# 816539 , Reply# 36   3/30/2015 at 10:41 (3,314 days old) by beekeyknee (Columbia, MO)   |   | |
Post# 816608 , Reply# 37   3/30/2015 at 18:23 (3,314 days old) by kb0nes (Burnsville, MN)   |   | |
Hmm not sure about the concern with acids and glass. Seems to me that with the exception of Hydroflouric acid, glass is pretty impervious. The concentrated Acetic and Hydroflouric acids I have purchased came in glass bottles. I never had any of my glass labware get etched either and that is at elevated temperatures too. Yes it was Borosilicate glass but I don't believe the addition of the boric oxide greatly alters the chemical resistance of soda lime glass. Of course porcelain may not be pure glass so perhaps there is some damage caused by long term exposure. Still low concentrations of vinegar for relatively short duration seems unlikely to cause damage.
I do know that Hydroflouric will harm porcelain in a HURRY. I learned this the hard way when I spilled a little rust remover on our old Whirlpool range top. In the second before I wiped it up I destroyed the gloss... |
Post# 816610 , Reply# 38   3/30/2015 at 18:29 (3,314 days old) by floyde (Los Angeles, CA)   |   | |
Sometimes I use vinegar in the rinse cycle on whites. Will that harm the tub? What about Arm and Hammer Washing Powder? |
Post# 816611 , Reply# 39   3/30/2015 at 18:51 (3,314 days old) by Ultramatic (New York City)   |   | |
Post# 816650 , Reply# 40   3/31/2015 at 00:03 (3,313 days old) by beekeyknee (Columbia, MO)   |   | |
You all keep talking about hydrofloric acid which are considered relatively weak acids. Hydrochloric acids, on the othe hand, are a different story (also known as muriatic acid). They are very strong and should be used in a ventilated area. They are good for cleaning mineral deposits and uric acid build-up off of old vitreous china toilet bowels and tanks and make them run like new again.
I only put the bowel and tank minus the metal parts on a piece of plywood for cleaning. The acid will eat through gravel, concrete and will kill grass. Use a toilet swab and gloves, hold your breath while applying and run away tell the fumes die down, then go back for more applications. After the parts have been cleaned, especially inside the rim and the trap, you can spray everything down with water. Anyone who's restored an old toilet already knows this. I'd never use this type of acid on porcelain, a sink or tub. It will ruin it. |
Post# 816654 , Reply# 42   3/31/2015 at 01:33 (3,313 days old) by kb0nes (Burnsville, MN)   |   | |
My apologies for continuing the off topic discussion.
Hydrochloric acid won't etch glass. It does indeed react vigorously with the calcium in concrete which is why it is a common etchant for concrete. Hydrochloric acid (and Hydrogen Chloride) are common ingredients in toilet bowl cleaners, The ZEP bowl cleaner lists concentration as 5-10% on the MSDS, so I think its safe on porcelain. Rex is right about Hydrofluoric acid, it is wicked stuff. It is more poisonous and reacts with skin more aggressively when other acids. It is a bit odd because it doesn't attack steel and other metals as aggressively as other acids. It does attack oxides and silicates, which is why it dissolves glass. Back somewhat on topic, I seriously doubt that pouring a cup of vinegar into a top load washer tub could ever cause harm to the porcelain, unless it was left there a long while. Belt buckles, zippers and clothing rivets are a different story! |
Post# 816683 , Reply# 45   3/31/2015 at 10:27 (3,313 days old) by wayupnorth (On a lake between Bangor and Bar Harbor, Maine)   |   | |
The well water at my house is extremely hard with lots of iron. Since moving in 20 years ago, I have put a little Iron Out with the fabric softner in the dispenser of my Maytag and never had a problem with any tub issues. I need to run some Iron Out thru my dishwasher again as I can see rust stains starting to form. Some idiot cleaning company used muratic acid on the showroom floor of the local Ford dealership that caused thousands in damages and the smell lingered for months.
Post# 816701 , Reply# 46   3/31/2015 at 12:20 (3,313 days old) by macboy91si (Frankfort, KY)   |   | |
I've also noticed that the Maytag tubs seemed to be very susceptible to friction wear. I've picked up several that were very dull nearer the bottom of the tub, which to me would indicate more along the lines of abrasion than anything. Either way I can't imagine a dull porcelain inner-basket with water in it damaging clothes. I'm using an early 80's Kenmore BD portable with a 1.5cf tub. I overload it but no damage to anything in over 3 months of use, and that thing has a small diameter and tall FIXED agitator fins.
But then again, as a family, we've also never had a WP/KM DD (aka. ShredMore) do any damage to anything that wasn't already on it's way out. Depending on the clothes you buy, some just don't hold up regardless of the washer you use. I've had newer (less than a year old) pants that just sort of dry-rot/tear after a while, but the weakness was with the fabrics breakdown not the washer. My roommate had this happen with some of his vegan clothing at our old house where there were 4 washers hooked up.
We may never know...
Tim |
