Thread Number: 6052
Maytag DE606 |
Post# 124417 , Reply# 2   4/25/2006 at 13:53 (6,576 days old) by toggleswitch (New York City, NY)   |   | |
Post# 124445 , Reply# 3   4/25/2006 at 15:31 (6,576 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 124805 , Reply# 5   4/27/2006 at 03:56 (6,574 days old) by sudsmaster (SF Bay Area, California)   |   | |
Maytag dryers don't have rollers in front, the drum is supposed to glide on felt or teflon pads. If the pads get worn then it will be noisy. Sounds like that's the problem with yours. Try removing the front panel and inspecting the glide pads. Replacements should be readily available from a local applaince store. |
Post# 124830 , Reply# 6   4/27/2006 at 08:02 (6,574 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 124831 , Reply# 7   4/27/2006 at 08:18 (6,574 days old) by mayken4now (Panama City, Florida)   |   | |
Whe I re-did my Halo-of-Heat, I found that the "Felt" in the front needed to be replaced. I belive that is just like Greg said, and kennygf suggested you check the bearing in the blower housing. These machines also have a lot of wiring. Be careful with the all of them, mark them and take your time. I find that taking real close up pictures of things comes back to help on re-assembly if you do not have a service manual. Steve |
Post# 124892 , Reply# 8   4/27/2006 at 11:28 (6,574 days old) by jimmyb (Texas Y’all)   |   | |
The motor belt is too loose. I am not sure if it is a bad belt as it is new or the tension spring. I will keep you posted. Thanks for the help! jimmyb |
Post# 125979 , Reply# 9   5/2/2006 at 00:45 (6,569 days old) by jimmyb (Texas Y’all)   |   | |
Seems as though taking the blower fan off and cleaning it as well as the post it sits on did it. Thanks for all of your input and help !! |
Post# 125995 , Reply# 10   5/2/2006 at 07:34 (6,569 days old) by toggleswitch (New York City, NY)   |   | |
Post# 125997 , Reply# 11   5/2/2006 at 07:48 (6,569 days old) by appnut (TX)   |   | |
Post# 126048 , Reply# 12   5/2/2006 at 17:46 (6,569 days old) by jimmyb (Texas Y’all)   |   | |
Hey man I try to post in the cleanest possible way being sure there is no way that you can twist things around (quite possibly impossible). What would we do with out you - thanks for all of the laughs :) JimmyB |
Post# 126083 , Reply# 13   5/2/2006 at 20:09 (6,568 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 126116 , Reply# 14   5/2/2006 at 22:16 (6,568 days old) by pturo (Syracuse, New York)   |   | |
I have a maytag A107 and A607 and the chrome has deteriorated in lumps and bubbles around the trim of the panels. What is the best way to restore, if you can reveal the beauty secrets? Is there chome paint? |
Post# 126270 , Reply# 15   5/3/2006 at 15:22 (6,568 days old) by goatfarmer (South Bend, home of Champions)   |   | |
