Thread Number: 60543
maytag A700 wobbles |
Post# 832031 , Reply# 1   7/12/2015 at 21:39 (3,211 days old) by d-jones (Western Pennsylvania (Pittsburgh Area))   |   | |
The service manual doesn't give you many options here. For centering all it says is to load the machine with a normal load of laundry and a full load of water, let it agitate for three to four minutes, then stop it and check for proper centering. If off center then tighten the springs as necessary to bring it back into proper alignment. Once that's done repeat the process until the tub remains centered. I hope that helps.
By the way, the service manual is available at Automatic Ephemera if you don't already have it. |
Post# 832042 , Reply# 2   7/12/2015 at 23:16 (3,210 days old) by Kenmore71 (Minneapolis, MN)   |   | |
