Thread Number: 61048
RETRO FRIDAY--Say Goodbye to Garbage! |
Post# 836685   8/14/2015 at 20:19 (3,185 days old) by bwoods ()   |   | |
See an inside view of GE's Vintage "Disposall" in action... CLICK HERE TO GO TO bwoods's LINK |
Post# 836689 , Reply# 1   8/14/2015 at 20:37 (3,185 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 836733 , Reply# 4   8/15/2015 at 05:45 (3,184 days old) by Easyspindry (Winston-Salem, NC)   |   | |
. . . of how a disposal works. I'll bet most people never think about "how" this stuff works. Thanks for sharing. Jerry Gay |
Post# 837016 , Reply# 10   8/17/2015 at 03:25 (3,182 days old) by tolivac (greenville nc)   |   | |
I also have both universal and induction GE dispsoers-GREAT machines!!! |
Post# 837076 , Reply# 11   8/17/2015 at 15:26 (3,182 days old) by Travis ()   |   | |
Post# 837143 , Reply# 15   8/17/2015 at 22:52 (3,182 days old) by Travis ()   |   | |
I think it works fine. I got all the leaves out of it today. I plugged it in and ran it and it spit out some crud. I'm not sure if I like the batch feed model. I'll hook it up though and see how it goes. |
Post# 837154 , Reply# 16   8/18/2015 at 00:46 (3,182 days old) by tolivac (greenville nc)   |   | |
Agreed-when I saw 7A on the dataplate-its an induction motor machine.Use it in good health!!! |
Post# 837212 , Reply# 18   8/18/2015 at 10:52 (3,181 days old) by Combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
GE made some good disposers over the years and also some pretty cheap ones. The only reason they made the series wound motor units was they were cheap to make and took up less space. The series wound motor units were generally only recommended for new construction as it didn't grind the waste nearly as fine as the better induction units as a result they would clog pipes if you had older plumbing in your home.
The Carboloy cutter that GE added to their induction units is probably more of an advertising gimmick then any real advantage and performance I'm sure it added a 10 or 15% advantage but that one little quarter inch square piece of Carboloy sure couldn't have done much, I have seen older GE disposers with the carboy cutter where it was worn completely smooth. The real beauty of the induction units is the little square holes punched in the grinding ring those holes never really got dual and as a result the machines continue to grind well throughout their lifetime.
Even though these GE induction disposers all were quite good I would still rate the Maytag disposers the waste King disposers and the National-Kitchenaid and the of coarse the In Sink Erator disposers as far ahead of GEs efforts. |
Post# 837362 , Reply# 21   8/19/2015 at 16:04 (3,180 days old) by Frigilux (The Minnesota Prairie)   |   | |
Post# 837366 , Reply# 22   8/19/2015 at 16:51 (3,180 days old) by bajaespuma (Connecticut)   |   | |
That's a 1960 GE set kitchen; we've all seen it before in a multitude of print ads, sometimes it's Petal Pink, sometimes it's Turquoise Green. The oven and the dishwasher (neither Princess, nor Empress, but a very fine "Custom 4-Cycle" with Plate Warmer button) are without a doubt from that year. I'd kill for one of those dishwashers.
I'd love to have a disposal unit, but my septic engineer explained to me that disposers actually do too good a job of grinding food up into small bits and those small bits don't spend any time decomposing in the septic tank but head straight to the leaching fields where they clog up the works. So now I compost which is a smelly, messy chore that I do out of the conviction that I'm doing some small good for the land around me.
BTW, I'm told that the Custom 4-Cycle in the picture below is floating around out there. If whoever has it ever wants to sell it to a good home... |
Post# 837369 , Reply# 23   8/19/2015 at 17:35 (3,180 days old) by marky_mark (From Liverpool. Now living in Palm Springs and Dublin)   |   | |
I have a friend in the UK who used to have a Waste King made in Anaheim, would be about 15 years old now I guess. Very small unit with small grinding chamber and quite noisy but high RPM (I think about 2700) and used to grind very fast. Would grind anything no problem. Then she moved to a new home with a big ISE unit that was quieter. Now she has moved again and has the TOL Insinkerator Evolution model which is very quiet and has the under cutter.
Here in Spain I have the BOL Insinkerator and it is ok but noisy and slow with Parmesan rind and also I have always found that BOL Insinkerator models struggle with lemons. They do grind lemons eventually but they sometimes get wedged. Interestingly I have never known a disposal to jam. I have also never used a batch-feed model. They are sold in the UK and Spain but I have never used one. Never seen one in the USA either.
I did once cause the mother of all clogs in a vacation rental house in Arizona. I put down a whole load of uncooked spaghetti and it did clog in the trap. So I put boiling water down -- obviously a mistake with pasta! The result, having left it overnight, was a congealed mess in the trap that resembled concrete! Pretty easy to remove the trap, then had to poke a stick through to get rid of it LOL! Other than that, I have never had a problem with clogging except I used to live in an apartment in Brighton, UK and it had a BOL Insinkerator that was installed when the place was built in 2005. This would clog constantly even with the most basic small amounts of food going down. I had to get Dyno-Rod out several times. Presumably something wrong with the plumbing. |
Post# 837371 , Reply# 24   8/19/2015 at 18:02 (3,180 days old) by jkbff (Happy Rock, ND)   |   | |
Post# 837373 , Reply# 25   8/19/2015 at 18:30 (3,180 days old) by bwoods ()   |   | |
Hopefully I can find some more good ones. |
Post# 837443 , Reply# 26   8/20/2015 at 09:11 (3,179 days old) by neptunebob (Pittsburgh, PA)   |   | |
Who makes the Evergrind brand for Menards?
The Emerson Electric Company - in other words, InSinkerAtor. Which brings up Barry, if the GE disposal is superior why is just about every disposal, at least in our area, is an Insinkerator? Could it have something to do with there being a Kenmore version? Also, ISE hypes that once the collar with the drain flange is installed on the sink, it is possible to simply screw connect in a new ISE into the old drain flange, kind of like when they dock spacecraft to the International Space Station. But I find usually by the time they need a new disposal the flange is so beat up and ratty that I end up replacing it anyway. Here's a tip: The drain flange with the snap ring with the other parts is a real pain to install under a sink, so it can help to duct tape the flange in the sink and then tape up the other parts on the underside of the sink. That way it is possible to get that pesky snap ring snapped so it can support all the parts. |
Post# 837453 , Reply# 28   8/20/2015 at 10:34 (3,179 days old) by jkbff (Happy Rock, ND)   |   | |
Post# 837457 , Reply# 29   8/20/2015 at 11:28 (3,179 days old) by neptunebob (Pittsburgh, PA)   |   | |
The evolution has more sound insulation but I think if you get the lowest price that has a stainless steel turntable inside should be good. Even the low priced one with the galvanized turntable will be ok. Disposals eventually leak in the bearings after about 10 years so you will end up replacing an evolution anyway at the time and since most people don't run a disposal for a long time (we don't)why not save any extra 100 dollars. The Evergrind is like the Badger disposals ISE makes for Home Depot, OK but not an evolution.
Post# 837466 , Reply# 30   8/20/2015 at 12:44 (3,179 days old) by jkbff (Happy Rock, ND)   |   | |
Post# 837467 , Reply# 31   8/20/2015 at 12:48 (3,179 days old) by marky_mark (From Liverpool. Now living in Palm Springs and Dublin)   |   | |
My best friend has the TOL Insinkerator Evolution 200 (known as Evolution Excel in USA) and I have the BOL Insinkerator. Is the Evolution worth it? My friend would say definitely yes. It's much quieter and seems to grind very well. She is very glad she spent the extra money.
Of course, it may not last any longer. And even if it actually breaks sooner, you could still say it's worth it because it's so much quieter and more pleasant to use.
Some people notice that the sink drains slower and food takes more of a push through the splash guard. My friend hasn't noticed this. It's also quite a large unit and will fill the space in the cabinet below.
I guess it depends on what is important to you and also what you want to pay. |
Post# 837646 , Reply# 35   8/21/2015 at 13:49 (3,178 days old) by syndets2000 (Nanjemoy, MD)   |   | |
well.....the bearings were always gone in the ones I replaced with ISE units- then there were shredder plates that always come loose.. :/ |
Post# 837731 , Reply# 39   8/22/2015 at 06:21 (3,177 days old) by tolivac (greenville nc)   |   | |
Hang onto your Maytag-as long as it still works--most of the disposers sold today are----JUNK!!!!Sadly Maytag won't be able to service your older machine.They are no longer in the disposer business.--except as ISE units with Maytag stampted on them. |
Post# 837974 , Reply# 47   8/24/2015 at 07:45 (3,175 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Were cheap, noisey and crude disposers. There is a housing development [ Calverton ] near by where Kettler Brothers built 1800 homes from 1963-1969, they all had GE kitchens with a GE disposall, the first year or so had the GE induction units after that they all had the cheap builder SW units.
Over the years I have been in at least 1/2 of these houses and replaced at least a hundred or more of these disposers personally. The usual failures were, bad bearings, motors that went electrically dead, cutters that broke off the flywheel [ very common, and if you think that these things were noisy you should have seen people trying to use them with just one cutter, the water would dance out of the sink, LOL ] and they also suffered from really flimsy attachment clips that often allowed the unit to just start to fall loose from the sink flange.
The only good thing about these GE SW was that they were the first mass produced units that were basically corrosion proof in construction, before these came around every disposer had many parts made of cast aluminum and as a result most disposer failures were caused by corrosion and leaks. Because of this these GE SW disposalls could last as long as 10-15 years for families that did not use them much and certainly did not try grinding bones and corn cobs, etc.
As Robert [ syndets2000 ] also mentioned these GE SWDs were not great at grinding food waste very finely, I have a comparison report from Maytag comparing their new disposers with all other popular brands including the better and cheap GE SW units and the difference in grind quality is huge. I also have a similar report from Whirlpool comparing their disposers with both style GE units. I also saw the CRs test where they complained of poor grinding and last but not least I have the GE service manual for their Disposalls where they recommend the SWDs primarily for NEW CONSTRUCTION, I don't make this stuff up.
Using a SWM for a disposer is a stupid idea, SWMs are great motors and work well in appliances like vacuum cleaners where they can run at near full speed and have lots of cooling air going through them. As mentioned SWMs do produce a lot of torque at a stalled condition, but doing this much plays hell on brushes, commutators and on the windings them selves especially in an appliance with NO COOLING system.
I am sure that this is one of the reasons that we replaced so many of the units that were completely dead, often the customer even told us that they tried to grind up most of a water melon etc right before it died. [ and yes we even checked to see if the over-load protector had died, we would replace the OLP if that was all that was wrong with the unit ]
I would have to put the GE SW-Dispossalls in the same class as their use of the cheap shaded pole motors in their DWs for so many years.
But after all "Profits Are GEs Most Important Product" Along with outsourcing jobs to every country possible.
Post# 838011 , Reply# 49   8/24/2015 at 11:29 (3,175 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Hi Barry, I am really enjoying this conversation about different disposer designs thanks for starting it, but you have never hurt my feelings, put me on the defensive etc, I am only presenting more information for readers of this site to consider.
There are really only two people participating on this thread that have worked on hundreds and even thousands [ Robert syndets2000 ] of home disposers, a lot of the rest is just armchair theory and feel good memories of long gone failed designs.
Please keep the personal remarks out of these discussions, thanks John. |
Post# 838085 , Reply# 54   8/24/2015 at 20:43 (3,175 days old) by Brisnat81 (Brisbane Australia)   |   | |
The problem here is more cost. A badger costs $400 plus and we paid almost $1000 for our evolution 200. We're impressed with how it performs but it's a huge amount of money when you can just throw the waste out. |
Post# 838104 , Reply# 55   8/24/2015 at 23:30 (3,175 days old) by neptunebob (Pittsburgh, PA)   |   | |
Barry, going off on a tangent, does GE even make electric motors anymore? It seems like they don't make much of anything if you believe their strange commercials. One commercial has some goofy guy speaking backwards about how they "turn problems up side which down" and then another where they talk about being a software company. Just what are they trying to tell people?
Post# 838267 , Reply# 60   8/25/2015 at 19:53 (3,174 days old) by neptunebob (Pittsburgh, PA)   |   | |
But Barry I thought GE was all full of innovations, I mean, you have the commercial about my mom works for GE and makes trees dance, and GE welcomes ideas that look like a bleached cookie monster and now they have some goofy guy who talks backward with people upside down, and how can you say GE has no innovation?
I mean this sarcastic, by the way. What is it with these commercials its not like they want us to buy anything from them? |
Post# 838270 , Reply# 61   8/25/2015 at 20:05 (3,174 days old) by bwoods ()   |   | |
That's funny, Bob. Well at least we can say their ads have innovations!!!! |
Post# 838282 , Reply# 62   8/25/2015 at 21:55 (3,174 days old) by syndets2000 (Nanjemoy, MD)   |   | |
My dad has a swm whirl a way I put pork chop bone in it Lolololol |
Post# 838289 , Reply# 63   8/26/2015 at 00:12 (3,174 days old) by bwoods ()   |   | |
When was a series wound motor used in a Whirlaway? Or are you talking about the more modern Annaheim-built "Whirlaway's". These use a permanent magnet motor. I've tested several of them. Not too good. I agree!! |
