Thread Number: 61425
1-18 washer vibration |
Post# 840895 , Reply# 1   9/12/2015 at 19:30 (3,148 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 840952 , Reply# 2   9/13/2015 at 01:03 (3,148 days old) by PhilR (Quebec Canada)   |   | |
If you try to run the machine with just water with the water level to mini on normal speed, you'll see the water gets so high on the sides of the tub that there isn't enough remaining under the agitator and the pulsator gets out of the water and makes a relatively loud noise when it hits the water on it's way down. Doesn't do exactly the same with clothes in but as Jon said, it's still not recommended to use it with a water level below "Small" on normal speed. In fact, the 1979 WEG "Elite" washer even had a feature that prevented using it on normal agitation speed if the water level selected was set below "Small".
Post# 840994 , Reply# 4   9/13/2015 at 09:42 (3,148 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 841017 , Reply# 5   9/13/2015 at 13:11 (3,147 days old) by PhilR (Quebec Canada)   |   | |
2 speed...
The 3 speed motor was discontinued just a few months before mine was made... It still has the same features as the previous 3 speed model less the "Hand Washable" option that was replaced by a second "Delicate" option. I still hope to find a 3 speed machine someday or the control panel and motor/wiring from a 1976 WIC washer to fit on mine... |
Post# 841289 , Reply# 6   9/15/2015 at 10:44 (3,145 days old) by glomain (tuscarawas cnty. (eastern ohio))   |   | |
