Thread Number: 61791
why did generation 1 duet washer use plastic for the door latch |
Post# 844405   10/5/2015 at 15:23 (3,125 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Hello to all aw members i wonder why did whirlpool generation 1 duet used plastic for the open mechanisim of the door latch if you look at the pic when i open the washer after washing one of my shirts that required bleach and the white cycle when i open the washer the latch nearly broke in my hands as you will see on the pic
Post# 844918 , Reply# 1   10/9/2015 at 05:41 (3,122 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 844945 , Reply# 2   10/9/2015 at 12:58 (3,121 days old) by brucelucenta ()   |   | |
So that you would have to replace it of course! |
Post# 844947 , Reply# 3   10/9/2015 at 13:01 (3,121 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 844962 , Reply# 4   10/9/2015 at 15:42 (3,121 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 845006 , Reply# 5   10/9/2015 at 19:34 (3,121 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
that is impossible for me to do i do not have the needed tools even if i would buy them it would cost me a fortune and like i said not even sure it is replaceable and if i did have to have that fix i would call in a tech as this is something i would never fix myself and with 11 years of use it would be good to have a tech inspect the washer because if a tech told us it would be wise to consider a replacement set we will if we have to but 1 step at a time
Post# 845020 , Reply# 6   10/9/2015 at 20:31 (3,121 days old) by Lorainfurniture (Cleveland )   |   | |
That handle is a few bucks, and comes off with a basic screwdriver. Those 2 screws in your first photo are the only ones you need to unscrew to fi it. |
Post# 845028 , Reply# 7   10/9/2015 at 21:51 (3,121 days old) by DADoES (TX, U.S. of A.)   |   | |
Yeah, two screws, appear to be torx. You're in Canada ... can't say about there but Lowe's here lists a 5-piece torx screwdriver set (T10, T15, T20, T25, T30) for $9.98.
