Thread Number: 61852
/ Tag: Vintage Dryers
Rollers for Frigidaire 1-18 Dryer |
Post# 845079   10/10/2015 at 10:16 (3,120 days old) by gregingotham (New York)   |   | |
Anyone know where I can purchase new rollers for a Frigidaire 1-18 dryer model DCD3T? Also need the felt drum seal. Any suggestions appreciated. Thanks! |
Post# 845137 , Reply# 1   10/10/2015 at 18:09 (3,120 days old) by coldspot66 (Plymouth, Mass)   |   | |
I may have some rollers and a felt seal....let me check. |
Post# 845258 , Reply# 2   10/11/2015 at 09:01 (3,119 days old) by akronman (Akron/Cleveland Ohio)   |   | |
Post# 845358 , Reply# 3   10/11/2015 at 20:03 (3,119 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Actually there is a groove cut in the roller shaft that can be filled with a high quality grease which last a lot longer than just oiling them. The problem with 1-18 dryers is the rubber often separated from the plastic wheel, the best of the 1-18 dryers had only two rollers in the rear [ the last models they built ] before that roller problems were very common. The felt seals can probably be borrowed from other dryer brands. |
Post# 845370 , Reply# 4   10/11/2015 at 22:37 (3,119 days old) by gregingotham (New York)   |   | |
for the good counsel. Coldspot- let me know what you find. I'm not doing the work myself but the guy who is said both the rollers were "shot"....so apparently it has two. |
Post# 845411 , Reply# 5   10/12/2015 at 07:37 (3,118 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
It would have a minimum of 4 and most had 5, 2 in the front and 2 or 3 in the back.
Another good thing to know about rebuilding 1-18 dryers is a MT dryer blower fits a 1-18 perfectly, and FD used the same type of cheap attachment of the blower to the motor that MT did, so if the blower shows any sign of coming loose replace it now while you are in there.
Post# 845430 , Reply# 6   10/12/2015 at 10:36 (3,118 days old) by COLDSPOT66 (Plymouth, Mass)   |   | |
I have 2 5309956509 rollers and a felt seal part # 5308950059. I have other rollers, but i think they are for the Gibson/Kelvinator style dryers, not the 1-18 dryers. |
Post# 845435 , Reply# 7   10/12/2015 at 12:09 (3,118 days old) by gregingotham (New York)   |   | |
let me know how best to contact you and hopefully we can do a deal. have someone who's waiting on the parts this week. |
