Thread Number: 61991
/ Tag: Wanted to Buy Items
Wanted: Near Perffect Matched W/D Set |
Post# 846219 , Reply# 1   10/17/2015 at 13:01 (3,113 days old) by rp2813 (Sannazay)   |   | |
If you don't need a huge tub in the washer, the build quality of vintage Maytags can't be beat. They are tanks! The tubs on Maytags ran smaller than other makes, so I would suggest you go with machines from the higher end of their model line that sport the extra large tub. You can spot them by the number of slots down the side of the agitator. The large size has three, the extra large has four, and the control panels on the extra large size have four water level selections as opposed to three.
Another good choice would be a belt driven Kenmore. I suggest Kenmore over Whirlpool because Sears commissioned machines from Whirlpool that provided a wider range in the model line and higher end models that ran more quietly than an actual Whirlpool.
Post# 846269 , Reply# 3   10/17/2015 at 17:39 (3,113 days old) by rp2813 (Sannazay)   |   | |
I think you can find well made machines into the 1990s but for a vintage look you probably want something from the '80s or earlier. The classic center dial Maytags date from the late '60s to the late '70s, but the following style was only cosmetically different with an updated brown control panel.
Kenmores with black control panels and a center dial also date back to the 1980s. In the '70s before the black panel models, the color schemes were different and loosely based on where the machine ranked in the model line.
I don't know of anyone with a pair of machines up for grabs, but I see them often enough on SF and Monterey Bay Area Craigslist. Something will turn up. |
Post# 846286 , Reply# 4   10/17/2015 at 18:26 (3,113 days old) by ibuzzard (Boulder Creek California)   |   | |
We will continue to scour Craigslist . Best Wishes, Steve. |
Post# 846287 , Reply# 5   10/17/2015 at 18:35 (3,113 days old) by ibuzzard (Boulder Creek California)   |   | |
Is it feasible to repaint these old sets, without too much trouble? I rejected an otherwise nice set because of numerous visible scratches. No rust, just scratches. When we do the remodel, we couldn't stomach having new scratched appliances... |
Post# 846290 , Reply# 6   10/17/2015 at 18:39 (3,113 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
Post# 846291 , Reply# 7   10/17/2015 at 18:40 (3,113 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 846293 , Reply# 8   10/17/2015 at 18:46 (3,113 days old) by rp2813 (Sannazay)   |   | |
Some members have had powder-coating or an automobile grade repaint done.
Keep in mind that many vintage washers had porcelain enameled top surfaces, so those would be costly to have restored.
Your best bet is to hold out for a well-maintained set, or machines that only need some cleaning. Car cleaner/polish works well on these surfaces.
Ralph |
Post# 846360 , Reply# 10   10/17/2015 at 23:06 (3,113 days old) by rp2813 (Sannazay)   |   | |
You're entering sketchy territory with older machines than, say, 1970 for your daily drivers.
Again, Whirlpool/Kenmore and Maytag used many of the same components in their drive mechanisms from the '50s into the '80s and beyond, but other parts could be tough to find.
The 806 series Maytags have lighted panels, so you may want to narrow your search to those. They have the larger tub and the most speed and temperature options.
If you want to go for something older, like from the '60s, a TOL Lady Kenmore set would have all the bling you could ever ask for.
If you're concerned about water use, the Maytags always scored as the most efficient machines in that regard per Consumer Reports, and as a result, they were also cheapest to operate. That's mostly about their tubs being smaller than those of their competitors. |
