Thread Number: 62487
/ Tag: Wringer Washers
paint chipping |
Post# 850809 , Reply# 1   11/10/2015 at 08:29 (3,090 days old) by ken (NYS)   |   | |
You painted over the porcelain which doesn't hold paint well because its so smooth. That's why its now chipping off. Was the porcelain inside the tub bad that it needed to be painted over? The porcelain itself would deal with water. That's what it was there to do originally. To get paint to stick to porcelain it has to be acid etched with a mild acid or roughed up with sandpaper first. Use a good grade primer and paint.
This post was last edited 11/10/2015 at 10:57 |
