Thread Number: 62864
newer speed queen screaming |
Post# 854112 , Reply# 2   11/28/2015 at 22:09 (3,071 days old) by Dustin92 (Jackson, MI)   |   | |
Oops.. Noticed it's only 3 months old. I'd try running another load and if that doesn't work, call for service. |
Post# 854113 , Reply# 3   11/28/2015 at 22:26 (3,071 days old) by mamapinky (blairsville pa)   |   | |
Dustin, thank you, I'll run a load in the morning, I have had the devils own luck with washers the past few months. Again Thank you...Cheryl |
Post# 854159 , Reply# 5   11/29/2015 at 09:35 (3,071 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Try running the machine through another cycle, with nothing in it if you like.
It is easy to take the washer front panel off if you like and see if the noise is coming from the water pump. It is also easy to remove the hoses from the pump [ they have screw type clamps ] but it really will not do you much good. Taking the water pump off the motor is a PITA, I do not recommend any one try it unless they have to [ it is usually easier to remove the entire motor assembly if you need to replace or service the water pump ]
The good news is that the washer is under warranty if the little part of the jacket does not dislodge itself from the pump and go down the drain. |
Post# 854173 , Reply# 7   11/29/2015 at 11:25 (3,071 days old) by Gusherb (Chicago/NWI)   |   | |
Well it makes sense you'd hear it during agitation. The pump is always running as long as the motor is on. I'd attempt to drain it down as that might flush it out. Letting it agitate will probably just make it worse. |
Post# 854188 , Reply# 8   11/29/2015 at 12:33 (3,071 days old) by mamapinky (blairsville pa)   |   | |
Thank you all.I did drain it down, but no luck in dislodging it, I'll call tomorrow for service. I hope this isn't going to be a long wait..and I really hope they will honor my warrenty and not say user error. They can't do that can they lol? Thanks Cheryl |
Post# 854237 , Reply# 10   11/29/2015 at 19:15 (3,070 days old) by Yogitunes (New Jersey)   |   | |
most service guys will work with you, especially on warranty repairs, especially if they don't note any sort of major damage/abuse....
something like this, and it could be that zipper part, they will log it in as a defective pump, and put on a replacement..... problem solved!..... I have a Fler, and over time the electric pump will get noisy , well THAT is not covered as long as it still works, so the guy just marked it down as non-functioning, and ordered a replacement...he gets paid either way.... like others have said, not worth having a disgruntled customer over something simple...... keep us posted as to how you make out.... not to be judgmental, but those under wire bras can cause havoc on pumps......can't count how many jams I had to clear from one of those.....even with a mesh bag, those things will still find their way out....I am constantly checking the pockets from the kids, preventative maintenance is what I call it....lol |
Post# 854280 , Reply# 12   11/29/2015 at 23:03 (3,070 days old) by askolover (South of Nash Vegas, TN)   |   | |
Post# 854286 , Reply# 13   11/29/2015 at 23:57 (3,070 days old) by alr2903 (TN)   |   | |
"what hook"? |
Post# 854372 , Reply# 14   11/30/2015 at 16:25 (3,070 days old) by LordKenmore (The Laundry Room)   |   | |
>I'd just request a service call for strange noises and you are afraid it will cause damage until checked out.
Agreed. I would avoid mentioning the zipper hook. Why give fuel for a fire of argument that "it's not Speed Queen's problem?" Although, personally, to a degree I'd almost argue that perhaps there is a design flaw here. I don't know much about the realities of top load design; however I think it's not unreasonable to expect incidents like this to occur. Even with care, stuff can break in the wash. And so it seems reasonable that a pump system should be designed with that thought in mind. |
Post# 854373 , Reply# 15   11/30/2015 at 16:27 (3,070 days old) by LordKenmore (The Laundry Room)   |   | |
Post# 854428 , Reply# 16   11/30/2015 at 20:27 (3,069 days old) by nmassman44 (Brooksville Florida)   |   | |
Post# 854584 , Reply# 18   12/1/2015 at 15:27 (3,069 days old) by cuffs054 (MONTICELLO, GA)   |   | |
LordK, when I first saw the thread title I thought it was about my neighbor. I'm just sayin... |
Post# 854728 , Reply# 20   12/2/2015 at 17:04 (3,068 days old) by mamapinky (blairsville pa)   |   | |
It ran thru the complete test cycle just fine so I started a load of twin size sheet set..filled up but 10 seconds into agitation the noise started again. Guess ill be keeping the service appt. Lol. Cheryl |
Post# 854814 , Reply# 21   12/3/2015 at 06:40 (3,067 days old) by mamapinky (blairsville pa)   |   | |
I will not cancel service ..I did 3 small loads last night the noise was gone on all 3 until the end of final spin on last load..so...now my question is. .my clothespin for lid lock surely won't void my warrenty will it ? Thanks everyone Cheryl |
Post# 854835 , Reply# 23   12/3/2015 at 08:58 (3,067 days old) by countryguy (Astorville, ON, Canada)   |   | |
Post# 854843 , Reply# 25   12/3/2015 at 10:15 (3,067 days old) by alr2903 (TN)   |   | |
Cheryl, I hope all is okay washer trouble at the busy holiday time and cold weather is just one more hassle. I wish you the best. Art |
Post# 854980 , Reply# 28   12/4/2015 at 09:42 (3,066 days old) by moparwash (Pittsburgh,PA )   |   | |
Post# 854982 , Reply# 29   12/4/2015 at 09:55 (3,066 days old) by runematic (southcentral pa)   |   | |
