Thread Number: 62878
/ Tag: Twin-Tub Washers
Servis Supertwin 70 |
Post# 854361 , Reply# 1   11/30/2015 at 14:17 (3,069 days old) by slowspin66 (lincoln uk)   |   | |
Hi Ian another great machine. I think i may know where there is an outer spin can. When i did the MK11 a few years ago the outer can was worse than the one on your machine. I gave it a good sort out with a drill and scraper then repainted it with grey Hamerite paint. I also did a similar process on the EE twin tub we had the resent get together. See how you get on and let me know if you still need a new part. Keep us upto date with the progress. Regards Darren
Post# 854379 , Reply# 2   11/30/2015 at 16:54 (3,069 days old) by vacbear58 (Sutton In Ashfield, East Midlands, UK)   |   | |
Post# 854568 , Reply# 3   12/1/2015 at 14:06 (3,068 days old) by triumphdolomite (Staffs(UK))   |   | |
Thanks both, I should have a bit off spare time tomorrow so I'll dig the rust out from the bottom and see if I can see any holes. Ian |
Post# 856953 , Reply# 5   12/16/2015 at 17:09 (3,053 days old) by supermaticjames (Donegal, Ireland)   |   | |
Hi Ian, Unless there were minor changes made between the Mk70 and the Mk100 then the knobs should just pull off with a bit of wiggling - they did on my Mk100. Maybe someone stuck it on with super glue? Good luck with the restoration! Regards, James |
