Thread Number: 62916  /  Tag: Modern Dishwashers
Bosch dishwasher motor jammed
Post# 854706   12/2/2015 at 13:13 (3,067 days old) by HotpointWMA64 (North Yorkshire)
Hi everyone,
Just bought a Bosch sgs3042gb/03 dishwasher (not a fire affected model) and it is absolutely immaculate.
Was built around 2002ish, used by an old lady and replaced in 2004 when the new owners of the house put in an integrated one. Hardly any use- but 10 years of sitting doing nothing.
Come to plug it in at my girlfriends house and it fills as normal but when the water should be pumped around the dishwasher it just humms... I have been told this is the siezed motor shaft on the water seal, common problem apparently but I don't work on dishwashers a lot so not too sure.
My question is... Does anyone know how to get to it? If I remember rightly there's just a bottom access panel underneath that unscrews and you can get to it like that but I am just wanting to clarify this.
Regards, George
Post# 854883 , Reply# 1   12/3/2015 at 16:34 (3,066 days old) by HotpointWMA64 (North Yorkshire)
Update...
I unjammed the motor and now it works very well and very quiet... Not as big a job as I thought actually!
....well.... When I say very well, there's one more problem- it doesn't use as much water as it should.
I have to manually top up the water cause the inlet valve shuts off far too quickly, barely filling the filter area properly.
My thinking is that the pressure chamber has a bit of a blockage as its been stood for so many years and the debris could have gone all hard in it.
What do you guys all think to this? Should I whip the left panel off and take the chamber off and give it a clean out or does this sound like a different problem? Also is it easy to remove the pressure chamber?
Thank you in advance for any much appreciated help!!
George
