Thread Number: 63374
1950 Plymouth |
Post# 859556   1/2/2016 at 00:19 (3,051 days old) by Stan (Napa CA)   |   | |
This has been a daily driver for some years, (not to far, or passed 55mph) and I've been nursing a clutch for a long time
(slips in third gear when climing) Without warning (no noise) she decided not to let me shift into second gear.. I coasted to the side of the road with clutch in with shift in neutral position. When I came to a stop, I let up on the clutch (shift still in neutral) felt as though she was moving but like from second? Weird! While still stopped, I shifted to first, and let up on clutch, felt as though she want to go but that something was stoping the rear wheels from turning. Now gear shift is stuck in first gear position. The really weird thing is that while the clutch is in, she can't be pushed, rear wheels won't move. But also seems to start with clutch in with out learching forward?? Tried rocking it back and forth, tried crawling under to see if I could get shifter pins loose or something but it's cold greasy and I'm not up to a chalange right now. So called a tow truck (had to be towed from the front) to the mechanic. He'll take a look Tuesday. Any ideas as to this very strange incident. Could it be as simple as a shifter linkage? Or loosing a cotter pin? Or ..
Post# 859558 , Reply# 1   1/2/2016 at 00:39 (3,051 days old) by ea56 (Cotati, Calif.)   |   | |
Maybe the clutch linkage broke? I used to have a 71' Maverick with 3 on the tree. Back in 1983 I was in Santa Rosa and stopped at a red light with the clutch in. When the light turned green I let up on the clutch , but it stayed on the floor. I didn't know what to do so I just pressed down on the acelerator and the car moved forward in 1st gear. So when the engine sounded like it was time to shift to 2nd I made the shift, without the clutch! Surprisingly, I was able to drive all the way home to Petaluma this way, about 18 miles, shifting through all three gears as needed! And believe it or not the gears barely even had any grinding noise. The next day I drove to my mechanic and had the linkage repaired. He told me that since I knew how to shift at the right engine speed, thats why I was able to drive home without the clutch. I will say that it sure seemed strange to drive like this without using the clutch, but I guess necessity is the Mother of invention. And thankfully, my little Maverick was no worse for the wear.
Eddie This post was last edited 01/02/2016 at 01:14 |
Post# 859560 , Reply# 2   1/2/2016 at 01:01 (3,051 days old) by rp2813 (Sannazay)   |   | |
I can't say it's exactly the same, but it sounds a lot like what happened to Dave in the '50 GMC once. The Jimmy has a column shift, and I presume the Plymouth does as well.
I don't know what Dave did, but the linkage was jammed up like typewriter keys and wouldn't even budge when I attempted to manipulate the column-to-transmission connecting rods by hand under the hood (something that has always quickly cleared similar but less severe trouble in the past).
The truck had to be towed, but it indeed turned out to be nothing more than the linkage that needed to be freed up. The mechanic gave Dave a lesson in how the transmission wanted to be shifted. I used to cringe whenever he was behind the wheel of the Jimmy because of the way he murdered the entire drive train. I've been driving that truck since 1971 and when I'm behind the wheel it's like an extension of myself.
I'm not sure what to make of the Plymouth starting but also not budging with the clutch disengaged, but it makes me think the clutch is not the problem. I think you're on the right track and should for sure check the linkage to see if it has gotten sloppy or a component has failed. I hope it's an easy fix like you're thinking it might be. Keep us posted.
Ralph |
Post# 859594 , Reply# 3   1/2/2016 at 09:06 (3,051 days old) by mayken4now (Panama City, Florida)   |   | |
Post# 859604 , Reply# 4   1/2/2016 at 09:40 (3,051 days old) by sudsmaster (SF Bay Area, California)   |   | |
Post# 859633 , Reply# 5   1/2/2016 at 13:25 (3,051 days old) by wayupnorth (On a lake between Bangor and Bar Harbor, Maine)   |   | |
We had a 51 Plymouth as a second car for years. I remember the clutch and brake pedals went thru the floor, under the car and the transmission was not a synchromesh, as you had to be at a complete stop to shift into first without gears grinding. Most annoying thing about the car was single speed wipers (think extra slow). I dont believe that engine could power the car over 55 mph.
Post# 859648 , Reply# 6   1/2/2016 at 16:12 (3,051 days old) by Supersuds (Knoxville, Tenn.)   |   | |
Plymouths, like all cars of that era, had synchomesh on second and third but not first. The theory was that you wouldn't need to shift to first unless you were at a complete stop. After 1940, IIRC, Plymouth's second gear ratio was 1.83 to 1, and a lot of people just started in second all the time anyway.
Ford brought out an all-synchro 3 speed in 1963 or thereabouts, and even sold them to GM. |
Post# 859650 , Reply# 7   1/2/2016 at 17:01 (3,051 days old) by LordKenmore (The Laundry Room)   |   | |
Nice Plymouth! I love the color.
A high school classmate had a Plymouth from IIRC the early 1950s. He loved that car, and claimed that someone once smashed into him at a stop sign. The Plymouth emerged pretty much unscathed. The other car, however, suffered significant damage. Other memory: Chrysler at that time had a special key with IIRC a crystal-like Chrysler emblem. My classmate swore the key would probably work on his car, and thought seriously of getting that modern key blank cut for his car. |
Post# 859656 , Reply# 8   1/2/2016 at 17:40 (3,051 days old) by Artcurus (Odessa)   |   | |
Nahh, but that Pontiac behind it would be a nice score also. |
Post# 859661 , Reply# 9   1/2/2016 at 18:19 (3,051 days old) by Stan (Napa CA)   |   | |
No news yet as it sits at the mechanic til Tuesday.
Seized up parking brake is what it feels like, however, while driving a moment before this happened, it didn't want to shift into second, and I didn't want to force it, so coasted to the side of the road in neutral with clutch in. None of it makes sense to me. No noise, no grinding, no warning! @John.. The color is what Plymouth called Channel Green. Syncro on second, but I don't use it much. @Tim.. Engine will power passed 55mph but I've never felt comfortable traveling at that speed in it. No updated brakes ect. Wipers do have more than one speed, but if the vacuum motor is worn, or if there a small leak, then you just get slow. While in third gear, if there is sudden acceleration, the wipers will momentarily stop or slow. (Normal) I've changed wiper motor on it once, kind of a PITA I took the cowl vent out to access it to avoid laying in my back It's a quirky old thing |
Post# 859668 , Reply# 10   1/2/2016 at 18:49 (3,051 days old) by wayupnorth (On a lake between Bangor and Bar Harbor, Maine)   |   | |
Stan, My parents 51 Plymouth had electric wipers with the on-off switch right in the top middle center hard metal dashboard of the 2 piece windshield and they were super slow. I remember my father saying, look, we have a new car as it rolled over 100,000 miles to 0 but it was still the same old car and he eventually sold it for $75. My mother hated that car because it was a standard and no power steering. Mother drove the nice station wagon.
Post# 859675 , Reply# 11   1/2/2016 at 19:56 (3,051 days old) by sudsmaster (SF Bay Area, California)   |   | |
I actually have two 1950 Plymouth four door sedans. One runs and ready to go at any time. The other one was bought with a frozen motor and is basically a donor car, although the body is very straight with little rust.
I have on occasion driven off with the parking brake lightly engaged, only to find that as it heats up it will very suddenly bring the car to a screeching halt. It works by compressing an asbestos cloth lined steel band around a drum on the driveshaft. at the rear of the transmission.
I actually tore down and rebuilt a spare '50 Plymouth transmission in a manual transmission class about five years ago. These are very simple transmissions, and relatively easy to take apart and put back together. I suppose something internal could have busted preventing proper shifting, in addition to problems with the external linkage.
I assuming you keep it topped up with gear oil...
Never had any problems with it that I could trace to the external linkage, though. Shifting into reverse can be a little balky, probably the reverse gear has some chewed up teeth, which is common in an older manual. There is only one synchro ring in these trannies, aiding the downshift from third to second. No synchro is needed to shift from 1st to second, as I recall. And yes, the car can start on a level surface in second, no problem. 1st is very low but helpful for very steep hills. In which case it's usually advisable to shift into 1st before entering the grade. LOL.
As far as top speed goes, these engines redline at 3600 rpm, which translates to about 65 mph. However I do try to keep it under 60 on the freeway. The cars themselves handle relatively well considering their era, but the skinny rims and stock tires do limit cornering. The steering box is relatively low effort with lots of turns and a wide diameter steering wheel.
One can probably find a replacement used transmission at a vintage car wrecker, or on eBay. They are easy to pull and replace, if you have a transmission jack.
The runner 50 has a vacuum wiper system and a vacuum booster pump running off the same cam that powers the fuel pump. It is infinitely adjustable in speed, although usually a slow speed is preferred as it can go nuts when compression braking downhill. I find vacuum wipers to be highly entertaining. |
Post# 859676 , Reply# 12   1/2/2016 at 20:23 (3,051 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
It's pretty, Stan. I remember counting cars that were of this era, on Coolidge Hwy, in my home town, when traffic in the early 60's was so light, you had to wait a long time to get a string of seven cars. Your car brings back a lot of different memories, of the men and times that drove these. Hope it isn't a big cost or you can find a reasonable solution to repair it.
Phil |
Post# 859696 , Reply# 13   1/2/2016 at 22:24 (3,050 days old) by rp2813 (Sannazay)   |   | |
Post# 859706 , Reply# 14   1/2/2016 at 23:31 (3,050 days old) by Stan (Napa CA)   |   | |
Post# 859709 , Reply# 15   1/3/2016 at 00:10 (3,050 days old) by sudsmaster (SF Bay Area, California)   |   | |
Well, unless you've noticed a major gear oil stain under the car, I'm guessing it's probably OK, but it doesn't hurt to check.
Come to think of it, I haven't checked mine for probably about five years now. At least.
And no, while I used to drive it daily, back in the 90's, I decided around 2003 to give it a rest and drive it maybe 3-4 times a year, to car shows or just to limber her up. Doesn't seem to hurt, but I do keep it garaged. Most recent repair has been to starter solenoid, which on this vehicle is conveniently located bolted to the side of the engine compartment just above the driver side wheel well. Near the battery. The old one, probably the one that came with the car in 1950, was sticking in the ON position, so it wouldn't stop spinning the starter even after the ignition key was turned to on instead of start. Revving the motor usually would flick the starter off, but I don't like revving a cold motor. A whack with a hammer worked to, but that was a temporary measure. Found a serviceable new one online for about $25 and it works fine. Just doesn't look as ancient as the original (bakelite bottom case instead of all metal case).
These old cars are sort of hard to kill. The motors are simple, low compression, low HP (98) very torquey, etc. They will run with scored cylinders (don't ask), burnt valves, etc. Probably would run on diesel as well. It's a basic motor design that Chrysler debuted in 1924. Downsized for the Plymouth around 1930 and gradually updated. The motor stayed in production cars until the late 1950's when the slant-six came along, and was still produced and used in various industrial settings like fork lifts for decades more.
The one aspect that is annoying is getting a smooth clutch release. The "Floating Power" feature lets the motor rock too much and then the clutch grabs and shudders. If the FP motor mounts are tightened up the shuddering is reduced or goes away, but then there is too much motor vibration transmitted to the frame. I've tried all sorts of mount settings, nothing really resolves the problem. Talked to other owners with the same experience. I know it's not me because the '67 Chevy Van with MT has silkly smooth (well, sort of) clutch engagement. I even tried replacing the clutch and resurfaced flywheel (twice), no luck. It's got a 10 inch clutch in it now, so it never slips.
Sometimes starting in second is the answer. It's enough to make one want a fluid clutch, until one remembers how much power those things sapped.
Post# 859712 , Reply# 16   1/3/2016 at 00:39 (3,050 days old) by Stan (Napa CA)   |   | |
I've never noticed a shutter..
Still have original solenoid, no problems (yet) I do get some vibration at highway speed's but thought it may be U Joint ware ect, but now you got me thinking. The only oil leak I've got is a rear main seal (dribble) that's been leaking for years. Something I thought would best be changed when the clutch went out. Just didn't want that all to be now! Temp gage went out last summer (worn or broken tube) Another "lay on ur back" under the dash job. |
Post# 859715 , Reply# 17   1/3/2016 at 01:01 (3,050 days old) by rp2813 (Sannazay)   |   | |
The transmission on the GMC had a drip from the filler plug for quite a while, but not to the point of leaving obvious evidence on the driveway. I'd just notice it when I was under the truck for other reasons.
For years, after sitting at a red light in neutral with the clutch disengaged, when the light turned green and I'd depress the clutch I'd get grinding that would wind down over a period of five or ten seconds as I attempted to engage first gear. I got used to it and knew to anticipate it.
Then a year or two ago the transmission was getting noisy and it sounded like an old milk truck. I decided to check the gear oil level and add some if necessary. It took well over a pint!
The milk truck noise was gone and the grinding issue cleared up too. Now the light turns green and off we (relatively) quietly go. I made sure the filler plug was good and tight when I replaced it.
It's worth topping off the gear oil before investigating the linkage. |
Post# 859719 , Reply# 19   1/3/2016 at 01:26 (3,050 days old) by Stan (Napa CA)   |   | |
Post# 859755 , Reply# 20   1/3/2016 at 09:55 (3,050 days old) by sudsmaster (SF Bay Area, California)   |   | |
Post# 859824 , Reply# 22   1/3/2016 at 16:00 (3,050 days old) by LordKenmore (The Laundry Room)   |   | |
>As I recall on long trips I have averaged about 20 mpg in the four door '50 Plymouth.
Doesn't seem that bad all things considered. I've had newer 4 cylinder cars that barely got maybe mid 20s MPG range. Yesterday, I rode in someone's Subaru, which was getting about 21 MPG on a trip that was mostly highway. Another thought--and correct me if I'm wrong--but it seems like gas quality would be less of an issue in an old Plymouth. I know I've heard lots of strong suggestions over the years to use Chevron or other high cost gas due to additives that help keep fuel injectors clean. But you don't have fuel injectors to worry about on that old Plymouth. As long as the gas isn't liquid sludge, it SEEMS like anything should be fine. |
Post# 859835 , Reply# 24   1/3/2016 at 16:49 (3,050 days old) by LordKenmore (The Laundry Room)   |   | |
> it cruised nicely at 65 or 70 with no strain at all
Never drove a car of that vintage. But I did have a small 4 cylinder Japanese car made ca. 1980. Acceleration was horrible, but had absolutely no problem cruising at 70+. Not bad when one considers it dated to an era when 55 was the top speed in the US, gas economy was a huge concern, etc. I have no idea what the top speed was. But I can say that when Montana had no speed limit, I hit a speed above what the speedometer could measure in one of the flat parts of that state. |
Post# 859836 , Reply# 25   1/3/2016 at 16:52 (3,050 days old) by LordKenmore (The Laundry Room)   |   | |
>I got in a race once with a guy in a v8 40 Ford, I stayed ahead of him up to about 75, the Ford would do just under 100 in those days, the Plymouth about 90.
I can't remember for sure, and correct me if I'm wrong... But I have a sense that I might have read that 6 cylinder Fords of some vintage (I'm thinking ca. 1950) actually had better acceleration than the V8 at lower speeds. |
Post# 859840 , Reply# 26   1/3/2016 at 16:58 (3,050 days old) by rp2813 (Sannazay)   |   | |
I've had the GMC up to 65, but I don't feel safe going that fast with it on crowded area freeways -- or even empty ones, plus it gets pretty loud in the cab. It seems to have a sweet spot at around 57, so that's where I tend to top out, and I always keep to the far right lane.
So Stan, what happened to that (flowering cherry?) tree? Did it get struck by lightning or something? |
Post# 859842 , Reply# 27   1/3/2016 at 17:07 (3,050 days old) by ea56 (Cotati, Calif.)   |   | |
I'm pretty sure that I've read this too about the 49 to 52 Ford 6's having better low end acceleration than the V-8's in Hemmings Classic Car. I believe that this was due to the 6's having higher low end torque. These older American cars were really a lot of fun to drive and still are, if you're lucky enough to have one. And the 3 spd. column shifts were so easy to drive, provided that the linkage was in good working order. Really very little shifting in most normal driving. I guess I'm just behind the times, but I really am not interested in having a car with a 6 spd. manual. Why would you want to have to shift so much?
Anyway, I sure do appreciate Stan's 50 Plymouth. We had a few of them in my family in the 50's and early 60's and I remember well riding in them. The floors in the backseat were so big that we kid's would play board games and color on the floor while on long drives. Eddie |
Post# 859844 , Reply# 28   1/3/2016 at 17:13 (3,050 days old) by sudsmaster (SF Bay Area, California)   |   | |
My second engine rebuilder was rather adamant that I not drive the car above 55. He said the motor was never designed for sustained top speeds, and the bearings and rings would wear out quickly if pushed to the limit. I had top components installed the second time around... forged pistons, tri-metal main bearings. And relatively tight tolerances. It doesn't burn any oil after 20 years, so there is that.
The larger Dodge/Desoto/Chrysler 230 and larger flathead sixes can be longer lived, mainly because there's more room in the block to space the cylinders with more meat around them. The 218 block was shortened and hence the cylinders are rather closely packed. This limits the amount of overbore that can be done, and also affects cooling.
Plymouth was the entry level car for Chrysler Corp. It is a good car but certain economies were taken in production. Oddly, it was their smallest car but even the smallest 50 Plymouth today would count as a full-size car.
The rear main seal will always seep a bit. The secret to a less leaky one is to avoid the rubber seals and only use a rope type seal. It won't seal as tightly to begin with but it also won't deteriorate quickly from heat and age like the rubber ones will. And besides, the engine breather tube exits under the chassis, keeping the road oiled anyway.
Post# 859849 , Reply# 29   1/3/2016 at 17:44 (3,050 days old) by LordKenmore (The Laundry Room)   |   | |
I've only had 5 speeds, but I don't find the shifting too bad. Mainly, I guess, it all takes place about the same time when accelerating, so what's an extra shift or two? Living with a modern 4 speed (used in economy cars) might be more annoying. I had one years back, and it seemed like there were moments when no gear seemed quite right... And I remember looking once at a Toyota truck that had a 4 speed, and wasn't selling. Apparently it was the lack of a 5 speed that was causing it to linger and linger. |
Post# 859863 , Reply# 30   1/3/2016 at 18:39 (3,050 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
Post# 859905 , Reply# 31   1/4/2016 at 01:07 (3,049 days old) by Stan (Napa CA)   |   | |
got me thinking.. Aside from the shifter being stuck, the fact that while the car seamed to be in gear, when I let up on the clutch I felt something was holding the rear wheels. So I paid a visit today to where the Plymouth sits and waits for the mechanic.
I knew the e brake wasn't pulled, but when Rich mentioned the e brake, I had to explore. First thing I did was to gently pull the brake to see if I felt or heard heard anything. Sure enough something feels off. (Thanks Rich) I started her up and reached for the gear shift and was surprised to find it wasn't stuck anymore? (possible vibration from the tow ride) So I backed her up a drove her around the block, I was afraid to use first gear for my test, so just started in second. When I got close to turning into where it was parked at the mechanic, I was brave enough to use flrst, second, and third. Shifting seems slightly off somehow? Without crawling under the car..I'm convinced that somethings up with the e brake, and the shift linkage. At any rate at least I know that the clutch and transmission is operating! And I will direct the mechanic to the e brake first, then on to the two shifter arms. One of them may have a pin loose or something. I'm just to pretty too crawl under greasy old cars anymore! Good to know about the rope type seal Rich, I have one in a box somewhere. P.S..you boys may find this funny, but when I called for the tow, I had to spell PLYMOUTH to the person who took the call! LOL Forgive me Ralph.. What Tree? |
Post# 859910 , Reply# 32   1/4/2016 at 01:37 (3,049 days old) by Supersuds (Knoxville, Tenn.)   |   | |
Had to spell Plymouth, but he would have been unfazed by Hyundai, sigh.
Looks like your're onto something with that wacky driveshaft brake! About top speeds, keep in mind that cars of this era were pulling wildly low rear axle ratios, like 4.27 to 1 or even 4.54 to 1, so the engines would really be revving even high gear. An overdrive is a useful addition, though I'm not sure if Plymouth offered them from the factory. Chryslers often had them. |
Post# 859912 , Reply# 33   1/4/2016 at 01:44 (3,049 days old) by rp2813 (Sannazay)   |   | |
Gee, it's not like the last Plymouth was produced in 1950. Plymouth doesn't make smart phones. If they did, that person would have known how to spell it.
I'm glad this is looking like it's not transmission related. The linkage and E-brake are relatively simple and inexpensive repairs.
Stan, it's the tree in the photo of your car above, in the foreground parking strip. It looks like half the trunk of it (the tree, not the Plymouth) is missing. |
Post# 859915 , Reply# 34   1/4/2016 at 01:57 (3,049 days old) by Stan (Napa CA)   |   | |
Post# 860535 , Reply# 39   1/7/2016 at 08:11 (3,046 days old) by mayken4now (Panama City, Florida)   |   | |
Post# 860592 , Reply# 40   1/7/2016 at 15:44 (3,046 days old) by cuffs054 (MONTICELLO, GA)   |   | |
The suspense is killing me! |
Post# 860604 , Reply# 41   1/7/2016 at 17:05 (3,046 days old) by rp2813 (Sannazay)   |   | |
Post# 860660 , Reply# 42   1/8/2016 at 00:59 (3,045 days old) by Stan (Napa CA)   |   | |
Ralph!
Haven't heard anything. The shop is around the corner from work, and my brother hangs out there sometimes (we've known these mechanics for years) I asked my brother to let me know if he sees it up on the rack...if that happens, I'll to take a look for myself. This is if I've got time and I've got time to walk over.. If it works out that way, I'll take pics to share More to come with the old Plymouth (hope it just old worn linkage) |
Post# 860676 , Reply# 43   1/8/2016 at 08:28 (3,045 days old) by miele_ge (Danbury, Connecticut)   |   | |
Post# 860749 , Reply# 44   1/8/2016 at 19:52 (3,045 days old) by stan (Napa CA)   |   | |
Post# 860757 , Reply# 45   1/8/2016 at 20:33 (3,045 days old) by Supersuds (Knoxville, Tenn.)   |   | |
I did a little research and it appears Plymouth didn't offer overdrive until 1952, for some reason. Chevy didn't have overdrive until 1955, because they used a torque tube drive before then and adding an overdrive unit would have been too complicated, apparently.
How is your 1973 Oldsmobile ragtop, Stan? |
Post# 860768 , Reply# 46   1/8/2016 at 22:12 (3,044 days old) by Stan (Napa CA)   |   | |
Post# 860905 , Reply# 47   1/9/2016 at 16:37 (3,044 days old) by cuffs054 (MONTICELLO, GA)   |   | |
Hold up there missy! Stan how about a pix with the crew? I don't think you would like bad in any hair style! |
Post# 860926 , Reply# 48   1/9/2016 at 18:24 (3,044 days old) by wayupnorth (On a lake between Bangor and Bar Harbor, Maine)   |   | |
I know what you mean Stan about frigging with old cars. I have a 35 year old Corvette that has been in storage for 12 years because I dont want to mess with replacing brakes and valve cover gaskets to put it back on the road. I would love to sell it and get it over with too. But I am not giving it away with only 49,000 miles. I always thought that he who dies with the most toys is the winner. Naaaa, I am too old to play with these toys any more.
Post# 860983 , Reply# 49   1/10/2016 at 02:21 (3,043 days old) by Stan (Napa CA)   |   | |
"Plymouth didn't offer overdrive til 52"
I've read that too, but Chrystler offered it in the 30s on DeSoto? From what I've read, and seen.. It's possible to add a overdrive to the 50, but seems complicated, or at least takes some imagination. Tim..have you got pic to share of your Corvette? Are you going to have to do the work so you can sell it? These old cars can be daunting at times, but I've always figured that I'm just the caretaker of these old girls...at least til it's time to pass them on to the next guy that will keep them alive, or better take them further. I'm torn! ...I'm glad the Plymouth is with the mechanic, but I'm annoyed at myself for not making more of a effort to fix it myself. I'd really like to be under it when he's got it up on the hoist with a drop light on it! Guess I'd bitch if I was hung with a new rope! LOL |
Post# 861021 , Reply# 50   1/10/2016 at 10:37 (3,043 days old) by wayupnorth (On a lake between Bangor and Bar Harbor, Maine)   |   | |
Hi Stan, here is my 1981 Corvette. I would prefer to just sell it as is where is.
Post# 861069 , Reply# 51   1/10/2016 at 16:44 (3,043 days old) by Supersuds (Knoxville, Tenn.)   |   | |
It may not be that bad according to this source.
"Overdrive proved popular enough that Plymouth offered it as a complete service package to be installed in the field on P22 and P23 series cars. Net dealer price, which included the overdrive and mainshaft assembly, clutch disc, hand brake drum, wiring harness, and necessary controls was $142.25. First shipments of the kit were not scheduled until mid-May 1952. For owners of earlier Plymouths, the unit was virtually a bolt-in swap for cars dating back to 1940. As early as 1940, Plymouth had used a long tailshaft assembly on their transmissions. Removing this tailshaft allowed the overdrive unit to slip into its place, allowing the original drive shaft to be used." CLICK HERE TO GO TO Supersuds's LINK |
Post# 861278 , Reply# 52   1/11/2016 at 19:48 (3,042 days old) by mopar65 (Almont MI)   |   | |
Post# 861373 , Reply# 53   1/12/2016 at 09:34 (3,041 days old) by Supersuds (Knoxville, Tenn.)   |   | |
Post# 863183 , Reply# 55   1/20/2016 at 23:37 (3,032 days old) by Stan (Napa CA)   |   | |
Post# 863185 , Reply# 56   1/20/2016 at 23:41 (3,032 days old) by rp2813 (Sannazay)   |   | |
Post# 863226 , Reply# 57   1/21/2016 at 07:39 (3,032 days old) by mayken4now (Panama City, Florida)   |   | |
Good Story Stan. Didn't I say the linkage from the get go? They failed on all sorts of makes and models due to the nature of usage and being constantly moving while shifting. It can leave you with the impression (unexplainable) that there is a major issue going on.
Glad you have your car back home and all is well.
--Steven |
Post# 863995 , Reply# 58   1/25/2016 at 12:47 (3,028 days old) by stan (Napa CA)   |   | |
You did Steven! Thank you.
At first, I questioned if it was something that simple. On the side of the road.. Couldn't see the worn bushing, just wanted to get it unstuck! (I wasn't going to get that to happen) I have some slight apprehension about the repair that was done.. While driving down the highway, I heard a snap, and found that it jumped out of gear (into neutral) Hasn't done it since, but... |
Post# 864010 , Reply# 59   1/25/2016 at 14:38 (3,028 days old) by rp2813 (Sannazay)   |   | |
Post# 864740 , Reply# 61   1/29/2016 at 22:18 (3,023 days old) by sudsmaster (SF Bay Area, California)   |   | |
There is probably a procedure for dialing in the linkage setting so they don't pop out of gear or clash. It would be in your service manual, which you have, of course!
And here is a link to a wholesale closeout of various 1950 Plymouth parts:
www.rockauto.com/RSS/vehiclefeeds...
CLICK HERE TO GO TO sudsmaster's LINK |
Post# 866998 , Reply# 62   2/13/2016 at 14:34 (3,009 days old) by Stan (Napa CA)   |   | |
I have the service manual (with my greasy fingerprints on it) LOL.
No more issues with it popping out of gear...however now it's making a noise that I fear is a transmission bearing.. On my last nerve with this old girl, so she's going to sit for a while. If I find that it's a overhaul, then I'm done. I'll put her up for adoption! Losing my patience with old cars. |
Post# 867002 , Reply# 63   2/13/2016 at 15:13 (3,009 days old) by Supersuds (Knoxville, Tenn.)   |   | |
Post# 867012 , Reply# 64   2/13/2016 at 16:15 (3,009 days old) by sudsmaster (SF Bay Area, California)   |   | |
Like I said, these transmissions are very simple affairs and not rocket science to rebuild. The bearings are likely standard and readily available off the shelf or online. That is, if the noise is actually a transmission bearing and not dragging brakes.
However the idea that old cars last forever is a myth. They were designed when labor was cheaper than advanced materials so they typically require much more maintenance than newer cars. Softer alloys, less durable rubber, more primitive lubricants, etc. So we tend not to drive them as often or as far or as fast as new cars, and save them for special days.
Post# 883893 , Reply# 65   6/8/2016 at 03:23 (2,893 days old) by Stan (Napa CA)   |   | |
This old girl has sat a while and I'm ready to deal with this noise. It sounds like something in the driveline. Almost like a dried out u joint? Im going to get greasy.. get under her and see what I can see. If I get it up on blocks maybe turn by hand I'll hear this noise and hear exactly where it's coming from.
@cuffs I'll be wearing a dew rag for this, so your going to get your wish, a dirty hairy greasy man under a car! LOL |
Post# 883961 , Reply# 66   6/8/2016 at 12:12 (2,893 days old) by rp2813 (Sannazay)   |   | |
After that visual, if I were within closer range I'd be happy to assist. I could use a change of scenery after dealing with the brakes on the Jimmy without the desired outcome, and I have successful experience with a Rambler driveshaft under my belt.
Those among us who know me know just how I mean that . . .
Post# 884070 , Reply# 67   6/8/2016 at 22:37 (2,892 days old) by askolover (South of Nash Vegas, TN)   |   | |
Post# 884088 , Reply# 68   6/9/2016 at 02:05 (2,892 days old) by sudsmaster (SF Bay Area, California)   |   | |
The '50 Plymouth, unless changed out, has ball and trunion U-joints fore and aft, also called Detroit U-joints. These can and do wear out. Most frequently the rubber sleeve covering the U-joint ages and cracks or tears. Then the grease inside can be lost or contaminated.
Inside the U-joints is a smaller shaft, with a ball on the end. The ball is bisected by a trunion pin. On the trunnion pin ends two more balls are fitted, which ride on needle bearings so they can rotate on the pin. The whole assemble then rides inside a heavy cast and machined housing, which has grooves to accept the needle bearing equipped trunion balls. So the U-joint can flex in the with regard to the driveline radial direction as well as move in and out in the driveline axial direction.
Proper rebuilding of the Detroit U-joint, including replacement of the rubber sleeve, involves pressing out the trunnion pin on a big hydraulic press. An automotive machine shop should have one, but you might have to look around for a machinist or mechanic willing to press out the pin and/or rebuild the U-joint.
When you get under the car you can inspect the rubber sleeves for integrity, and see if the driveshaft can be moved by hand forward and backward. If not, it might be seized up.
Usually the noise, I'm told, is a loud clunk when going over bumps and/or under load.
What I've seen is that the heavy machined casting that the trunnion runs in develops wear spots where the trunnion balls usually ride. Or there's a rubber sleeve/lubrication failure.
It's not too difficult to pull the driveshaft with the U-joints attached, but of course it's dirty uncomfortable work on your back under a car jacked up and on stands. (Don't rely only on jacks!). After that fixing the damn Detroit U-joints is no picnic, and pressing out the trunnion pin can be dangerous involving very high pressures. Pressing in a new pin requires a careful technique, because you want it to be centered on receiving ball. One mechanic who pressed mine in machined a spacer so that the pressing would stop at the right point.
Have fun.
Post# 884352 , Reply# 69   6/10/2016 at 01:18 (2,891 days old) by Stan (Napa CA)   |   | |
Post# 1158238 , Reply# 70   8/30/2022 at 03:29 (619 days old) by Stan (Napa CA)   |   | |
Don’t know where the 6 years has gone!
So the noise turned out to be worn needle bearings in the trany I went on driving the car around twin. The sound was evident only in first gear. Clutch was slipping in third gear then Finally the starter took a shit. New starter New clutch (pics of old) and new parts for tranny except sncro gear. (Couldn’t find one and mine was kind of o.K. New brakes and wheel cylinders. And fresh tune up (rotor cap points plugs) new battery. All well but still can’t drive it cuz the SOB sprung a radiator leak! Though you boys might want to see. |
Post# 1158241 , Reply# 71   8/30/2022 at 05:07 (619 days old) by askolover (South of Nash Vegas, TN)   |   | |
I'm a car nut so I like to see their innards. My VW has 314,000 miles on it currently. I kind of sort of have a feeling the dual mass flywheel is going out. Still running original clutch! All of that would get changed out if the above scenario does play out. I'll be due for a timing belt and water pump in about 5500 miles. I miss the simplicity of my old diesel Rabbit from 1980, but I can't complain about this 2001 bug that I bought new for my 30th birthday. |
Post# 1158242 , Reply# 72   8/30/2022 at 05:20 (619 days old) by SudsMaster (SF Bay Area, California)   |   | |
Interesting!
I also have a 1950 Plymouth, a "Special Deluxe". Her name is Bubbles. Part of the agreement so I could purchase her was to keep the name, LOL. I've had Bubbles for over 28 years. Used to drive her a lot. That clutch sure does look familiar.
I've replaced a lot of parts on Bubbles. Had the motor rebuilt - they didn't do a very good job, had to rebuild the motor again after about 2 years and 27,000 miles. The rings they put in were scoring the cyclinder walls. This time I pulled the motor myself and took it to a better machine shop.
She has a manual transmission (I don't think Plymouths had automatics in 1950), which works quite well. Found the little service book (had to go out to garage to fetch it).
Last time I drove Bubbles was in 2017. So she probably needs an oil change. Maybe a draining of the gas tank, too. IDK. Have to check coolant as well. And the battery may be dead. Such fun!
Yeah, I'm making plans to drive her again before this summer is out. |
Post# 1158245 , Reply# 73   8/30/2022 at 06:24 (619 days old) by qsd-dan (West)   |   | |
Clutch doesn't look bad at all, at least the material isn't worn down to the rivets, which is a good thing. I bet the slipping issue was weak pressure plate springs. Too bad about not locating new synchro's. You can extend the life of the 1st gear synchro by coming to a dead stop before shifting into first or blipping the throttle before shifting into first while rolling at slow speeds. The first method is the safest.
Post# 1158275 , Reply# 74   8/30/2022 at 18:56 (619 days old) by SudsMaster (SF Bay Area, California)   |   | |
Post# 1158288 , Reply# 75   8/30/2022 at 21:48 (619 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Thanks Rich I was quite sure there was no Sysco in first gear in a 1950 Plymout.
When Jeff and I started this business in 1979 we went out and bought two short wheelbase dodge tradesman 1974 vans with 225 slant sixes and three speed on the column they didn’t even have synchromesh in first gear, it made it kind of challenging in traffic because you had to come to almost to complete stop or double clutch to get it back into first gear and my van didn’t have power steering or brakes somehow or another Jeff’s van actually had power brakes.
I also think it’s unusual that you’d have trouble with a bad clutch slipping in third gear usually a bad clutch slipping it’s hard to even get the car Up to speed in first or second gear with a bad clutch.
I almost never comment on anything if I’m not absolutely sure about.
John L |
Post# 1158289 , Reply# 76   8/30/2022 at 21:53 (619 days old) by Stan (Napa CA)   |   | |
No synchro for first. I’ve always has to come to a complete stop before shifting into first. And even with all this work done, I still double clutch going into second..shel shift normal but she likes it better if I double clutch. I issue going from second to third.
My issue now is getting her loose from reveres! Somethings not quite right with linkage ? Greg take care of your Bug! Rich, don’t let Bubbles just sit there! She need exercise 😀 Here’s more pics |
