Thread Number: 63407
Frigidaire dishwasher in action |
Post# 859871 , Reply# 1   1/3/2016 at 19:17 (3,035 days old) by Joeypete (Concord, NH)   |   | |
My Frigidaire sounds similar with the alternating spray arms. The lower on mine is the Blade Spray so it sounds slightly different. I've had great results with it. I'm very happy.
I have used Finish tabs exclusively for the past several years but recently I bought some of the Sam's pacs and the work pretty well I must say. I add a wee bit of STPP to each load too. Keeps the inside of the dishwasher nice and clean. |
Post# 859883 , Reply# 2   1/3/2016 at 20:40 (3,035 days old) by Frigilux (The Minnesota Prairie)   |   | |
Your Frigidaire is impressively quiet for a contractor-grade machine. Cascade Platinum pacs do the best job in my dishwasher, as well.
Ashtrays are a challenge for the upper rack. I'd forgotten how a bit of mashed-in ash would sometimes be left behind---even in soft water. Hard to believe it's been well over a decade since my last Merit. 🚬 |
Post# 859888 , Reply# 3   1/3/2016 at 21:31 (3,035 days old) by washman (o)   |   | |
It does get the ashtrays clean frig, even in top rack. Also dries much better than the landlord supplied GE at the condo. CLICK HERE TO GO TO washman's LINK |
Post# 859890 , Reply# 4   1/3/2016 at 22:43 (3,035 days old) by mark_wpduet (Lexington KY)   |   | |
at that under loaded machine.....LOL
but it does sound like a lot of action going on inside. I have hard water and I use finish powerball with no problems at all, although I've heard Cacade Platinum is best, but some people say it leaves your dishes with a detergent taste? I dunno, I've never tried it.....but many people here use it, so I doubt that reviewer. |
Post# 859941 , Reply# 5   1/4/2016 at 06:43 (3,035 days old) by joeypete (Concord, NH)   |   | |
I run mine everyday and sometimes it's def not a full load. I try to use the Top Rack (Energy Saver) cycle when it's not full. I'll space everything out evenly so the sprays can do a better job since it's a shorter cycle. But even on "Normal" Heated Wash...it runs typically for maybe 1 hour 15-20 minutes. Top Rack is just over an hour. It doesn't just use the top rack spray though...which is weird, but whatever. lol
Post# 859962 , Reply# 6   1/4/2016 at 08:10 (3,035 days old) by Johnb300m (Chicago)   |   | |
Post# 860008 , Reply# 8   1/4/2016 at 14:29 (3,034 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
I saw your dishwasher video. I must say from the sounds of it, that is deent wash action. |
Post# 860010 , Reply# 9   1/4/2016 at 14:31 (3,034 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
I wonder what type of pump this dishwasher uses. |
Post# 860020 , Reply# 10   1/4/2016 at 15:10 (3,034 days old) by johnb300m (Chicago)   |   | |
This is the current style of Frigidaire main wash pump. Some are slightly different, but are the same Johnson Electric architecture.
Pump impeller up front. Grinding chamber in back. 2900-3100rpm .7-1.2amps www.repairclinic.com/PartDetail/b... The much older, Askoll-sourced pumps looked something like this. product-images.highwire.com/45599... |
Post# 860024 , Reply# 11   1/4/2016 at 15:16 (3,034 days old) by washman (o)   |   | |
but it is made in China. |
Post# 881664 , Reply# 12   5/21/2016 at 12:47 (2,897 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
I plan on getting my dad a Frigidaire dishwasher model fbd2400kw. I also plan on trying the cascade platinum packs in the lemon burst scent. I do have plenty of their sister rinse agent. |
Post# 881676 , Reply# 13   5/21/2016 at 15:15 (2,896 days old) by washman (o)   |   | |
The cascade paks consistently outperform all other brands I have used, even the Finish powerball recommended by the manufacturer. |
Post# 884819 , Reply# 14   6/12/2016 at 23:51 (2,874 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
Here's a video of the inside of a Frigidaire dishwasher. CLICK HERE TO GO TO GELaundry4ever's LINK |
Post# 884831 , Reply# 15   6/13/2016 at 02:38 (2,874 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 884989 , Reply# 17   6/13/2016 at 20:49 (2,873 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
How about this one? CLICK HERE TO GO TO GELaundry4ever's LINK |
