Thread Number: 63779
/ Tag: Modern Dishwashers
It's dead at 4 years I don't get it! |
Post# 863568 , Reply# 1   1/22/2016 at 20:45 (3,016 days old) by Rberryiii3 (Palm Springs, California)   |   | |
Could this be a water inlet valve problem ? |
Post# 863569 , Reply# 2   1/22/2016 at 20:47 (3,016 days old) by Rberryiii3 (Palm Springs, California)   |   | |
Post# 863577 , Reply# 3   1/22/2016 at 21:16 (3,016 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 863646 , Reply# 4   1/23/2016 at 10:49 (3,015 days old) by Yogitunes (New Jersey)   |   | |
Post# 863727 , Reply# 6   1/23/2016 at 19:38 (3,015 days old) by norgeway (mocksville n c )   |   | |
Of new DWs before I learned better!, a Custom 21 is running in my Kitchen right now! |
Post# 863765 , Reply# 7   1/24/2016 at 04:34 (3,014 days old) by askolover (South of Nash Vegas, TN)   |   | |
Post# 863771 , Reply# 8   1/24/2016 at 06:26 (3,014 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 863810 , Reply# 9   1/24/2016 at 11:21 (3,014 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 863917 , Reply# 10   1/24/2016 at 22:39 (3,014 days old) by kb0nes (Burnsville, MN)   |   | |
While it is quite possibly true that many new appliances have some form of built in surge suppression, if it is there it is fairly rudimentary and a bit late should there be an impulse. If the home is located in an area likely to see lots of lightning, it may well be wise to augment the protection.
Ideally impulse suppression should be added as far upstream as possible. A whole house device should be added at the distribution panel. As with a flood raging towards your home, its best to divert it as far away from the house as possible! The service entrance panel also has a much lower impedance path to ground which makes a suppressor there more effective. Adding a good quality device properly installed at the appliance is an extra layer of protection. Sadly most devices sold today are far better at giving peace of mind then actual impulse suppression. I do believe that John's assertion that few failures are caused by surges. Damage from surges is placed foremost in peoples minds as it sells lots of surge suppression devices (i.e. big profits). Since it is in the public mind just about any form of failure of anything electronic is commonly attributed to a surge or spike. I would say in general, unless you experiences a very near lightning strike, damage from a surge is far less likely then a random electronic failure. |
Post# 863929 , Reply# 11   1/25/2016 at 00:59 (3,014 days old) by tolivac (greenville nc)   |   | |
Best yet-UNPLUG the machine when it isn't in use or when storms are forecast.The "protection" in most appliances is pretty moot at best.A separate surge protector or unplugging are the best means of protection.Unplugging is FREE! |
Post# 863938 , Reply# 12   1/25/2016 at 03:33 (3,014 days old) by delaneymeegan (Midwest)   |   | |
"....unplug, or kill the power for about 5 minutes, then try it again and see what you get...... and "unplugging are the best means of protection"
With my Whirlpool Duet I've had a few issues with the timer. I found doing a "hard disconnect" (pulling the plug) vs. turning off the breaker or a switch, reset things. And when there is the threat of lightning or power surge, ALWAYS unplug.
Another thing you can try, while machine is unplugged, carefully remove the wires/plugs from the timer and reinstall. There may be a corroded or loose connection.
I hope it's this simple for you.
