Thread Number: 64413
/ Tag: Modern Dishwashers
Frigidaire DW motors |
Post# 870449   3/4/2016 at 09:33 (2,974 days old) by chetlaham (United States)   |   | |
Post# 870454 , Reply# 1   3/4/2016 at 10:02 (2,974 days old) by vacerator (Macomb, Michigan)   |   | |
Most machines don't even have one anymore because of the noise they made in pump outs. That Frgidaire looks simple, but also cheaply designed. At least it was able to be fixed. |
Post# 870457 , Reply# 2   3/4/2016 at 10:21 (2,974 days old) by chetlaham (United States)   |   | |
Post# 870458 , Reply# 3   3/4/2016 at 10:22 (2,974 days old) by johnb300m (Chicago)   |   | |
Post# 870527 , Reply# 4   3/4/2016 at 16:10 (2,974 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
How many chopper blades do the frigidaires have? What are they made of? |
Post# 870576 , Reply# 7   3/4/2016 at 21:19 (2,974 days old) by cfz2882 (Belle Fourche,SD)   |   | |
on a damaged 2011 GE dishwasher I stripped,the main motor was made in Vietnam :)the drain motor was made in china. |
Post# 870580 , Reply# 8   3/4/2016 at 21:55 (2,974 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
I like my dishwashers to have quality chopper blades in them. My whirlpool point voyager has 2 stainless steel blades in the food grinder so tough food particles get pulverized. It does matter. I am about quality, not quantity. |
Post# 870584 , Reply# 9   3/4/2016 at 22:55 (2,974 days old) by chetlaham (United States)   |   | |
Induction motors are significantly better then brush motors. Yes a very poor induction motor might fail before a good brush motor, but in my experience GE has some of the best motors for any modern dishwasher. The redesigned motors from 2000 are still chugging along. Comparing a brush motor to a GE quiet power motor is imo a no brainier.
If Frigidaire is still using brush motor on their DW I do not think that looks good in terms of reliability. |
Post# 870666 , Reply# 10   3/5/2016 at 09:51 (2,973 days old) by Johnb300m (Chicago)   |   | |
Well you'll be crying in your Cheerios to hear that GE and Elux now source their little brush motors from Johnson Elrctric. A Chinese firm with an English name.
They're AC fed, but have a built in AC/DC converter and permanent magnets. All make the same distinctive brush 'whine'. Though they seem pretty powerful thus far. |
Post# 870668 , Reply# 11   3/5/2016 at 09:54 (2,973 days old) by vacerator (Macomb, Michigan)   |   | |
A motor is as good as its bearings, rare earth induction magnets, or armature windings and carbon brushes. On a copper wound motor, all it takes is one broken spot to cause failure. |
Post# 870672 , Reply# 12   3/5/2016 at 10:24 (2,973 days old) by chetlaham (United States)   |   | |
Post# 870680 , Reply# 13   3/5/2016 at 11:54 (2,973 days old) by Johnb300m (Chicago)   |   | |
Chet, you're 100% correct.
The very low end standard tub GE machines still use the now "old" (aprox. 1/8hp) induction "quiet" motor. I believe they're now made in China and Vietnam. Sadly....they used to be made in the USA and Germany back in the 'good old days.' They're still a great motor though. Probably my favorite. |
Post# 870682 , Reply# 14   3/5/2016 at 12:18 (2,973 days old) by chetlaham (United States)   |   | |
Post# 870799 , Reply# 16   3/6/2016 at 07:49 (2,972 days old) by vacerator (Macomb, Michigan)   |   | |
SR motors need a microprocessor to control the sine waves. |
Post# 870814 , Reply# 17   3/6/2016 at 10:08 (2,972 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
What types of wash pumps do the frigidaires use from the BOL to the TOL models? |
Post# 871626 , Reply# 21   3/9/2016 at 21:37 (2,969 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
I noticed that the BOL model frigidaires have a single speed pump while the TOL models have a variable speed pump. Why is that? |
Post# 871627 , Reply# 22   3/9/2016 at 21:44 (2,969 days old) by Johnb300m (Chicago)   |   | |
Post# 871671 , Reply# 23   3/10/2016 at 06:06 (2,968 days old) by vacerator (Macomb, Michigan)   |   | |
under the upcharge of Electrolux. Entry level professional line, Electrolux, and Icon. |
Post# 875651 , Reply# 24   4/4/2016 at 21:36 (2,943 days old) by chetlaham (United States)   |   | |
Post# 875652 , Reply# 25   4/4/2016 at 21:40 (2,943 days old) by chetlaham (United States)   |   | |
Post# 877077 , Reply# 26   4/14/2016 at 14:39 (2,933 days old) by chetlaham (United States)   |   | |
It looks like you guys are right. I found this thread with a new GE dishwasher (congrats btw :) ) and the motor looks identical to Frigidaire's.
www.automaticwasher.org/cgi-bin/T... |
Post# 877135 , Reply# 27   4/14/2016 at 22:25 (2,933 days old) by panthera (Rocky Mountains)   |   | |
Post# 877187 , Reply# 28   4/15/2016 at 13:04 (2,932 days old) by chetlaham (United States)   |   | |
This place is bar none. :) Really eye opening.
As for variable speed pumps... one theory I have might be low water ususage. Some ultra high end machines from the past would actually cycle the motor every couple of seconds. The sump would fill, the motor would rev up sending water to the arms and then it would coast down for water to re-enter the sump. When it did it would rev back up again. If the motor rain continuously 2/3 of the time it would be pulling in air. Frigidaire, at least their low end models over come this by using a diverter so only one wash arm can run at a time. |
