Thread Number: 64713
More Misbehaving Duets! |
Post# 873702 , Reply# 1   3/21/2016 at 18:24 (2,957 days old) by COLDSPOT66 (Plymouth, Mass)   |   | |
According to the tech sheet, F9E1 is long drain. It does sound like the pump is bad. F8E1 is no water detected entering machine, or pressure switch not tripped. Hope this helps. John ( a friend of Eddie's; toploader 55) |
Post# 873704 , Reply# 2   3/21/2016 at 18:31 (2,957 days old) by stevet (West Melbourne, FL)   |   | |
That's what I thought too. I have seen similar design pumps that will run for a bit then freak out and fail and these were new ones and greater horsepower. Time to find a pump on Fleabay or use one of the ones I have and make or make it work! |
Post# 873705 , Reply# 3   3/21/2016 at 18:35 (2,957 days old) by COLDSPOT66 (Plymouth, Mass)   |   | |
Latest part # is w10730972. There are alot of part #'s on Repairclinic.com. |
Post# 873722 , Reply# 4   3/21/2016 at 19:57 (2,957 days old) by nmassman44 (Brooksville Florida)   |   | |
Post# 873756 , Reply# 6   3/22/2016 at 00:04 (2,957 days old) by MattL (Flushing, MI)   |   | |
On one of my duets I replaced the pump with a GE version. The WP pump was selling for ~$50 the same GE version was $19 if I recall. It was physically identical too. |
Post# 873930 , Reply# 7   3/22/2016 at 18:33 (2,956 days old) by stevet (West Melbourne, FL)   |   | |
Matt, If I can get the same pump from GE at that price I would definitley want to save the extra bucks. Would you have the part number for it? Thanks Steve |
Post# 873975 , Reply# 8   3/22/2016 at 23:49 (2,956 days old) by MattL (Flushing, MI)   |   | |
I have no idea at this point. If you do a search you might come across a post by me some 5 years ago on the topic. I think I posted about it, not sure. |
Post# 874147 , Reply# 10   3/24/2016 at 00:39 (2,955 days old) by MattL (Flushing, MI)   |   | |
Glad to hear you found one. |
Post# 877252 , Reply# 12   4/15/2016 at 21:28 (2,932 days old) by cfz2882 (Belle Fourche,SD)   |   | |
normal for water to be in that portion of motor-that is kind of a water cooling jacket it seems. |
Post# 877254 , Reply# 13   4/15/2016 at 22:01 (2,932 days old) by DADoES (TX, U.S. of A.)   |   | |
