Thread Number: 64730
/ Tag: Classified Ad Finds
1960's FRIGIDAIRE REFRIGERATOR |
Post# 873863   3/22/2016 at 14:51 (2,956 days old) by agitatorboogie (Denver)   |   | |
No interior shot. The owner wants it gone so a lot haggling potential. Pardon my dead links in advance
CLICK HERE TO GO TO agitatorboogie's LINK on Louisville Craigslist
Post# 873866 , Reply# 1   3/22/2016 at 15:10 (2,956 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
ooh! Someone get it! I'd love to, but unfortunately, a comet has struck and I can't move.
CLICK HERE TO GO TO ovrphil's LINK on Louisville Craigslist |
Post# 873874 , Reply# 2   3/22/2016 at 15:27 (2,956 days old) by rp2813 (Sannazay)   |   | |
Post# 873958 , Reply# 3   3/22/2016 at 22:40 (2,955 days old) by funktionalart (Rison, AR)   |   | |
1963 Custom Imperial. Mine's turquoise. It works. BUT : I do need freezer shelving componentry replacements(roller guide bits for sliding). If any of you buy this, please contact me before you part out! PLEASE. These things are getting scarce….
CLICK HERE TO GO TO funktionalart's LINK
Post# 873959 , Reply# 4   3/22/2016 at 22:43 (2,955 days old) by funktionalart (Rison, AR)   |   | |
Post# 874118 , Reply# 6   3/23/2016 at 20:34 (2,954 days old) by funktionalart (Rison, AR)   |   | |
PhilR will probably tell you all you need to know as he has multiples of these Frigidaires. I can give you specs on my own '63 later tonite--for now I can tell you that it is either FPI-14 which means 14 cu. ft. or FPI-16 ) 16 cu.ft. I cannot recall exactly which at the moment The refrigerator section is not large at all when compared to a modern unit…but still plenty commodious for the era. . Dimensionally about 70-71" tall, 30 or 32 wide and around 26-27 deep…but I will give exact dimensions after I measure it tonight for you.
Post# 874154 , Reply# 8   3/24/2016 at 02:38 (2,954 days old) by PhilR (Quebec Canada)   |   | |
The 1961 FPI-15B and 1963 FPI-16B have the same exterior dimensions. The 1963 models got rid of the cold plate in the refrigerator section. The interior volume of the refrigerator section is marginally bigger because of that but it's simplified design means one less fan motor, one less thermostat (the one for the fan in the refrigerator section of the 1962 and earlier models is hidden and it's adjustment is a service operation) and no cold plate in the refrigerator section. For all the parts removed, there's one extra part and it rarely fails in the 1963, that part is a thermostatic valve that regulates the airflow in the refrigerator section, it works in a similar way as a coolant thermostat in a car.
The 1963 models are still more complicated than manual defrost refrigerators but the simplified refrigerating system works better at maintaining constant temperatures in the refrigerator section when it works fine.
One thing to look for on all these early Frost-Proof Frigidaire refrigerators is to see if there's a current leak on the cabinet. If the refrigerator has been stopped for a while, it might not be detectable but if it's running, you can disconnect it and test put one of the probes on both prongs of the power cord and the other on a metallic part of the fridge like the stainless trim around the cabinet. With the multimeter set on "ohm" or "beep" (if it has the beep feature), it should not beep or detect continuity on that setting. Another way to test that is to ground one of the prongs of the multimeter and touch the cabinet of the fridge while it's connected with the mulltimeter set on 200V AC, see if it shows current leak, repeat the operation with the fridge's plug reversed in the wall outlet (these aren't polarized). If there's no current or minimal current leak, it will show 0 or a very low reading, if it shows something like 118 volts, it will likely need a new defrost heater. The defrost heaters aren't that easy to replace on these refrigerators.
Also, before you fill it with food, make sure that the temperatures in the refrigerator and in the freezer are OK and that the defrost timer and heater work correctly, every 12 hours on a 1963. The timer's manual advance shaft has been moved from just behind the kick plate on the left side to facing the water tray also on the left side. That is of course if the timer hasn't been replaced with a generic one.
To test the temperatures in the freezer and in the fridge, I suggest placing a good quantity of water in a large plastic pan in the freezer and a good quantity of water in a pitcher in the fridge. Set the cold control to "1" and wait for a day to see what happens. Then put a thermometer directly on the ice in the freezer and in the water in the fridge. You want the compressor cycle on and off occasionally (not just twice a day when the defrost takes place but a few times between each defrost periods and check the temperatures of the water and the ice in the freezer. The ice should be at or below 0°F and the refrigerator section should be between 32°F and 40°F.
The only disadvantages I see versus the earlier cold plate system is that the air that circulates in the food section also circulates in the freezer section. So if you keep things for a long time in the freezer, things may catch odors from the items stored in the refrigerator. But most of today's fridges are also made like that and they circulate the air between the freezer and the refrigerator sections.
I have one 1963 FPI-16B and it works nicely.
Post# 875423 , Reply# 10   4/3/2016 at 07:24 (2,944 days old) by funktionalart (Rison, AR)   |   | |
Post# 875464 , Reply# 11   4/3/2016 at 12:00 (2,944 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
Post# 875500 , Reply# 12   4/3/2016 at 19:20 (2,944 days old) by PhilR (Quebec Canada)   |   | |
Post# 875591 , Reply# 13   4/4/2016 at 11:57 (2,943 days old) by agitatorboogie (Denver)   |   | |
Post# 875607 , Reply# 14   4/4/2016 at 14:06 (2,943 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
Post# 917815 , Reply# 16   1/27/2017 at 08:23 (2,645 days old) by PhilR (Quebec Canada)   |   | |
Post# 917839 , Reply# 17   1/27/2017 at 12:51 (2,645 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
Post# 917849 , Reply# 18   1/27/2017 at 14:35 (2,645 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
Post# 917862 , Reply# 19   1/27/2017 at 16:48 (2,645 days old) by Ovrphil (N.Atlanta / Georgia )   |   | |
Ad:
"Selling a working vintage fridge/freezer combo. Fridge reaches normal temps, freezer does freeze. In great cosmetic condition. I don't have the dimensions yet. Door seals need to be replaced but not urgent. $100 takes it." CLICK HERE TO GO TO Ovrphil's LINK on Cleveland Craigslist |
Post# 917875 , Reply# 20   1/27/2017 at 19:24 (2,644 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 918432 , Reply# 21   1/31/2017 at 11:10 (2,641 days old) by Ovrphil (N.Atlanta / Georgia )   |   | |
Post# 923125 , Reply# 23   2/22/2017 at 14:50 (2,619 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
Post# 1108939 , Reply# 24   2/20/2021 at 22:14 (1,159 days old) by Loried75 (Sayre)   |   | |
Post# 1109023 , Reply# 25   2/21/2021 at 15:28 (1,159 days old) by goatfarmer (South Bend, home of Champions)   |   | |
