Thread Number: 66082
Warning to those using Tide HE TurboClean liquid in their HE washers |
Post# 886643 , Reply# 2   6/23/2016 at 21:48 (2,863 days old) by mark_wpduet (Lexington KY)   |   | |
but I've avoided them for over a decade and only used powder. I'm sure not all liquids are bad - but this very thing is what I've always been afraid of using liquids. Even when I use the cheap watered down generic fabric softener, and only a very little, it gels in the fab softener dispenser, so I dilute it with a little more water.
Post# 886652 , Reply# 3   6/23/2016 at 23:47 (2,863 days old) by Murando531 (Augusta, Georgia - US)   |   | |
I've only used the powder HE Turbo because I typically use powders exclusively. The only liquid I am using now is Persil, but it's only with colors and darks. Towels are getting the Persil powder which I'm impressed with, although the price is still a factor in whether I'll buy it again. The Tide HE Turbo powder works very well, and I haven't had sudsing issues at all so far after using it for almost a year now. I've yet to have any residue or odor in the machine either.
Post# 886675 , Reply# 4   6/24/2016 at 02:59 (2,862 days old) by logixx (Germany)   |   | |
I rarely pour liquid detergents straight into the dispenser drawer - they always go on top of the clothes in a dispensing device (like the Tide Kick) or just a spare cap. Alternatively, I wait for the water to come on and add the liquid then, so it gets washed down immediately. I also don't pull the drawer all the way out when adding liquid detergent.
Post# 886703 , Reply# 7   6/24/2016 at 07:35 (2,862 days old) by Frigilux (The Minnesota Prairie)   |   | |
Yikes! I used liquid Tide for many years, then used pods, then went back to liquid Tide Ultra Stain Release Turbo Clean (and Persil ProClean 2 in 1) last September with the purchase of a Maytag 8100 front-loader that automatically dispenses detergent from a cartridge.
Haven't noticed any mold/mildew issues, but will keep an eye (and nose) out for it. I've only run the Clean cycle once, back in November of 2015. I use liquid chlorine bleach and boosted-temp hot water on several loads each week, so tend not to have many problems with mold, etc. Thanks for the heads-up. I'm a lifelong Tide user, so am reluctant to switch, but will be vigilant concerning buildup. Should probably run that Clean cycle again... |
Post# 886709 , Reply# 8   6/24/2016 at 08:11 (2,862 days old) by Yogitunes (New Jersey)   |   | |
we see this sort of thing all the time......its a matter of adapting laudry habits to the machine.....no different than certain machine shave to be loaded a certain way for best results...
your going to find this sort of issue with almost any liquid.....for one, I hate the dosing of trying to find that tiny hidden mark inside of the cap...... found it easier to mix each jug with a 50/50 mix of detergent and water, then a full cap is used each time, perfect measuring and results....oddly enough, this knocks out all the scent for some reason....this works for softeners too if your going to use full strength, a shot glass measures best, for most machines I use this method with, put the shot glass with detergent in the drawer and leave it there, by the time you flip it and close the drawer, the detergent is draining towards the back of the chamber.... and this also falls more along the lines of certain machines and their designs......pulling a drawer out to add liquid, as the drawer is pushed back in, the underneath is not getting flushed.....some machines do have an under flush, others do not..... probably best in this case is to add to the tub with the clothing..... not just Tide, any thick liquid is going to give the same results.... I too have seen the build up of detergents in the outter tubs of TLers....but again, this is not exactly a detergents faults, it operator error.....adding detergent to the tub before adding clothing or water, theres nothing really in place to stir this up.... if the package was read correctly, it mentions to add detergent 'AS' the machine is filling with water, not before, then add clothes for best results... never a bad idea to pull that drawer and rinse it out, and check that area as well on a weekly basis..... |
Post# 886779 , Reply# 10   6/24/2016 at 15:18 (2,862 days old) by washman (o)   |   | |
those PODS will come back to haunt you! Turn to the good side of the force and may the laundry force be with you! Hi frig! |
Post# 886797 , Reply# 11   6/24/2016 at 17:04 (2,862 days old) by mrb627 (Buford, GA)   |   | |
Are thicker than regular liquids and can cause problems with dispensers that are poorly designed to gradually leak detergent into the dispenser cavity. Cheaper detergents are typically more water than the more concentrated flavors. They won't typically build up as quickly.
I stopped using the dispenser drawer for liquid detergents. I put liquids in the drum directly to avoid build up of any kind. Every machine seems to have some quirk in its design. You have to find a way to live with it, or send it on its way and find something else. Malcolm |
Post# 886812 , Reply# 12   6/24/2016 at 19:53 (2,862 days old) by Iheartmaytag (Wichita, Kansas)   |   | |
I use liquid, powders and pods. I run a clean washer cycle fairly often. I always leave my door open and pull the detergent drawer. I always wipe down the boot, window and drawer after each use, and turn off the water.
About once a month or more often if I'm thinking about it. I take the drawer to the sink and give it a washing there, also wipe inside the dispenser area at this time.
One thing I will hijack the thread here if any of the knowledgeable know. How do you clean the hard water scale from the diffuser above the dispenser? I wish there was an easy way to remove it, for now soak a rag in white vinegar and then wipe it the best I can, I am only getting one side that way.
End Hijack--thanks
Post# 886835 , Reply# 13   6/24/2016 at 23:24 (2,862 days old) by mark_wpduet (Lexington KY)   |   | |
when I used TL washers - I always started the machine empty, poured the detergent in, then added the clothes. I never knew I had been doing this all wrong. I'm pretty sure I was using liquid detergents at this point too...I don't think I ever once added clothes, started machine, poured detergent on the clothes.
@Iheartmaytag - that sounds exactly like my routine - I have no clue how you would clean that honestly. |
Post# 886893 , Reply# 14   6/25/2016 at 10:50 (2,861 days old) by Frigilux (The Minnesota Prairie)   |   | |
Post# 886914 , Reply# 16   6/25/2016 at 14:08 (2,861 days old) by mrb627 (Buford, GA)   |   | |
Goes to the top loaders in this category. Mostly due to the amount of water flushing the drawer. Plus, a liquid dispenser INSERT that holds the detergent until needed. Too bad they don't clean up to their capacity rating as claimed.
The Whirlpool reservoir dispenser for liquid might be the best thing out their in the FL market. Malcolm |
Post# 886919 , Reply# 17   6/25/2016 at 14:56 (2,861 days old) by Ilovewindex (Tualitan OR)   |   | |
Post# 886921 , Reply# 18   6/25/2016 at 15:29 (2,861 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
Post# 886938 , Reply# 19   6/25/2016 at 17:40 (2,861 days old) by Yogitunes (New Jersey)   |   | |
Post# 886964 , Reply# 20   6/25/2016 at 22:09 (2,861 days old) by Frigilux (The Minnesota Prairie)   |   | |
Malcolm-- The Maytag 8100 has an insert cup to hold liquid detergent for single doses and I agree it's much better than some of the dispensers on other machines. No leakage/seepage.
Yogitunes-- The auto-dispense system on the Maytag does the same; it mixes the detergent with water and sprays it over the load as it fills. You can see the sudsy spray saturating the clothes. The Cold Wash cycle goes one better, dispensing all the detergent in a very small amount of water and tumbling for about 15 minutes. Then it adds the remaining water and begins the wash cycle. Kind of like Kelvinator's Magic Minute. |
Post# 886970 , Reply# 21   6/25/2016 at 23:37 (2,861 days old) by ilovewindex (Tualitan OR)   |   | |
Post# 887009 , Reply# 22   6/26/2016 at 09:21 (2,860 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
This is the biggest NON-PROBLEM I have heard of. WE have never done a service call for this problem, And I have never seen a washer in the field where this was causing a problem. First of all if there in a build-up of detergent in any part of a washer it is very easy to remove, detergent desolves very quickly and easily with a little hot water [ fabric softener build-up is a different matter ].
Liquid Tide is an excellent product, it will not cause more bearing failures that cheaper brand detergents, I would love to see someone prove that.
If you want to add detergent directly to the washer either poor it directly on the clothing or wait till the washer finishing filling because if the washer has an electric drain pump whether TL or FL machine the liquid detergent can run down into the sump where it may stay till the washer drains.
Again I have never seen a washer that had a build-up of either powered or liquid detergent anywhere water is. The only service call we ever did where detergent build-up caused a problem was on a early 80s WP BD TL washer, where the customer said the washer was doing everything except spinning. It turned out that they were so sloppy when adding powered detergent to the washer that detergent was built up so heavily on the top of the washer that the lid could not close enough to activate the lid switch, I took a putty knife and scraped away enough dried detergent so the lid would close again, LOL.
Post# 887078 , Reply# 24   6/26/2016 at 19:35 (2,860 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
As he is right on. If this was truly a problem then EVERY FL IN EVERY LAUNDROMAT MADE IN THE LAST 30+ years would have gunked up and failed due to liquid Tide! BTW my machine does not have or need a clean washer cycle and I have NO build-up. When you build them right such wasteful bull$hit is not needed.
WK78 |
Post# 887087 , Reply# 26   6/26/2016 at 22:48 (2,860 days old) by DADoES (TX, U.S. of A.)   |   | |
A properly designed dispenser nowadays (last 10-ish years) has a cup insert or a "dam" set in place when liquid detergent is used to prevent it from running out until the fill water begins flowing into the cup to overflow/flush it. I suppose some machines (older models?) perhaps are designed differently? |
Post# 887099 , Reply# 27   6/27/2016 at 01:41 (2,859 days old) by logixx (Germany)   |   | |
Post# 887145 , Reply# 28   6/27/2016 at 10:36 (2,859 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
I use tide he turbo clean but I use the powder version or tabs this is the one I use but the 120 wash load format
Post# 887149 , Reply# 29   6/27/2016 at 10:51 (2,859 days old) by Iheartmaytag (Wichita, Kansas)   |   | |
Years ago a neighbor, an Amway dealer, was telling my mother how corrosive Tide was, how it would damage her washer yadda--yadda.
So she set out to demonstrate to my mom by putting a cup of Tide in a quart mason jar, and a cup of Amway in another jar. She filled to about two inches from the top with hot water and put in each jar a wad of steel wool. Shaking them all together to mix it all up as if agitating.
Then the idea was to let them sit and show how Tide would eat away at the steel. Two weeks later the steel wool was gone all but debris, in the Amway jar. The Tide jar the steel wool was still intact.
Now this was powders, as there were few liquid detergents save Era or Wisk at that time. I believe that Tide powders used to have an ingredient listed "to protect washer parts" I haven't read the ingredients lately, don't know if they still list or not.
Post# 887177 , Reply# 30   6/27/2016 at 15:13 (2,859 days old) by Murando531 (Augusta, Georgia - US)   |   | |
Honestly I don't trust cheaper detergents over P&G detergents, and now Persil. I've had more issues from using All or Arm&Hammer and the like than anything else, not only with their crappy cleaning performance but the odors the leave in machines. My Papaw solely used Purex liquid in their FilterFlo, and the amount of gunk that would be around the recirculating port was disgusting. I convinced him to use a box of Gain powder I bought him, for a month, and before he used it, I gave his machine an "Andrew-Finesse", and scrubbed every nook and cranny with toothbrushes and toothpicks. And for that month or so after, there was barely any grime at all even around basket water line. Switched back to Purex because he wanted to "support the little guys at Dollar General", and once again, not long before a musty smell in the machine and gunk around the recirculator and inside the rubber lip of the cabinet.
I won't dare use budget detergents in my BravOasis, knowing how crucial it is for there to be no buildup on the floating basket's shaft, and so far, a year and two months with this machine, nary a splotch of residue or even the slightest whiff of odor to be found. |
