Thread Number: 68795
1974 maytag a207 still shakes |
Post# 915911 , Reply# 2   1/16/2017 at 10:56 (2,656 days old) by mrb627 (Buford, GA)   |   | |
Post# 915950 , Reply# 3   1/16/2017 at 16:02 (2,656 days old) by bendixmark (Winchester Mass)   |   | |
What is this washer sitting on? |
Post# 916541 , Reply# 5   1/20/2017 at 11:48 (2,652 days old) by swestoyz (Cedar Falls, IA)   |   | |
You mentioned that you changed the damper pads. Did you change them because the machine was squeaking during spin, or for good measure?
If the machine was already squeaking badly before changing them the damper may have been permanently damaged.
If the tub springs are adjusted correctly (which should correct the leaning tub) and the leveling legs are adjusted correctly with a leveled machine, your Maytag should be whisper quiet on a solid floor.
Ben |
Post# 917135 , Reply# 8   1/23/2017 at 15:20 (2,649 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
