Thread Number: 68910
/ Tag: Ranges, Stoves, Ovens
My Ancient Xmas Cactus: Storm Victim |
Post# 916957   1/22/2017 at 15:10 (2,662 days old) by rp2813 (Sannazay)   |   | |
The winds were howling almost all night. At around 12:30 AM I was getting ready for bed, and as I went to turn off the front patio light, I realized my sprawling Xmas cactus that may date as far back as the 1940s was MIA. It had been blown off the patio.
This thing weighs a ton, and was well-seated in a cast iron stand, but apparently it was a little too top-heavy. I was planning to re-pot it, as it hasn't been looking happy, so I guess I'll be doing that sooner rather than later.
Under calm conditions earlier today, I assessed the damage. I'm glad it wasn't worse. It looked as though it could have been reduced to stubs before I righted it. |
Post# 916962 , Reply# 1   1/22/2017 at 15:35 (2,662 days old) by vacerator (Macomb, Michigan)   |   | |
Zygo I've seen. |
Post# 916965 , Reply# 2   1/22/2017 at 15:46 (2,662 days old) by pulltostart (Mobile, AL)   |   | |
Post# 916970 , Reply# 3   1/22/2017 at 16:19 (2,662 days old) by Maytagbear (N.E. Ohio)   |   | |
Ralph...if you haven't already, take several tip cuttings, and best of luck. Lawrence/Maytagbear |
Post# 916977 , Reply# 4   1/22/2017 at 16:43 (2,662 days old) by rp2813 (Sannazay)   |   | |
Lawrence (pts and mb),
Back in 1984, I briefly lived in an all original 1937 Mediterranean style home that had been uninhabited for several years. Out in the unkempt back yard, hidden under a thick and tangled mat of overgrown Bermuda grass, I caught a glimpse of a fluted turquoise glazed pot on its side and long forgotten, containing this lopsided cactus, not even a foot across, that was still trying to make a go of it. I fished it out, found a place for it and began to care for it.
When it was time to move, I brought the cactus over to my parents' house, where it has been ever since. It did well here, although at one point (+/- 1990?) its stand got tangled up with the garden hose and it toppled, shattering the original pot. I had an identical vintage pot, slightly larger and unglazed, so popped it in there and that is the pot that broke last night.
I've received various varieties of Xmas cacti over the years as gifts, and not a one of them has survived. This plant, on the other hand, seems indestructible -- as the pix above attest. I started a hanging specimen from a slip of this plant about 20 years ago and it got huge, requiring over 3' of clearance underneath. I gave it to a friend a couple of years ago because I didn't want to deal with re-potting it. I have taken many slips from this plant with good success. It seems to be a fool-proof variety. It looks like the broken pieces left behind by last night's mishap will be great for potting up and starting more plants. |
Post# 916983 , Reply# 5   1/22/2017 at 17:25 (2,662 days old) by pulltostart (Mobile, AL)   |   | |
Post# 916988 , Reply# 6   1/22/2017 at 18:08 (2,662 days old) by rp2813 (Sannazay)   |   | |
Post# 917012 , Reply# 7   1/22/2017 at 20:00 (2,662 days old) by ptcruiser51 (Boynton Beach, FL)   |   | |
As most of you know, I re-located to FL from NJ several years ago. I gave my two cacti to my sister for safekeeping until I could make another trip to the Garden State. Not knowing what to do with them, she put them on top of the toilet tank in her guest bathroom. She has four cats and they will trash any plant brought in, so she was able to keep the door shut. Lo and behold, the plants bloomed twice with almost no attention other than watering.
Brought them here, and they grow fine except for no blooms. I took cuttings and sent them to a friend in PA. He rooted them and they bloomed! Go figure... |
Post# 917016 , Reply# 8   1/22/2017 at 20:11 (2,662 days old) by earthling177 (Boston, MA)   |   | |
My mother used to say that there are many plants like that, including African Violets -- when the temperature is good, enough light and water, they just grow, but when it seems that hard times are coming (less water, light or soil nutrients) then they bloom. |
Post# 917041 , Reply# 9   1/22/2017 at 23:45 (2,662 days old) by rp2813 (Sannazay)   |   | |
This one has always bloomed, but the timing has varied according to the amount of light the plant receives. Usually it was well after the holidays and almost closer to Easter, apparently because it was getting too much shade. I lopped off some low limbs and branches on nearby trees to allow for two or three hours' worth of morning sun to hit it, and the next bloom began right around Xmas. The following two have as well.
Charlie, try different exposure and let soil dry between waterings. I do very little to this plant other than enjoy it.
Growing up, an IBM scientist lived around the corner from here. Back in the '60s, in his spare time he did a lot of experiments with plants to see if they had feelings, and results indicated they might or did. Needless to say, neighbors thought he was kind of a kook. Call me a kook, but maybe this plant is forever grateful to me for saving it. |
Post# 917052 , Reply# 11   1/23/2017 at 01:01 (2,662 days old) by rp2813 (Sannazay)   |   | |
Matt, cuttings can be as short and small as a single "leaf" or they can be taken from older more woody pieces. In the last picture above, those woody looking stems that snapped off will get stuck in pots. Some of the younger greener parts will too.
Let the cut ends dry before sticking in soil -- deep enough to keep the cutting stable/upright. Don't overwater. They'll rot instead of root.
I'll take some pictures of a couple of cuttings I've got going around here and post them. |
Post# 917192 , Reply# 13   1/23/2017 at 19:02 (2,661 days old) by ptcruiser51 (Boynton Beach, FL)   |   | |
I see you are from Pittsburgh. Do you think your suggestion would work here in FL? The sun is very hot here in the summer, and I don't have a spot that's shaded on my property. As for "first frost", we don't have that in South Florida! My first summer here I put the cactus under a picnic table on the patio. It still got fried! Another aw.o pal said to put it in a darkened room and water sporadically. It still did nothing. Maybe I should give it back to my sister and tell her to put it back on her terlet tank! LOL.
Post# 917234 , Reply# 14   1/23/2017 at 22:12 (2,661 days old) by rp2813 (Sannazay)   |   | |
Charlie, is there not even a spot where you can create shade on a north or east facing side of your place?
I still maintain that blooming is more about light than temperature. These plants don't like temperatures below 33, so I don't think Florida is the problem in that regard, but they also don't like to bake in the sun, so in your case, the more shade the better. They also don't look their best if they get too much sun. Just a chunk of lattice strategically placed would probably help yours.
Here are shots of cuttings I've taken, some quite recent and others a couple to a few years old. For scale reference, none of the pots is wider than 6". I moved one to the table on our back patio a few weeks ago since it's under cover from rain and any frost, and where we can enjoy its blooms. Even the sort of sickly looking sprig in the last shot is still bent on producing blooms. It may ultimately fail, but the little starts in the same pot appear poised to take off.
Post# 917325 , Reply# 15   1/24/2017 at 11:07 (2,661 days old) by Maytagbear (N.E. Ohio)   |   | |
the pilot episode/TV movie of "The Waltons?" The one with Patricia Neal as Olivia? She had her Christmas Cactus down cellar.... The series was OK, but I love the pilot movie much, much more. Lawrence/Maytagbear |
Post# 917378 , Reply# 16   1/24/2017 at 14:16 (2,660 days old) by rp2813 (Sannazay)   |   | |
Lawrence, I do remember that scene, and my cactus often brings it to mind when it blooms -- although I think I remember her cactus having red flowers. I'd go so far as to say that scene was part of my motivation for the rescue operation mentioned above.
I love Patricia Neal, and honestly, that scene, along with Johnboy's simple explanation for what triggered the Great Depression, are the only two I can readily recall from the pilot that IIRC was entitled "The Homecoming."
I remember being disappointed that Neal and the comparatively rugged guy who played the dad weren't part of "The Waltons" cast. I agree with you that the series didn't measure up to the pilot. |
Post# 917471 , Reply# 17   1/25/2017 at 06:07 (2,660 days old) by polkanut (Wausau, WI )   |   | |
Here's a listing of the actors and the parts they played in the original pilot/movie. Andrew Duggan played the part of John Walton.
CLICK HERE TO GO TO polkanut's LINK |
Post# 917986 , Reply# 18   1/28/2017 at 14:07 (2,656 days old) by rapunzel (Sydney)   |   | |
That's the saddest looking cactus I've ever seen. HOW COULD YOU?! I'm gonna be sobbing all day now. |
Post# 918047 , Reply# 20   1/29/2017 at 01:12 (2,656 days old) by rp2813 (Sannazay)   |   | |
Post# 990130 , Reply# 22   4/10/2018 at 01:14 (2,220 days old) by RP2813 (Sannazay)   |   | |
Matt, I'm not so sure that dividing it would be the best thing, unless it's clearly two or more plants in the one pot. Mine was in the same size pot from the day I found it until it blew over 33 years later, but as I mentioned above, it seemed like it was finally ready for a larger pot before the mishap.
I never took pictures of it in its larger pot, so will get some shots that will capture the new growth from the snapped ends. It is much happier in its larger container.
I've never had my CC bloom more than once. I know some friends with a red orchid cactus (a started cutting that I gave them) that provided a second round of blooms during this past summer, though. None of my orchid cacti have bloomed more than once either.
Post# 990197 , Reply# 23   4/10/2018 at 12:21 (2,220 days old) by MattL (Flushing, MI)   |   | |
Thanks, I'll have to look for a bigger pot rather than dividing. Mine is red with double flowers. |
Post# 990215 , Reply# 24   4/10/2018 at 14:26 (2,219 days old) by RP2813 (Sannazay)   |   | |
Here are some shots of the cactus in what may turn out to be its forever home. It's a deep, very heavy, tapered square shaped terracotta pot. I may have to come up with a suitable pedestal for it soon. The three-legged stand it was in when it blew over is on the left, currently home to a spindly gardenia that's languishing in too much shade.
You can see the shiny green new growth that sprouted from the areas where branches snapped off when the plant fell. It seems to be quite happy in its new pot. |
Post# 990258 , Reply# 25   4/11/2018 at 00:34 (2,219 days old) by MattL (Flushing, MI)   |   | |
Here are a few shots of my plant, smaller than yours by quite a bit... |
Post# 990262 , Reply# 26   4/11/2018 at 02:33 (2,219 days old) by RP2813 (Sannazay)   |   | |
Matt, that is a beautiful plant! It's an impressive size for living indoors, and it appears to be very healthy and well cared-for. The double blossoms are truly special. I don't recall seeing anything like it before.
I'd say to wait to re-pot unless the roots are pushing the plant up and out of the pot. These plants can become very heavy, so just be sure the pot and plastic hanger aren't getting brittle. It's best to suspend them with something more secure. I just last week placed one of my hanging orchid cacti, weathered plastic pot and all, into a metal hanging basket that would normally be used with one of those coco-liner things inside it. It was so heavy and lopsided that it was a disaster waiting to happen. |
Post# 990321 , Reply# 28   4/11/2018 at 15:12 (2,218 days old) by RP2813 (Sannazay)   |   | |
