Thread Number: 69940
/ Tag: Wringer Washers
Wringer washer pump hose replacement |
Post# 928655   3/24/2017 at 11:26 (2,589 days old) by Johnny42 (Glasgow)   |   | |
Post# 928666 , Reply# 1   3/24/2017 at 14:23 (2,589 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Hi Johnny, has the hose split and leaking, if its intact I would smother it in clear water sealant and then well dry wrap it in duct tape...if bad the hose is in one pierce from the pump to the back of the helmet hose that enters the tub...the helmet tub side is pushed into the tub wall, its a right angles piece of rubber with a hose connector !! It is fiddly but can be done without taking the top off.....otherwise take the wringer off and undo the screws in the sides, the top will pull off but take care with the fibre / rubber top seal that it doesn't break...
Will scan the service pages when back at the weekend, Have you got a new helmet hose from ebay ? Mike |
Post# 928672 , Reply# 2   3/24/2017 at 14:59 (2,589 days old) by Johnny42 (Glasgow)   |   | |
Post# 928693 , Reply# 3   3/24/2017 at 17:56 (2,589 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Heres one near to you ..this is for a twinny so you may have to extend the pipe to get to the pump, wringer hoses are deffo nla..but you will have the original helmet.
CLICK HERE TO GO TO chestermikeuk's LINK on eBay |
Post# 928694 , Reply# 4   3/24/2017 at 18:08 (2,589 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Post# 928856 , Reply# 5   3/25/2017 at 12:48 (2,588 days old) by Johnny42 (Glasgow)   |   | |
