Thread Number: 7001
multimaic |
Post# 138337   6/27/2006 at 19:05 (6,512 days old) by christfr (st louis mo)   |   | |
who has cracked one of these open? have 2 dif books and as usual they dont tell you everything. this baby has a prob with the brake when the spin ends and the brake kicks in the tub does stop as it should but then the trans locks, you can yank on the trans case and unlock it but it will do the same on the next spin so im thinkin the brake or spring in the upper end. any ideas boys?? i want to tear into this but cant get the nuts off
Post# 138338 , Reply# 1   6/27/2006 at 19:08 (6,512 days old) by unimatic1140 (Minneapolis)   |   | |
Post# 138344 , Reply# 2   6/27/2006 at 19:28 (6,512 days old) by christfr (st louis mo)   |   | |
Post# 138345 , Reply# 3   6/27/2006 at 19:33 (6,512 days old) by unimatic1140 (Minneapolis)   |   | |
Chris as far as I remember that is a standard nut, so its lefty-loosie to remove it. Take a standard hex wrench and tap it with a hammer counter-clockwise to remove it. Then you are going to need to remove the bigger nut above. There is a special tool to remove that nut, but I've done it many times without the tool. That also turns counter-clockwise to remove. The spring will be in the mechanism above that.
Post# 138350 , Reply# 4   6/27/2006 at 19:59 (6,512 days old) by christfr (st louis mo)   |   | |
Post# 138404 , Reply# 5   6/28/2006 at 06:14 (6,512 days old) by christfr (st louis mo)   |   | |
well robert was right it does come apart ha ha..so now it all apart on the floor it looks good and feels good but still not sure what the spring is really supposed to look like, the book talks about tiny gaps can cause probs, and i think i see a gap so....now the hunt is on for a spring. oh and seems that rapid dry on ebay (the one with the brake issue) will be comming to st louis ha..i dont think il ever get the car back in the garage now. gees what if i win that other one too..i must have lost my mind
Post# 138538 , Reply# 6   6/28/2006 at 15:46 (6,511 days old) by oldwasherguy (Ladson SC)   |   | |
Post# 138709 , Reply# 7   6/29/2006 at 06:06 (6,511 days old) by christfr (st louis mo)   |   | |
Post# 139293 , Reply# 8   7/1/2006 at 20:08 (6,508 days old) by christfr (st louis mo)   |   | |
Post# 139317 , Reply# 9   7/1/2006 at 22:11 (6,508 days old) by tlee618 ()   |   | |
Hi Chris, Looks like you are having fun there!!! Glad that you have some new toys to play with and challenge you!!LOL Terry |
