Thread Number: 70624
Advise on New Washing Machine |
Post# 935833 , Reply# 1   5/2/2017 at 12:22 (2,551 days old) by appliancedude16 (Sunnyvale,California, U.S.A)   |   | |
Buy a speed queen top loader, they are built to last and clean clothes really good, plus they are about 26 inches, the dryer is 26 7/8 inches wide. |
Post# 935838 , Reply# 2   5/2/2017 at 12:38 (2,551 days old) by johnb300m (Chicago)   |   | |
Post# 935844 , Reply# 3   5/2/2017 at 13:08 (2,551 days old) by panthera (Rocky Mountains)   |   | |
Here are several possibilities, in no particular order - all I've either installed and followed for a few years (at least) so know they work: 1) Get the Maytag fixed? 2) A stackable washer/dryer would fit your depth and width description. Whirlpool makes 24 and 27", as does GE. Frigidaire makes one in 27" which is very highly regarded for it's cleaning and known to fail the day after the warranty runs out. The Whirlpool, Frigidaire and GE 27" models wash a full load. The GE seems a bit easier to install, the Whirlpools are easier to learn if you're used to traditional. Both will need a second rinse as they are, unfortunately, HE. 3) The mold problem with front loaders was caused by American consumers no longer knowing what their grandmothers did - you NEVER close the door completely, you MUST run a HOT water wash with oxygen bleach at least once a month. Then you NEVER have mold. Ever. 4 )Discontinued but still occasionally in big-box stores are the Electrolux 27" front loaders which are only about 24" deep. 5)Cold water washing and cheap fabric softener are at the root of 99.999999999999% of mold, scum, dirty washers and, yes, premature failure of washers. If you must cold water wash, then use top of the line detergents and accept that at the very latest, once a month you MUST run a true hot water cleaning cycle with chlorine bleach.
This post was last edited 05/02/2017 at 13:25 |
Post# 935847 , Reply# 4   5/2/2017 at 13:35 (2,551 days old) by mrb627 (Buford, GA)   |   | |
Post# 935849 , Reply# 5   5/2/2017 at 13:56 (2,551 days old) by brucelucenta ()   |   | |
Yep, for what you are needing speed queen top loader is the answer. It is really the ONLY answer for a top load machine. |
Post# 935853 , Reply# 6   5/2/2017 at 14:06 (2,551 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
Post# 935877 , Reply# 7   5/2/2017 at 16:43 (2,550 days old) by Yogitunes (New Jersey)   |   | |
don't compare capacities of TLers and FLers equally.....
a 3.3 of a FLer will hold quite a bit more than the same 3.3 of a TLer a FL set would offer a counter top area for folding or storage....a hanging rod over top never hurts as well... if anything, take a load of clothes into the store, and load the machine to get a feel for how much that machine will do per load... CLICK HERE TO GO TO Yogitunes's LINK
Post# 935887 , Reply# 8   5/2/2017 at 18:27 (2,550 days old) by panthera (Rocky Mountains)   |   | |
I think it's worth pointing out that a well restored Maytag made prior to the Whirlpool takeover is going to be much cheaper than a new SQ and will with 100% certainty last the desired 10 years, if not longer than the SQ. Yes, I think SQ is the only American made toploader right now which is well made and good at washing. I also think it's way more money than one needs to spend when there are still so many hundreds of thousands of outstanding Maytags from the pre-Whirlpool era out there. |
Post# 935999 , Reply# 11   5/3/2017 at 08:54 (2,550 days old) by panthera (Rocky Mountains)   |   | |
Post# 936054 , Reply# 12   5/3/2017 at 16:45 (2,549 days old) by Mrsalvo (New Braunfels Texas)   |   | |
Speed Queen is an excellent washer, i have one and it suits our needs quite well. As stated in the owners manual you don't want to overload them though, and I do agree. I keep mine wiped down and in pristine shape.😊 I think you'll like it, and the fast cycle times. |
Post# 936061 , Reply# 13   5/3/2017 at 17:19 (2,549 days old) by washman (o)   |   | |
Well..................never mind!
Hi Frig! |
