Thread Number: 70819  /  Tag: Vintage Automatic Washers
(Another) Hoover D6042 refurb
Post# 937919   5/12/2017 at 06:20 (2,541 days old) by triumphtoledo (Shropshire/Worcestershire)
Having just moved into a new house, this was awaiting us and, following advice on this Forum, I understand that they work pretty well and it would be best cleaning it up, replacing worn parts, and using it.
Post# 937920 , Reply# 1   5/12/2017 at 06:22 (2,541 days old) by triumphtoledo (Shropshire/Worcestershire)
Top off, all looking a bit dusty. the machine is very rumply, sounds like the fan, although the belt was very loose. I tried fitting a new one but, although the air flow was much improved, the rumble was still there.
Post# 937921 , Reply# 2   5/12/2017 at 06:24 (2,541 days old) by triumphtoledo (Shropshire/Worcestershire)
re
The drum belt was split almost all over too...
Post# 937922 , Reply# 3   5/12/2017 at 06:24 (2,541 days old) by triumphtoledo (Shropshire/Worcestershire)
plug
I think this should be replaced, as it doesn't look safe
Post# 937923 , Reply# 4   5/12/2017 at 06:26 (2,541 days old) by triumphtoledo (Shropshire/Worcestershire)
machine now stripped
I spent some time last night (11th May) stripping the machine down for assessment. The outer shell seems in good order. The timer is not a clockwork type but an electrical Sibel (French made) timer. Maybe it was replaced at some point. The knob looks quite new and still has a protective plastic film over the metal bezel.
Post# 937924 , Reply# 5   5/12/2017 at 06:28 (2,541 days old) by triumphtoledo (Shropshire/Worcestershire)
heater coils
Burnt fluff surrounding the heater coils needs vacuuming out. It looks as though the top heater coil was replaced, as the centre rope looks newer, which is hard to see on these crappy mobile phone pics...
Post# 937925 , Reply# 6   5/12/2017 at 06:29 (2,541 days old) by triumphtoledo (Shropshire/Worcestershire)
front bearing pads
The bearing pads look in good order but seem loose. I thought these should be white, not black. Originals, perhaps?
Post# 937926 , Reply# 7   5/12/2017 at 06:31 (2,541 days old) by triumphtoledo (Shropshire/Worcestershire)
heater coil rope
Does this look correct and/or safe to you? Seems weird that the heater coil ropes are tied together.
Post# 937927 , Reply# 8   5/12/2017 at 06:32 (2,541 days old) by triumphtoledo (Shropshire/Worcestershire)
Fluffy motor
Fluff seems to have infested the motor, so I think it will have to come apart and be cleaned-out, so it does not overheat.
Post# 937928 , Reply# 9   5/12/2017 at 06:33 (2,541 days old) by triumphtoledo (Shropshire/Worcestershire)
Fluff filter
The fluff filter had distorted and so I bought a new one and fitted that...
Post# 937931 , Reply# 10   5/12/2017 at 06:40 (2,541 days old) by triumphtoledo (Shropshire/Worcestershire)
fan bearing - Need help on this bit
Here's the bit I'm stuck on. The fan is made from metal and its centre shaft spins on a bronze bush. There is minor scoring on the shaft but it's not detrimental but there is movement between the shaft and bronze bush. Are these bushes available? Can anyone help at all?
R
Post# 937937 , Reply# 11   5/12/2017 at 08:02 (2,541 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)
dryer referb
Hi Rob, looking great with the refurb, easy to work on and lots of workarounds with parts / spares, am parting out same model which is at Als in the next couple of weeks and will have a spare fan / volute chamber which you are welcome to but wont be asap...
Keep them free of fluff and will last a long time, very quick drying as Mathew and Gary and John keep on about ha ha.. "Oovah Who Better"..
Post# 937952 , Reply# 12   5/12/2017 at 08:46 (2,541 days old) by triumphtoledo (Shropshire/Worcestershire)
cheers
Thanks Mike for the offer. Cheeky question, are the parts new?
R
Post# 937975 , Reply# 13   5/12/2017 at 09:43 (2,541 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)
Parts
Parts are New To Us but old vintage ? if that's what you meant ha ha..
Post# 937978 , Reply# 14   5/12/2017 at 09:55 (2,541 days old) by triumphtoledo (Shropshire/Worcestershire)
Sorry Mike, I meant new old stock; i.e. unused lol
Post# 938013 , Reply# 15   5/12/2017 at 12:05 (2,540 days old) by keymatic3203 (Cardiff UK)
parting out Mike?
that cabinet and panel look practically mint from here, probably better than mine, lol. I know can't keep them all.
Rob I've got a few of the fan bearing kits, you get the shaft and the bearing you're holding. so you're welcome to one of those.
oh and mine also has a sibel timer, so I'm sure these replaced the clockwork ones later in the run.
email an address to post to and I'll try and find one over the weekend,
Mathew
Post# 938027 , Reply# 16   5/12/2017 at 13:05 (2,540 days old) by triumphtoledo (Shropshire/Worcestershire)
Nice one Mathew
Brill Mathew, thanks - e-mail pinged over.
R
