Thread Number: 71109
/ Tag: Vintage Dishwashers
c76 Hobart Kitchenaid Deluxe Portable troubleshooting |
Post# 941293 , Reply# 1   6/1/2017 at 12:39 (2,520 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 941299 , Reply# 2   6/1/2017 at 14:18 (2,520 days old) by nmassman44 (Brooksville Florida)   |   | |
Methinks that you have a drain valve issue. If its a portable Deluxe as you say it is, take off the lower front panel and the valve is right in front on the left if I remember correctly. It should be vertical where the hose from the pump goes into the back of it and the bottom of the valve feeds the drain hose for the unicouple. It can be taken apart for cleaning. More than likely that it your issue. This machine's motor runs in one way only and constantly during the cycle except for dry.
Post# 941301 , Reply# 3   6/1/2017 at 14:34 (2,520 days old) by Steved (Guilderland, New York)   |   | |
Toothpicks and bread twisters were notorious fo doing exactly this. |
Post# 941366 , Reply# 4   6/1/2017 at 23:44 (2,520 days old) by petek (Ontari ari ari O )   |   | |
Post# 941416 , Reply# 5   6/2/2017 at 09:23 (2,519 days old) by MikeG (Silver Spring Maryland)   |   | |
Once again my thanks for all of your help and kindness. Sure enough, 20 minutes and a toothpick later our dishwasher is again making those distinctive happy sounds. Best regards and a big clean THANK YOU to all! |
Post# 941455 , Reply# 6   6/2/2017 at 15:50 (2,519 days old) by rp2813 (Sannazay)   |   | |
