Thread Number: 71143
/ Tag: Vintage Dishwashers
KDS-14 Restoration |
Post# 941714   6/4/2017 at 10:17 (2,518 days old) by Backintime (Mass)   |   | |
I am restoring a kitchenaid kds-14. Just a tech question. In reassembling this unit should i be putting any lubricant on the wand where it rides on the motor shaft? Thanks |
Post# 941721 , Reply# 1   6/4/2017 at 10:48 (2,518 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 941769 , Reply# 2   6/4/2017 at 17:06 (2,518 days old) by backintime (Mass)   |   | |
Hi I am talking about where the wash arm attaches to the motor shaft. I've attached some pics. Thank you. |
Post# 941789 , Reply# 3   6/4/2017 at 20:06 (2,518 days old) by Ultramatic (New York City)   |   | |
Post# 941791 , Reply# 4   6/4/2017 at 20:09 (2,518 days old) by rp2813 (Sannazay)   |   | |
Post# 941793 , Reply# 5   6/4/2017 at 20:13 (2,518 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Normally no lubricant would be used on that bearing [ you could put some Crisco on it if you want but it will wash away pretty fast ] this bearing is normally lubricated with the water detergent and any oils etc that are in the wash water, metal on metal bearings like this were always one of the reasons that it is better to put dishes in the DW as dirty as possible, as this bearing will wear out a lot faster if you rinse everything off the dishes.
The shaft that the wash arm sits on is the wash-arm-support, the motor shaft is down inside the pump and turns at 3450 RPMs on this DW.
Keep us posted on your progress.
Post# 941797 , Reply# 6   6/4/2017 at 20:24 (2,517 days old) by Backintime (Mass)   |   | |
Hi thanks for the info! So this isnt supposed to be a tight fit? Ill post more pics of this extensive resto if you like. Thanks Mike |
Post# 941799 , Reply# 7   6/4/2017 at 20:33 (2,517 days old) by Ultramatic (New York City)   |   | |
