Thread Number: 71158
Unimatic motor overload switch |
Post# 941920 , Reply# 1   6/5/2017 at 16:17 (2,516 days old) by TrainGuy (Key West, FL)   |   | |
Post# 941922 , Reply# 2   6/5/2017 at 16:22 (2,516 days old) by Phmorrow (Knoxville, TN)   |   | |
It is a WO-65. |
Post# 941928 , Reply# 3   6/5/2017 at 17:11 (2,516 days old) by Gyrafoam (Wytheville, VA)   |   | |
More importantly, what keeps tripping the motor overload switch? |
Post# 941945 , Reply# 4   6/5/2017 at 18:30 (2,516 days old) by TrainGuy (Key West, FL)   |   | |
Post# 941977 , Reply# 5   6/5/2017 at 21:41 (2,516 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
These sometimes go bad, best way to check is to take an amp reading of the washer while washing or spinning at full speed, the reading should be around 7 amps or a little less.
While accelerating into spin it will draw around 25 amps till the start winding cuts out.
You can just bypass the old OL and wire in a 15 amp time delay fuse if you don't want to try and find a good 60 YO part. |
Post# 942020 , Reply# 6   6/6/2017 at 06:40 (2,515 days old) by Phmorrow (Knoxville, TN)   |   | |
Thanks for the advice... I have a feeling it is just the switch; When you turn the dial and push it in for power, I have to very lightly push on the rest button to make it start to fill. The motor runs smooth and sounds healthy. |
Post# 942055 , Reply# 7   6/6/2017 at 12:21 (2,515 days old) by Unimatic1140 (Minneapolis)   |   | |
Those "PUSH" button overload protectors that Frigidaire used do not hold up if they have been tripped several times. Once they trip a few times they tend to trip unnecessarily over and over again. On most of my Unimatics I have jumped them out of the circuit if they are tripping unnecessarily. When using any of my vintage machines I always keep an eye on them and I'm not too worried about the lack of protector causing damage as I will generally catch any rare issue. I would never start a vintage machine and leave the house anyways.
