Thread Number: 71278
Any Twindos owners? |
Post# 943454 , Reply# 1   6/14/2017 at 16:21 (2,507 days old) by Northernmary (Huddersfield - West Yorkshire)   |   | |
Hello Adam,
I do own a wkh121wps machine with twindos and powerwash 2.0. You do see some suds when using the twindos system. I'm in a soft water area and some suds are present during the wash but I wouldn't say they was massively visible. I don't hear the machine dispense the liquids at all. I'm under the understanding that the twindos pumps in to the tub before the initial sump fill continues to fill then progresses to the powerwash distribution stages. How many times have you used the system it might just need a few washes to prime the system and get the liquids in the pipes? Just an idea ? Run the machine and if you don't feel that its working correctly get an engineer back out. Don't be disheartened there brilliant machines and the twindos detergent is very good too ! Detergent and bleach dispensed at the correct times gives a flawless wash. Hope this helps? Northernmary |
Post# 943543 , Reply# 3   6/15/2017 at 04:55 (2,506 days old) by Northernmary (Huddersfield - West Yorkshire)   |   | |
Hello Adam,
The machine primes its self the more the twindos is used I would of thought by 2 or 3 washes the system will be primed and delivering the correct amount of detergent. You can check its set to the correct levels by following the page I've posted before if you haven't already done your self? You definitely see more bubbles when the ultraphase 2 (hydrogen peroxide) has been added when doing white washes. Only because your clothes smell faintly of deturgent doesn't mean that not enough deturgent haven't been delivered it could be that the machine is fairly good at rinsing out the deturgent. I don't use softener and my clothes do faintly smell of the twindos deturgent. I love my laundry room area I've got shelfs full of deturgents, stuff I've used once and then I give it to friends and family 😂 James |
