Thread Number: 7135
New Speed Queen FL washer |
Post# 140728   7/7/2006 at 10:18 (6,503 days old) by jeff_adelphi (Adelphi, Maryland, USA)   |   | |
Post# 140729 , Reply# 1   7/7/2006 at 10:19 (6,503 days old) by jeff_adelphi (Adelphi, Maryland, USA)   |   | |
Post# 140731 , Reply# 2   7/7/2006 at 10:20 (6,503 days old) by jeff_adelphi (Adelphi, Maryland, USA)   |   | |
Post# 140732 , Reply# 3   7/7/2006 at 10:21 (6,503 days old) by jeff_adelphi (Adelphi, Maryland, USA)   |   | |
Post# 140733 , Reply# 4   7/7/2006 at 10:22 (6,503 days old) by jeff_adelphi (Adelphi, Maryland, USA)   |   | |
Post# 140735 , Reply# 5   7/7/2006 at 10:27 (6,503 days old) by jeff_adelphi (Adelphi, Maryland, USA)   |   | |
Post# 140736 , Reply# 6   7/7/2006 at 10:28 (6,503 days old) by jeff_adelphi (Adelphi, Maryland, USA)   |   | |
Post# 140738 , Reply# 7   7/7/2006 at 10:36 (6,503 days old) by newwave1 (Lincoln, United Kingdom)   |   | |
Post# 140740 , Reply# 8   7/7/2006 at 10:48 (6,503 days old) by washboy2005 (UK)   |   | |
I like that Speed Queen very much. Any chance of pics or Vids of your LG TROMM in action please ?? Thanks Take Care Dan |
Post# 140742 , Reply# 9   7/7/2006 at 10:55 (6,503 days old) by jeff_adelphi (Adelphi, Maryland, USA)   |   | |
Post# 140753 , Reply# 10   7/7/2006 at 12:37 (6,503 days old) by tlee618 ()   |   | |
Hi Jeff, Congratulations on the new machine. Boy your line up has sure changed since we were there in 2002!! Have fun with the new machine. Terry |
Post# 140789 , Reply# 11   7/8/2006 at 01:42 (6,502 days old) by alr2903 (TN)   |   | |
Very nice SQ great pics too. thanks. alr2903. |
Post# 140797 , Reply# 12   7/8/2006 at 04:52 (6,502 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 140799 , Reply# 13   7/8/2006 at 06:03 (6,502 days old) by askomiele (Belgium Ghent)   |   | |
Well that's a washer build to last very long. It's kind like my washer, the unknow OLYMPIA, build and sold only in the west of Belgium. Stainless steal drum en tub, iron counterweight and simply but good electronic design. Definatly family of this speedqueen!!! |
Post# 140805 , Reply# 14   7/8/2006 at 06:59 (6,502 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Post# 140813 , Reply# 15   7/8/2006 at 08:05 (6,502 days old) by mrb627 (Buford, GA)   |   | |
Post# 140843 , Reply# 16   7/8/2006 at 09:42 (6,502 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 140885 , Reply# 19   7/8/2006 at 12:59 (6,502 days old) by jeff_adelphi (Adelphi, Maryland, USA)   |   | |
I got the SQ washer from my good friend Bob Salem in Cleveland, Ohio. He is now a SQ dealer and gave me a deal I couldn't resist. The counter weight is cast iorn and mounted below the tubs. All the water from the dispenser enters the rear of the tub, but there is a nozzle at the top of the door boot that sprays the clothes when filling and for the first spray rinse. Water tempature has no thermal sensor, except for the boosted hot wash that heats to 140F. The water level in the video is the factory setting, a little more water then the Duet washer. I think the poor cleaning report is due to the short wash time, only 9 minutes. Total cycle time is about 30 minutes. They used the same cycle times as the commercial model. I bet they will change the cycle times soon. I have had no problems getting things clean. For very dirty loads I use the boosted hot setting, this extends the wash, due to heating time, about 10 minutes. Overall I like the construction of the washer. The SS tubs are quite heavy compaired to the Duet or LG I have. It should be very easy to service from the front. The tub bearings can be replaced without taking the tubs apart due to the removeable tripod on the rear of the outer tub. |
Post# 140891 , Reply# 20   7/8/2006 at 13:51 (6,502 days old) by mrb627 (Buford, GA)   |   | |
Post# 140920 , Reply# 21   7/8/2006 at 19:00 (6,501 days old) by decodriveboy (FL, US)   |   | |
Looks GREAT and solid as a tank! How much do these go for? Like the above poster I'm also curious if the factory water level setting can be adjusted. |
Post# 141037 , Reply# 23   7/9/2006 at 09:49 (6,501 days old) by mrb627 (Buford, GA)   |   | |
Post# 141039 , Reply# 24   7/9/2006 at 09:51 (6,501 days old) by mrb627 (Buford, GA)   |   | |
Does the detergent drawer remove for cleaning? The manual indicates that the operator should simply pour hot water through it for cleanup. Since this is foremost a commercial machine, there probably isn't an easy way to remive the drawer,huh? Although, you did remove it for one of the photos above. MRB |
Post# 141800 , Reply# 25   7/12/2006 at 20:28 (6,497 days old) by mrb627 (Buford, GA)   |   | |
