Thread Number: 72205
Speed Queen compatible fill valves |
Post# 954774   8/27/2017 at 08:19 (2,434 days old) by chetlaham (United States)   |   | |
I am looking for a new fill valve which will fit a 2013 Speed Queen, but have a faster fill rate and a 50/50 mix would be fine by me. I am looking to replace the current fill valve in my Queen since it fills WAY to slow on the hot and the cold could be faster.
And before I do this- just how fast can a Speed Queen funnel fill before splashing or dripping? |
Post# 955060 , Reply# 1   8/28/2017 at 16:46 (2,433 days old) by Yogitunes (New Jersey)   |   | |
Post# 955137 , Reply# 2   8/29/2017 at 06:19 (2,432 days old) by mrb627 (Buford, GA)   |   | |
In looking through a couple of parts manuals, the general fill valve seems to operate at 5.5 GPM. The Alliance branded units don't have a flow rate associated with them. Unpublished.
Some valves have a flow rate restriction washer in the outbound port. Have you examines the SQ unit to see if they have one? Maybe it could be removed. I wonder if modifying the flow rate would shorten the life of the valve... any thoughts? Malcolm |
Post# 955142 , Reply# 3   8/29/2017 at 06:39 (2,432 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
The pressure on the valve could be a little higher if you remove the flow retrictors, thus opening\closing could be a little more strain, though I doubt that would make much of a difference in total... |
Post# 955951 , Reply# 4   9/3/2017 at 16:52 (2,427 days old) by chetlaham (United States)   |   | |
I don't believe these have a removable restrictor- and none inline that I can see.
