Thread Number: 72457
Samsung PowerFoam/EcoBubble |
Post# 957502   9/14/2017 at 08:59 (2,415 days old) by MrAlex (London, UK)   |   | |
So, Samsung is advertising better stain removal and better results at lower washing temperatures with their PowerFoam (for US) and EcoBubble (Europe and probably the rest of the world)
CLICK HERE TO GO TO MrAlex's LINK |
Post# 957519 , Reply# 2   9/14/2017 at 11:15 (2,415 days old) by MrAlex (London, UK)   |   | |
Post# 957543 , Reply# 3   9/14/2017 at 14:18 (2,415 days old) by Rolls_rapide (.)   |   | |
That recirculation jet looks decidedly weak. Why don't manufacturers use decent strength pumps? |
Post# 957547 , Reply# 4   9/14/2017 at 15:02 (2,415 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
All that is doing is adding water flow. Gravity and tumbling cause enough pressure anyways. |
Post# 957549 , Reply# 5   9/14/2017 at 15:22 (2,415 days old) by Rolls_rapide (.)   |   | |
The Miele W1 machines look as though they have a much more powerful recirculation jet. |
Post# 957550 , Reply# 6   9/14/2017 at 15:23 (2,415 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
Just a different angle and outlet nozzle shape, doubt there is much pressure difference. |
Post# 957551 , Reply# 7   9/14/2017 at 15:27 (2,415 days old) by Rolls_rapide (.)   |   | |
I wonder what the wash results and time saving would be if manufacturers fitted a dishwasher recirculating pump to washing machines...? |
Post# 957605 , Reply# 9   9/15/2017 at 02:58 (2,415 days old) by logixx (Germany)   |   | |
I like Panasonic's system: dump some water anf detergent into thw outer tub, spin the drum - foam and mostly dissolved detergent. The disadvantage, however, is that Panasonic has to use a motorized sump valve to prevent detergent from being pushed into the drain pump area.
Some manufacturers premix detergent with water and spray that onto the clothes (TOL Whirlpool US and Panasonic in Asia, for example). |
Post# 957615 , Reply# 10   9/15/2017 at 04:54 (2,415 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
Don't think so. I mean, we had one for a short period (VG4-generation). The recirculation pump is attached to the drain pump filter housing, so water will be pulled through there anyways. |
Post# 957650 , Reply# 12   9/15/2017 at 11:32 (2,414 days old) by Maytag85 (Sean A806)   |   | |
Post# 957657 , Reply# 14   9/15/2017 at 12:25 (2,414 days old) by Maytag85 (Sean A806)   |   | |
There is something called "Rosalie's Zero Suds" and I heard it works quite well. I don't know how much it costs, but it must work well. I don't use a lot of detergent in my Maytag, but if something is heavily soiled, I use a little more, but not much. Sometimes there will be a lot of suds at the beginning of the wash cycle, but at the end before the first spin, all of the suds will be gone (the soil in clothes can eat up the suds)
Post# 957662 , Reply# 15   9/15/2017 at 13:13 (2,414 days old) by DADoES (TX, U.S. of A.)   |   | |
