Thread Number: 72499
/ Tag: Vintage Dishwashers
Kitchenaid Superba overflow problem |
Post# 957955 , Reply# 1   9/18/2017 at 01:36 (2,412 days old) by rp2813 (Sannazay)   |   | |
I'd check the float switch first. I'm not sure about the 17 series, but later models have the float located on the floor of the tub at front left. If you move it up and down while the tub is empty, you should hear the switch clicking underneath the machine.
Does the overflowing stop when you shut off the machine or do you have to shut off the water supply? If you have to shut off the supply valve, I'd suspect the machine's inlet valve solenoid is either stuck open or isn't receiving the signal to close. Experts here can advise on how to test it.
Post# 957957 , Reply# 2   9/18/2017 at 02:21 (2,412 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 958080 , Reply# 3   9/18/2017 at 23:01 (2,411 days old) by rp2813 (Sannazay)   |   | |
Post# 958833 , Reply# 4   9/24/2017 at 00:29 (2,406 days old) by amyofescobar (oregon)   |   | |
I have the same machine and it's had the same problem. One thing that helped is cleaning the fill sensor in the bottom of the basin. It's next to the filter basket.
Im still not sure why it happens, and I need to figure it out. Meanwhile, I just keep checking to make sure the unit is clean. If I dont wash dishes for a few days, a mold or something builds up. By the way, does your machine fully drain at the end of a cycle? Mine doesnt, and I was told that is common in this model, but I have to wonder if theres a way to correct that. |
