Thread Number: 73162
spin speeds |
Post# 966311   11/5/2017 at 23:16 (2,363 days old) by Losangeles (Muscle Shoals, AL 35661)   |   | |
Can someone explain why to a non-engineering type combos spin at such low speeds. I have watched the video of the Duomatic racing at 250 RPM and my mother had a Westinghouse slant front combo that could probably reach 350 RPM on a good day. And why do washers that spin counter clockwise achieve higher spin speeds than those that spin clockwise? I have always wondered. Thanks
Post# 966318 , Reply# 1   11/5/2017 at 23:53 (2,363 days old) by turquoisedude (.)   |   | |
Post# 966386 , Reply# 4   11/6/2017 at 11:26 (2,363 days old) by bajaespuma (Connecticut)   |   | |
This brings me to a question I've had about front loaders that I've owned. When my LG front loader was in working condition, I noticed that it took the machine (most loads) many, many attempts at balancing the load before it could begin the spin cycle, in earnest, which would gradually wind up to 1200 rpm. There were loads where the LG would simply give up and flash an error code indicating the user needed to manually redistribute the load or remove some of it.
My Miele, on the other hand, never has to waste a lot of time balancing the load. It is much smaller than the LG so I was wondering if this was just a function of size, or did Miele have a better balancing system?
Talk amongst yourselves. |
Post# 966401 , Reply# 5   11/6/2017 at 12:55 (2,363 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 966403 , Reply# 6   11/6/2017 at 13:06 (2,363 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Historically built like tanks in aid of coping with unbalanced loads to some extent. The older machines in particular have all that weight plus heavy duty suspension system. Newer machines IIRC still have or much of this but maybe even more robust shocks/suspension system.
My AEG Oko-Lavamat OTOH is another matter. The machine is clearly designed to avoid where possible spinning with unbalanced loads out of a certain parameter. The shocks/suspension system are not nearly as robust as the Miele. While the Miele will make a set number of attempts then simply start spinning, the AEG will take ages (to me it seems) of drum movements to get the wash juuuust right before spinning. There are times have stopped, opened up, pulled out and redistributed load, then started things up again just to move the process along. |
Post# 966450 , Reply# 8   11/6/2017 at 18:08 (2,362 days old) by Losangeles (Muscle Shoals, AL 35661)   |   | |
Post# 966571 , Reply# 10   11/7/2017 at 10:25 (2,362 days old) by bajaespuma (Connecticut)   |   | |
