Thread Number: 73292
/ Tag: Modern Dishwashers
Miele G2150 Dishwasher Arm Spin-Off? |
Post# 968106   11/15/2017 at 13:20 (2,354 days old) by rp2813 (Sannazay)   |   | |
I ran the Miele last night after dinner. This morning when I opened it up to retrieve the coffeemaker carafe, I found the upper rack (second tier for glassware, etc.) wash arm sitting on top of the items in the lower rack. It was easy to figure out how to re-attach it, but I'm wondering what caused this.
If there's anything in the lower rack that might create an obstruction, I always give the upper arm a spin to make sure it clears. The only thing I can think of is that maybe something shifted and blocked the arm, and somehow the connection point remained spinning while the arm wasn't, and the arm detached. Or maybe it just worked itself loose over the 4+ years I've had this machine. There's no good way to grip the hub where the arm attaches when tightening it, and I suspect it's a hand-tighten design.
This must have happened late in the game because there was a plastic cooking spoon with hardened cheese and other stuff stuck to it in this rack, and it came out clean. Any other theories on why this happened?
Post# 968111 , Reply# 1   11/15/2017 at 13:43 (2,354 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
I cleaned the spray arm on our Bosch a few loads ago, wasn't carefull when reattaching it and the same thing happend. Probably just worked itself loose. |
Post# 968147 , Reply# 3   11/15/2017 at 16:51 (2,354 days old) by mielerod69 (Australia)   |   | |
Hi Brisnat81,
When did you get your new dishwasher? When I lived in Melbourne, I had a G 5935 SCi which I left behind. Here in Sydney I have the G 2834 SCi. Even though this doesn't have QPW, I can replicate it with Light soiling + turbo option which lasts just over an hour. You can really hear the water movement in that program. Cheers Rod |
Post# 968179 , Reply# 5   11/15/2017 at 18:55 (2,353 days old) by rp2813 (Sannazay)   |   | |
