Thread Number: 73355
/ Tag: Vintage Dishwashers
KitchenAid by Hobart - Runs Hot Water Down the Drain |
Post# 968914 , Reply# 1   11/19/2017 at 11:14 (2,350 days old) by cjhsa (Grand Rapids)   |   | |
You'll have to turn your head clockwise or screen counter clockwise to see the mouse pic properly. Sorry, at least it's clear. |
Post# 968923 , Reply# 2   11/19/2017 at 13:18 (2,350 days old) by Tomturbomatic (Beltsville, MD)   |   | |
The drain valve is probably shorted open. |
Post# 968948 , Reply# 3   11/19/2017 at 16:59 (2,350 days old) by Gyrafoam (Wytheville, VA)   |   | |
Really nice machine. Will clean circles around most of the junk on the market today------ once it is operating properly. |
Post# 968959 , Reply# 4   11/19/2017 at 17:56 (2,350 days old) by cjhsa (Grand Rapids)   |   | |
So how do you fix a shorted out drain valve? |
Post# 968967 , Reply# 5   11/19/2017 at 18:45 (2,350 days old) by Tomturbomatic (Beltsville, MD)   |   | |
I would start by disconnecting the power from the machine and then removing the mouse. Reconnect the power then see what happens. |
Post# 969063 , Reply# 6   11/20/2017 at 08:24 (2,349 days old) by cjhsa (Grand Rapids)   |   | |
Did that. Cleaned contacts with a toothbrush. No luck. |
Post# 982770 , Reply# 7   2/14/2018 at 09:59 (2,263 days old) by cjhsa (Grand Rapids)   |   | |
Well, I will be opening the place up again soon. Wondering if anyone has any other suggestions for how to fix this thing? Should I just buy a new/used one off of Craigslist? |
Post# 982781 , Reply# 8   2/14/2018 at 13:53 (2,263 days old) by eronie (Flushing Michigan)   |   | |
Something is in the drain valve keeping it from closing. Open it up could be a bit of glass toothpick etc. Easy fix. |
Post# 982802 , Reply# 9   2/14/2018 at 15:49 (2,263 days old) by speedqueen (Metro-Detroit)   |   | |
Post# 984565 , Reply# 10   2/27/2018 at 09:17 (2,250 days old) by cjhsa (Grand Rapids)   |   | |
I did take the entire thing apart from the inside and found nothing blocking the drain. Any idea on that dishwasher where the drain solenoid is located? The mouse was way up high, not near the drain. And line power OPENS the solenoid? Thanks - not my area of expertise. |
