Thread Number: 73497
Kitchen Aid Imperial KDI-17 Won't Fill |
Post# 970618 , Reply# 1   11/29/2017 at 13:35 (2,340 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Hi There.
1. Could someone have possibly shut off the water to the dishwasher by accident (Like in shutting off the silcocks outside for the winter ?) 2. Could be a loose wire on the fill solenoid valve. Or just kinda corroded off after all these years ? 3. Vermin ? There is a recent thread about another KitchenAid with the same issue. 4. Is there something wedged under the Over fill Protect Float ? Watch that it moves up and down and clicks when you do. 5.Oh yeah... There is a tiny hole in the sump on the left hand side that sometimes fills up with debris hampering the pressure switch 6. Could be the Pressure Switch. I'll let the Experts chime in and refine what I have said so far : ) Good Luck and I hope you get it fixed. |
Post# 970619 , Reply# 2   11/29/2017 at 13:38 (2,340 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 970658 , Reply# 3   11/29/2017 at 17:01 (2,340 days old) by DSW (New York)   |   | |
Thanks for the quick replies! Can you tell me more about the location of the pressure switch? That and the solenoid seem like they could be the culprits. Water is on, no vermin and no visible signs of corrosion. |
Post# 970728 , Reply# 4   11/30/2017 at 05:09 (2,339 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Calling Dr. Bombay !!! (stevet)
Calling Dr. Bombay... Please come quick as a Solenoid has gone astray....
Post# 970729 , Reply# 5   11/30/2017 at 05:09 (2,339 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 971101 , Reply# 6   12/2/2017 at 07:42 (2,337 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
